Sample Door SW does not compile !
  • Hello everybody,
    I wish you a wonderful year 2015 .
    I have a problem when I try to compile the "BinarySwitchSensor Example".
    I receive the following message :
    In file included from /Users/guest/Documents/Arduino/MySensorGW/libraries/MySensors/MySensor.h:28,
    from MySensorDoorSW.ino:4:
    /Users/guest/Documents/Arduino/MySensorGW/libraries/MySensors/utility/RF24.h:51: error: ISO C++ forbids declaration of 'SoftSPI' with no type
    /Users/guest/Documents/Arduino/MySensorGW/libraries/MySensors/utility/RF24.h:51: error: expected ';' before '<' token
    I currently work with the release 1.5.5 of the Arduino IDE
    Somebody could help me ?
    Thanks by advance
    Alain
  • I can compile and use door sample from mysensor.
    the difference is that i'm using old arduino ide 1.0.5, while you're using 1.5.5.
    possible to change the ide ?
  • Hardware Contributor
    I compile the example sketch fine with IDE 1.5.7.
    Do you have uncommented the #define SOFTSPI in RF24_config.h for some reason (eg programming your gateway)?. If so comment it back again.
11.3k
