Openhab and Gateway Types
  • Hi,
    I have a sensor node communicating via RF24 to a Raspberry Pi (RPi) gateway. This RPi gateway is connected via Ethernet to Openhub ( the controller software) also running on the same RPi. This is all working fine. I want to add a SonOff relay to this setup and I want to communicate with the SunOff via MQTT messages.
    If I install the MQTT broker software (Mosquitto) on the RPi, will Openhab be able to communicate with the SunOff device, or do I have to add another MQTT gateway application on the RPi?
  • Mod
    You don't need anything else.
  • Thank you
  • 22
  • 10
  • 5
  • 135
  • 7
22
