Help troubleshooting Ethernet Gateway
  • Hi Friends, I started upgrading my system to Openhab2
    I was using Openhab 1.8 with a MQTT gateway working fine. Now with same hardware I flashed the gateway to be Ethernet gateway, but I'm not able to make it work. I think the Gateway is not connecting with Openhab
    In Openhab is always in offline state and if I disable startup check it appears as online but Opebhab debug shows like connections retries.
    This is console output from my gateway
    0;255;3;0;9;Eth: connect
    0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.1
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSF:WUR:MS=0
    0;255;3;0;9;TSM:INIT:TSP OK
    0;255;3;0;9;TSM:INIT:GW MODE
    IP: 192.168.88.205
    0;255;3;0;9;MCO:BGN:STP
    IP: 192.168.88.205
    IP: 192.168.88.205
    IP: 192.168.88.205
    IP: 192.168.88.205
    IP: 192.168.88.205
    and this is the DEBUG output from Openhab
    21:01:31.744 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: []
    21:01:31.744 [ERROR] [al.protocol.ip.MySensorsIpConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:44)
    21:01:31.744 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Disconnecting from IP bridge ...
    21:01:31.745 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Stopping Writer thread
    21:01:31.753 [WARN ] [rsAbstractConnection$MySensorsWriter] - Interrupted MySensorsWriter
    21:01:31.759 [DEBUG] [rsAbstractConnection$MySensorsReader] - Stopping Reader thread
    21:01:31.762 [WARN ] [rsAbstractConnection$MySensorsReader] - Interrupted MySensorsReader
    21:01:31.767 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: []
    21:01:41.770 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Connecting to IP bridge [192.168.88.205:5003]
    21:01:41.777 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
    21:01:42.774 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
    21:01:43.775 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
    21:01:44.775 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
    21:01:45.775 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
    21:01:46.775 [ERROR] [al.protocol.ip.MySensorsIpConnection] - Cannot start reading/writing thread, probably sync message (I_VERSION) not received. Try set skipStartupCheck to true
    Any Ideas
    Any help will be appreciated.
  • Mod
    May I ask why you changed from mqtt to ethernet? Did you change the connector type in Openhab?
  • Hi gohan.
    Sorry If I did not explain correctly. I upgraded to OpenHab 2.1.0
    I was previously using RaspberryPi with OpenHab 1.8 + MQTT gateway.
    Now I switched to a VM with Debian and OpenHab 2.1.0. and as I read that the MQTT gateway was not working with OH2.1 I flashed my gateway as an ethernet gw.
    Regarding the logs.
    I turned off the OpenHab machine and the gateway still repeats the output. Is it possible that the gateway is continuosly restarting?
  • Mod
    it looks like it has a problem, try using the library version 2.2 from development branch
  • Ok, I'll try that.
    Are you refering to the mySensors library, right?
  • Mod
    yes, I didn't thought about the version being similar number to OpenHab
  • Hi, It worked. using the 2.2 library solved my issue. Now I'll setup openhab. thanks for your quick and effective answer
11.3k
