send V_TEXT to LCD1602 Display
  • hi,
    i woud to use this sketch to show messages fron my pimatic controller on a 1602 Display.
    This sketch use the V_TEXT variabel to show messages.
    How i can use V_TEXT in pimatic to push messages to the display?
    //Credits: https://forum.mysensors.org/topic/1957/lcd-clock-and-text-sensor-node-with-new-v_text
    //Soft signing.
    //#define MY_SIGNING_SOFT
    //#define MY_SIGNING_REQUEST_SIGNATURES
    //#define MY_SIGNING_SOFT_RANDOMSEED_PIN 7
    #define MY_NODE_ID 3
    #include <TimeLib.h>
    #include <Wire.h>
    char lastLCD1[16] = "Line1"; //Line 1 always showing current time
    char lastLCD2[16] = "Line2";
    //20 whitespace characters used to clear your LCD line before printing to it.
    //Change to fit your LCD. Don't forget to change number of chars in the writeScreen function if needed.
    String LINE_BLANK = "                ";
    boolean timeReceived = false ;
    unsigned long lastUpdate = 0, lastRequest = 0, lastDisplay = 0;
    const byte LCD1_CHILD = 1;                          // Child ID for LCD line 1
    const byte LCD2_CHILD = 2;                          // Child ID for LCD line 2
    MyMessage textMsg(0, V_TEXT);
    // Initialize display. Google the correct settings for your display.
    // The follwoing setting should work for the recommended display in the MySensors "shop".
    LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
    void before() {
      Wire.begin();                                       // I2C.
      lcd.begin(16, 2);                                   // LCD with 20 chars, 4 lines.
      lcd.setBacklight(HIGH);                             // Make sure backlight is on.
      writeScreen(0, "Waiting for GW..");                // Print initial text before contact with GW.
    void setup(void)
      Serial.begin(115200);                               // Start serial.
      requestTime();                                      // Request time from controller.
    void presentation()  {
      sendSketchInfo("Domoticz LCD", "1.0");                    // Send the sketch version information to the gateway and Controller
      present(LCD1_CHILD, S_INFO, "LCD_line1");
      wait(500);
      present(LCD2_CHILD, S_INFO, "LCD_line2");
      wait(500);
      send(textMsg.setSensor(LCD1_CHILD).set("-"));      // initialize the V_TEXT at controller for sensor to none (trick for Domoticz)
      send(textMsg.setSensor(LCD2_CHILD).set("-"));
    void loop()     {
      // timer for loop delays
      unsigned long now = millis();
      // If no time has been received yet, request it every 10 second from controller
      // When time has been received, request update every hour
      if ((!timeReceived && (now - lastRequest > 10 * 1000)) ||
          (now - lastRequest > 3600000UL)) {              // request update from GW every hour to keep in sync
        Serial.println("Requesting time...");
        timeReceived = false;
        requestTime();
        lastRequest = now;
      // Update sensors every 5 seconds
      if (now - lastDisplay > 5000) {
        lastDisplay = now;
        request(LCD1_CHILD, V_TEXT, 0);                  // request new values from controller
        request(LCD2_CHILD, V_TEXT, 0);                  // request new values from controller
      // Update LCD time every second
      if (now - lastUpdate > 1000) {
        LCD_time();
        lastUpdate = now;
    // This is called when a message is received
      if (message.type == V_TEXT) {                       // Text messages only
        Serial.print("Message: "); Serial.print(message.sensor); Serial.print(", Message: "); Serial.println(message.getString());     // Write some debug info
        if (message.sensor == LCD1_CHILD) {
          writeScreen(0, message.data);
    // Don't forget to change "if" to "else if" when controlling all 4 lines:
        else if (message.sensor == LCD2_CHILD) {
          writeScreen(1, message.data);
    void receiveTime(unsigned long ts) {
      setTime(ts);
      timeReceived = true;
    void LCD_time(void) {
      lcd.setCursor(0, 0);
      if (timeReceived) {
        lcd.print(day());
        lcd.print(".");
        printDigits(month());
        lcd.print(".");
        printDigits(year());
        lcd.print(" ");
        printDigits(hour());
        lcd.print(":");
        printDigits(minute());
      } else {
        writeScreen(0, "Waiting for time...");
    void printDigits(int digits) {
    //add leading 0 if digit = 0-9
      if (digits < 10)
        lcd.print('0');
      lcd.print(digits);
    void writeScreen(int line, String text)
      // Remove anything over 20 char in text.
      if (text.length() > 19)
        text.remove(20);
      // Clear the line
      lcd.setCursor(0, line);
      lcd.print(LINE_BLANK);
      // Set Line
      lcd.print(text);
  • 8
  • 92
  • 1
