Out of memory in pressureSensor example
  • Hello,
    I've tried to use a pressureSensor example but Arduino nano clone didn't send any data. During compilation i have seen:
    Sketch uses 23,540 bytes (76%) of program storage space. Maximum is 30,720 bytes.
    Global variables use 1,677 bytes (81%) of dynamic memory, leaving 371 bytes for local variables. Maximum is 2,048 bytes.
    Low memory available, stability problems may occur.
    Serial was looped:
    send:sensor started, id 1
    I solved this problem by disable weather forecast. I suppose device run out of memory with enabled weather forecast.
  • @portals I had same issue - see this thread.
    Download latest library, disable debug and follow @BulldogLowell advice. I managed to get dynamic memory to 75% and that seems sufficient - it has been running for a week now without issues.
  • For now i found this solution:
    I changed a pressureAvg and pressureSamples to unsigned int. Next changed int forecast = sample(pressure) to int forecast = sample(pressure * 10) to avoid big precision lost. Sample function still may need correction but probably it is a good and easy way to fix this problem.
    Result:
    Sketch uses 18,636 bytes (60%) of program storage space. Maximum is 30,720 bytes.
    Global variables use 1,268 bytes (61%) of dynamic memory, leaving 780 bytes for local variables. Maximum is 2,048 bytes.
  • 33
  • 5
  • 17
  • 6
  • 5
  • 11
