RFM69 new driver delay
  • Hello,
    i am going to change my network from NRF24 to RFM69.
    Using the old RFM69 driver all is working fine. Using the new driver there is a delay on the nodes with an actor. The serial output shows that the gateway sends a request to the node, getting an acknolege the message is send to the node. This delays the actor appx 1.5 seconds. For nodes eg. lights with dimming funktion not very nice.
    Is there any possibility to speed this up ?
    My setup is: Fhem, Mysensors 2.2 rc1, ESP8266 Gateway - RFM69, node with RFM69
    Thanks for help!
    Have a good day
    Stefan
  • Mod
    I haven't tried actuators yet with rfm69, but new driver has ACS enabled, you could try to disable it and set a fixed TX power
  • @gohan said in RFM69 new driver delay:
    ACS enabled
    What i tried is before is #define MY_RFM69_ATC_MODE_DISABLED , no change
    Stefan
  • Hardware Contributor
    hello,
    could you provide sketch for gw and node, + logs please ?
  • Hello,
    here are the scetches gateway an simple actor with logs. Nothing strange, i think.
    I set some values ti fixed, for testing. If i use the old driver the response is imediatly.
    the scetches
    0_1509659557196_GatewayESP8266_RFM69.ino
    0_1509659598721_RelayActuator_TestRFM69_new.ino
    the logs, i switched on / off several times
    log gateway
    823183 Client 0: 55;1;1;0;2;1
    823199 RFM69:SWR:SEND,TO=55,RETRY=0
    824244 RFM69:SWR:ACK,FROM=55,SEQ=81,RSSI=-25
    824267 TSF:MSG:SEND,0-0-55-55,s=1,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:1
    828216 Client 0: 55;1;1;0;2;0
    828231 RFM69:SWR:SEND,TO=55,RETRY=0
    829277 RFM69:SWR:ACK,FROM=55,SEQ=82,RSSI=-25
    829300 TSF:MSG:SEND,0-0-55-55,s=1,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:0
    832936 Client 0: 55;1;1;0;2;1
    832952 RFM69:SWR:SEND,TO=55,RETRY=0
    833997 RFM69:SWR:ACK,FROM=55,SEQ=83,RSSI=-25
    834020 TSF:MSG:SEND,0-0-55-55,s=1,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:1
    837842 Client 0: 55;1;1;0;2;0
    837858 RFM69:SWR:SEND,TO=55,RETRY=0
    838903 RFM69:SWR:ACK,FROM=55,SEQ=84,RSSI=-25
    838926 TSF:MSG:SEND,0-0-55-55,s=1,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:0
    843821 Client 0: 55;1;1;0;2;1
    843836 RFM69:SWR:SEND,TO=55,RETRY=0
    843883 RFM69:SWR:ACK,FROM=55,SEQ=85,RSSI=-25
    843906 TSF:MSG:SEND,0-0-55-55,s=1,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:1
    900302 TSF:SAN:OK
    Log node
    Incoming change for sensor:1, New status: 1
    58841 RFM69:SAC:SEND ACK,TO=0,RSSI=-25
    58863 TSF:MSG:READ,0-0-55,s=1,c=1,t=2,pt=0,l=1,sg=0:0
    Incoming change for sensor:1, New status: 0
    63559 RFM69:SAC:SEND ACK,TO=0,RSSI=-25
    63584 TSF:MSG:READ,0-0-55,s=1,c=1,t=2,pt=0,l=1,sg=0:1
    68464 RFM69:SAC:SEND ACK,TO=0,RSSI=-25
    68489 TSF:MSG:READ,0-0-55,s=1,c=1,t=2,pt=0,l=1,sg=0:0
    73443 RFM69:SAC:SEND ACK,TO=0,RSSI=-25
    73467 TSF:MSG:READ,0-0-55,s=1,c=1,t=2,pt=0,l=1,sg=0:1
    Stefan
  • Hello,
    i have done some more test benching both drivers. Sending a command on and off.
    Using the new driver is like indian smoke signs, response more than 1 sec.
    I just uncomment the #define MY_RFM69_NEW_DRIVER i am in a different world
    The response using the old driver is below 100ms.
    By the way, gateway and node are in the same small room.
    Have good time
    Stefan
  • @scalz : any news about this problem ? I would like to move to the new driver but after reading this, I think it will be better to wait 😉
  • no news, i am using the old driver
  • Any news here? Can we use the new driver or should we stay with the old one?
  • Hi
    Yesterday i update my MySenors 2.2.0 to version 2.3.0. I use it with gateway on my Home Assistant. But after update i have big problem with communication on radio RFM69HW. Sometimes communication is lost or very long. When i send command to node sometimes it no received it. But when come back to old version 2.2.0 all works perfect.
    Some users suggest me to no use "NEW_DRIVER" It is true ?
