2 systems in same location
  • If i want to use 2 or more systems in the same location; sensors will be mixed? How can i ban other system to see my already working sensor? (For vera gateway)
  • Admin
    Select a different frequency (MyConfig.h) before compiling/uploading the new sensors/gateway.
  • Thank you Hek.
    #define RF24_CHANNEL 76 //RF channel for the sensor net, 0-127
    If i change** 76 to 77** it will be a different freq?
    #ifndef MyConfig_h
    #define MyConfig_h
    • Configure Sensor Network
      #define RF24_DATARATE RF24_250KBPS //RF24_250KBPS for 250kbs, RF24_1MBPS for 1Mbps, or RF24_2MBPS for 2Mbps
      #define RF24_PA_LEVEL RF24_PA_MAX //Sensor PA Level == RF24_PA_MIN=-18dBm, RF24_PA_LOW=-12dBm, RF24_PA_HIGH=-6dBM, and RF24_PA_MAX=0dBm
      #define RF24_PA_LEVEL_GW RF24_PA_LOW //Gateway PA Level, defaults to Sensor net PA Level. Tune here if using an amplified nRF2401+ in your gateway.
      #define BASE_RADIO_ID ((uint64_t)0xA8A8E1FC00LL) // This is also act as base value for sensor nodeId addresses. Change this (or channel) if you have more than one sensor network.
    // MySensors online examples defaults
    #define DEFAULT_CE_PIN 9
    #define DEFAULT_CS_PIN 10
    • Enable/Disable debug logging
      #define DEBUG
  • Admin
    yes
  • 4
  • 9
  • 5
  • 14
  • 20
18
11.3k
