MySensors MQTT gateway and serial rs485 sensor node communication
  • Hi all,
    I would like to setup an sensor network with an ethernet gatway and wired connected sensor nodes. (RS485)
    Gateway: Arduino Uno R3 with W5100 ethernet shield.
    Sensor Nodes: Nodes are connected with gateway via wired rs485 connection (cable).
    Connection Flow 1 # Get sensor values:
    Arduino Sensor Node (RS485) --> Gateway --> MQTT --> OpenHab2
    Connection Flow 2 # Issue commands to sensor node: (e.g. activate relay)
    OpenHab2 --> MQTT --> Gateway --> Arduino Sensor Node (RS485)
    Is that possible with the MySensors library?
    Because the RS485 gateway example I found on this page doesnt seem to use MQTT communication to OpenHab?
    Regards,
    Simon
  • Mod
    @ehome welcome to the MySensors community!
    It should be as easy as changing
    #define MY_GATEWAY_SERIAL
    to
    and add the configuration parameters listed on the mqtt gateway page.
  • Thanks for your fast reply.
    That sounds easy.
    And you think that the communication between sensor nodes and Gateway are still possible via wired RS485?
    I tried to find an example on this site for sending Information from Gateway to sensor nodes. (via SendMessage ?)
    For example I like to Switch on/off an light that is connected to an relay board at my sensor node.
    Communcation Flow:
    OpenHab2 --> MQTT --> Gateway --> RS485 --> Sensor Node --> Relay Board
    Currently I have an working RS485 Connection between my Arduino Uno's with the use from SoftwareSerial library.
    During my testings I realized, that the message that I triy to send "Hello" will be sent to the other arduino char by char. Is that true?
    Because I tried to raise up an pin on HIGH with "if(msg == "Hello")..." But it doesn't worked.
    Will the sendMsg method from the MySensor library handle this out of the box?
    Regards,
    Simon
