multiple buttons on one analog pin arduino
  • I have a problem with programming of an arduino, I want to link 32 push-buttons on one analogic pin on the arduino that communicate radio using NRF with domoticz system on which I have 32 relay's
    Can someone help me with the code?
    Until now I did
    • The MySensors Arduino library handles the wireless radio link and protocol
    • between your home built sensors/actuators and HA controller of choice.
    • The sensors forms a self healing radio network with optional repeaters. Each
    • repeater and gateway builds a routing tables in EEPROM which keeps track of the
    • network topology allowing messages to be routed to nodes.
    • Created by Henrik Ekblad henrik.ekblad@mysensors.org
    • Copyright (C) 2013-2015 Sensnology AB
    • Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
    • Documentation: http://www.mysensors.org
    • Support Forum: http://forum.mysensors.org
    • This program is free software; you can redistribute it and/or
    • modify it under the terms of the GNU General Public License
    • version 2 as published by the Free Software Foundation.
    #include <Bounce2.h>
    #define CHILD_ID 3
    #define CHILD_ID1 4
    #define BUTTON_PIN 3 // Arduino Digital I/O pin for button/reed switch
    #define BUTTON_PIN1 4
    Bounce debouncer = Bounce();
    int oldValue=-1;
    Bounce debouncer1 = Bounce();
    int oldValue2=-1;
    MyMessage msg1(CHILD_ID1,V_TRIPPED);
    // Setup the button
    pinMode(BUTTON_PIN,INPUT);
    pinMode(BUTTON_PIN1,INPUT);
    // Activate internal pull-up
    digitalWrite(BUTTON_PIN1,HIGH);
    debouncer.attach(BUTTON_PIN);
    debouncer1.attach(BUTTON_PIN1);
    debouncer.interval(5);
    debouncer1.interval(5);
    void presentation() {
    sendSketchInfo("ButoaneTest", "2.0");
    present(CHILD_ID, S_LIGHT);
    present(CHILD_ID1, S_LIGHT);
    int isOn = 0;
    int isOn1 = 0;
    // Check if digital input has changed and send in new value
    debouncer.update();
    // Get the update value
    int value = debouncer.read();
    if (value != oldValue) {
    if (value == HIGH) {
    if (isOn == 0) {
    isOn = 1;
    } else {
    isOn = 0;
    send(msg.set(isOn));
    oldValue = value;
    debouncer1.update();
    int value1 = debouncer1.read();
    if (value1 != oldValue2) {
    if (value1 == HIGH) {
    if (isOn1 == 0) {
    isOn1 = 1;
    } else {
    isOn1 = 0;
    send(msg1.set(isOn1));
    oldValue2 = value1;
  • Contest Winner
    @daniel.stancu you can do something like this
    This examples servers 10 switches with 10 relays
       Created by Henrik Ekblad <henrik.ekblad@mysensors.org>
       REVISION HISTORY
       Version 1.0 - Henrik Ekblad
       DESCRIPTION
       Example sketch showing how to control physical relays.
       This example will remember relay state after power failure.
