Stepper wont work with Mysensors
  • Hello,
    I try to run a stepper 28byj-48 with driver in mysensors. As soon as I Mysensors.h activate the stepper motor will not run. Can anyone help me what I do wrong. I use Int 4,5,6,7, above. Also at 3,4,5,6 not work I put too // for Mysensors the engine is running normally. Also burn without Mysensors all 4 LEDs. With Mysensors burn only 3 LEDs.
  • Hi,
    we need
    • Schematic
    • Code
    • Relevant links to the used parts i.e. datasheets
  • Here the image and the code that i wil use it a start. I am new to programm arduino.
    Schematic that i use this works without Mysensors.h (see the sketch)
    http://engyfun.blogspot.nl/2015/02/here-is-source-code-for-our-28byj48.html
    // =========================== Zet de serielle monitor aan ======================================
    // **************************** Einde Debug *****************************************************
    // =========================== Radio instelling RFM 69 ===========================================
    //#define MY_RADIO_NRF24
    #define MY_RADIO_RFM69
    //=========================== Node en Child infomatie =============================================
    #define MY_NODE_ID 17
    #define CHILD_ID 2
    //***************************** Einde Radio setup ***************************************************
    //#include <MySensors.h>
    #include <AccelStepper.h>
    #define HALFSTEP 8
    // ============================ Motor pin definitions ==================================================
    #define motorPin1  4                    // IN1 on the ULN2003 driver 1
    #define motorPin2  5                    // IN2 on the ULN2003 driver 1
    #define motorPin3  6                    // IN3 on the ULN2003 driver 1
    #define motorPin4  7                    // IN4 on the ULN2003 driver 1
    int CHILD_CURTAIN_ID =4;
    // Initialize with pin sequence IN1-IN3-IN2-IN4 for using the AccelStepper with 28BYJ-48
    AccelStepper stepper1(HALFSTEP, motorPin1, motorPin3, motorPin2, motorPin4);
    MyMessage msg_S_COVER_U(CHILD_CURTAIN_ID, V_UP);
    MyMessage msg_S_COVER_D(CHILD_CURTAIN_ID, V_DOWN);
    MyMessage msg_S_COVER_S(CHILD_CURTAIN_ID, V_STOP);
    MyMessage msg(CHILD_CURTAIN_ID,V_UP);
    // ==============================  Begin Setup ===========================================================
      stepper1.setMaxSpeed(18000.0);
      stepper1.setAcceleration(100.0);
      stepper1.setSpeed(400);
      stepper1.moveTo(20000);
    //****************************----- (Einde setup )---********************************************************
    // ==============================---- Begin Loop ----========================================================
      //Change direction when the stepper reaches the target position
      if (stepper1.distanceToGo() == 0)
        stepper1.moveTo(-stepper1.currentPosition());
      stepper1.run();
    // **************************** Eind Loop ==================================================================```)
    Sorry i can get the  code not in a nice black box.
  • Code looks good so far... (you misplaced the starting and ending ``` to mark code in a black box).
    What I can tell you from own, painful experience: If anything fails with the radio setup (also registration I think), loop() will never be executed. I was testing a LED library, working perfectly without MySensors.h but not doing anything with MySensors.h included.
    Later I realized my controller was switched off..after I switched it on everything worked. So ensure that MySensors can communicate properly. That means implementing presentation() and all other functions..
  • @Pansen,
    Thanks i give it a try.
  • @ Pansen It work now!
    When connect the radio then the 4e led and stepper is working.
    Thanks for the help.
  • 4
  • 933
  • 9
  • 274
11.3k