       http://www.mysensors.org/build/relay
    #define MY_REPEATER_FEATURE
    #define NUMBER_OF_RELAYS 10   // Total number of attached relays and switches
    unsigned int  relay_pins[NUMBER_OF_RELAYS] = { 1, 2, 3, 4, 5, 6, 7, 8, A1, A2 };
    #define RELAY_ON     1            // GPIO value to write to turn on attached relay
    #define RELAY_OFF    0          // GPIO value to write to turn off attached relay
    MyMessage  msg(0,  V_LIGHT);
    #define BUTTON_PIN   A0
    #define NO_BUTTON    255
    // The followinging are interrupt-driven keypad reading functions
    //  which includes DEBOUNCE ON/OFF mechanism, and continuous pressing detection
    #define NUM_BUTTONS     NUMBER_OF_RELAYS
    //keypad debounce parameter
    #define DEBOUNCE_MAX 6
    #define DEBOUNCE_ON  4
    #define DEBOUNCE_OFF 2
    // adc preset value, represent top value,incl. noise & margin,that the adc reads, when a key is pressed
    // set noise & margin = 30 (0.15V@5V)
    unsigned int  adc_key_val[NUM_BUTTONS] = { 50, 150, 200, 250, 300, 450, 500, 550, 600, 650 };
    // debounce counters
    byte button_count[NUM_BUTTONS];
    // button status - pressed/released
    byte button_status[NUM_BUTTONS];
    // button on flags for user program
    byte button_flag[NUM_BUTTONS];
    byte lastButtonPressed = NO_BUTTON;
    void before()
      for (int sensor = 0; sensor < NUMBER_OF_RELAYS; sensor++) {
        pinMode(relay_pins[sensor], OUTPUT);
        digitalWrite(relay_pins[sensor], loadState(sensor) ? RELAY_ON : RELAY_OFF);
      pinMode(BUTTON_PIN, INPUT);
      // reset button arrays
      for (byte i = 0; i < NUM_BUTTONS; i++)
        button_count[i]  = 0;
        button_status[i] = 0;
        button_flag[i]   = 0;
      sendSketchInfo("Relay 32", "1.0");
        present(sensor + 1, S_BINARY);
      byte button = buttonPressed();
      // Check if there was a change of buttons presses
      if (button != lastButtonPressed)  {
        // YES we detected a change, only response when buttons was released
        if (button == NO_BUTTON) {
          msg.sensor = button + 1;
          send(msg.set(loadState(button) ? "0" : "1") );
        lastButtonPressed = button;
      wait(10);
    char buttonPressed()
        if (button_flag[i] != 0) {
          button_flag[i] = 0;
          return i;
      return NO_BUTTON;
    // Convert ADC value to key number
    char get_key(unsigned int input)
      for (int k = 0; k < NUM_BUTTONS; k++)
        if (input < adc_key_val[k]) {
          return k;
      return -1;    // No valid key pressed
    void update_adc_key()
      unsigned int adc_key_in;
      char key_in;
      byte i;
      adc_key_in = analogRead(BUTTON_PIN);
      Serial.println(adc_key_in); // For debug only
      key_in = get_key(adc_key_in);
      for (i = 0; i < NUM_BUTTONS; i++)
        if (key_in == i) {
          //one key is pressed
          if (button_count[i] < DEBOUNCE_MAX) {
            button_count[i]++;
            if (button_count[i] > DEBOUNCE_ON) {
              if (button_status[i] == 0) {
                button_flag[i] = 1;
                button_status[i] = 1; //button debounced to 'pressed' status
        else // no button pressed
          if (button_count[i] > 0) {
            button_flag[i] = 0;
            button_count[i]--;
            if (button_count[i] < DEBOUNCE_OFF) {
              button_status[i] = 0;   //button debounced to 'released' status
        // Change relay state
        digitalWrite(relay_pins[message.sensor - 1], message.getBool() ? RELAY_ON : RELAY_OFF);
        // Store state in eeprom
        saveState(message.sensor - 1, message.getBool());
        // Write some debug info
        Serial.print(message.sensor);
    You have to connect the switches likes this, the value for R2 - Rx resistors around 100 ohms and 10k for R1.
    With the Serial.println debug statement one has to determine the correct analog values for the adc_key_val array (start with the lowest value first) by pressing the keys one by one, add approx 30 to the average values per button you see in the serial monitor too have some margin.
  • Hello.
    Thanks for the answer, now I'm working on finding the arduino resistor values.
  • This is a nice simple solution. There is one downside that is worth noting, pushing multiple buttons at the same time will throw it off. If that isnt a concern it will serve well.
  • Hello
    first of all, excuse me for my english, i'm french.
    I try to use the sketch with the 10 relays, but nothing works on the buttons.
    I tried with several resistance values using "analogread" to read the real values, but when I enter the values in the table nothing happens at the relay levels.
    P.S: the relays work with jeedom.
    can you give me the procedure to follow to properly "configure" the sketch?
    cordially
  • 1
  • 10
  • 1
  • 5