    This is code my sketch:
    #define MY_RADIO_RFM69
    #define MY_IS_RFM69HW
    #define RFM69_868MH
    #define MY_REPEATER_FEATURE
    //#define MY_RFM69_CSMA_LIMIT_DBM (-85)
    // uncomment if we want to manually assign an ID
    #define MY_NODE_ID 1
    #include <Bounce2.h>
    #define BUTTON_UP_PIN 3  // Arduino Digital I/O pin number for up button
    #define BUTTON_DOWN_PIN 4  // Arduino Digital I/O pin number for down button
    //#define BUTTON_STOP_PIN 5  // Arduino Digital I/O pin number for stop button
    //#define RELAY_DIR_PIN 6  // Arduino Digital I/O pin number for direction relay
    //#define RELAY_POWER_PIN 7  // Arduino Digital I/O pin number for power relay
    #define RELAY_UP_PIN 5
    #define RELAY_DOWN_PIN 6
    #define RELAY_ON 0
    #define RELAY_OFF 1
    //#define RELAY_DOWN 1
    //#define RELAY_UP 0
    #define DIRECTION_DOWN 0
    #define DIRECTION_UP 1
    #define SKETCH_NAME "Roleta w sypialni"
    #define SKETCH_VER "2.3"
    #define CHILD_ID_COVER 0   // sensor Id of the sensor child
    #define STATE_UP 100 // 100 is open - up
    #define STATE_DOWN 0 // 0 is closed - down
    //#define CHILD_ID_CALIBRATE 1   // sensor Id of the sensor child to calibrate
    #define CHILD_ID_SET 1   // sensor Id of the sensor child to init the roll time
    #define PRESENT_MESSAGE "Rolety dla Home Assistant"
    const int LEVELS = 100; //the number of levels
    float rollTime = 20.0; //the overall rolling time of the shutter
    const bool IS_ACK = false; //is to acknowlage
    static bool initial_state_sent = false;//for hass we need at list one state send at begining
    // debouncing parameters
    int value = 0;
    int oldValueUp = 0;
    int oldValueDown = 0;
    int oldValueStop = 0;
    //static unsigned long last_interrupt_time_up = 0;
    //static unsigned long last_interrupt_time_down = 0;
    //static unsigned long debounce_time = 200;
    Bounce debouncerUp = Bounce();
    Bounce debouncerDown = Bounce();
    Bounce debouncerStop = Bounce();
    // shutter position parameters
    float timeOneLevel = rollTime / LEVELS;
    int requestedShutterLevel = 0;
    int currentShutterLevel = 0;
    unsigned long lastLevelTime = 0;
    bool isMoving = false;
    int directionUpDown;
    bool calibrateDown;
    bool calibrateUp;
    unsigned long calibrationStartTime;
    float calibrationTime = 5.0;
    bool calibratedDown;
    bool calibratedUp;
    enum CoverState {
      STOP,
      UP, // Window covering. Up.
      DOWN, // Window covering. Down.
    static int coverState = STOP;
    MyMessage msgUp(CHILD_ID_COVER, V_UP);
    MyMessage msgDown(CHILD_ID_COVER, V_DOWN);
    MyMessage msgStop(CHILD_ID_COVER, V_STOP);
    MyMessage msgPercentage(CHILD_ID_COVER, V_PERCENTAGE);
    //MyMessage msgCode(CHILD_ID_SET, V_IR_SEND);
    void sendState() {
      // Send current state and status to gateway.
    //  send(msgUp.set(coverState == UP));
    //  send(msgDown.set(coverState == DOWN));
    //  send(msgStop.set(coverState == STOP));
      send(msgPercentage.set(currentShutterLevel));
    void shuttersUp(void) {
      #ifdef MY_DEBUG
      Serial.println("Shutters going up");
      if (digitalRead(RELAY_DOWN_PIN) == RELAY_ON) {
        digitalWrite(RELAY_DOWN_PIN, RELAY_OFF);
        wait(50);
      digitalWrite(RELAY_UP_PIN, RELAY_ON);
      directionUpDown = DIRECTION_UP;
      isMoving = true;
      coverState = UP;
      sendState();
    void shuttersDown(void) {
      #ifdef MY_DEBUG
      Serial.println("Shutters going down");
      if (digitalRead(RELAY_UP_PIN) == RELAY_ON) {
        digitalWrite(RELAY_UP_PIN, RELAY_OFF);
        wait(50);
      digitalWrite(RELAY_DOWN_PIN, RELAY_ON);
      directionUpDown = DIRECTION_DOWN;
      isMoving = true;
      coverState = DOWN;
      sendState();
    void shuttersHalt(void) {
    #ifdef MY_DEBUG
      Serial.println("Shutters halted");
      isMoving = false;
      requestedShutterLevel = currentShutterLevel;
    #ifdef MY_DEBUG
      Serial.println("saving state to: ");
      Serial.println(String(currentShutterLevel));
      saveState(CHILD_ID_COVER, currentShutterLevel);
      coverState = STOP;
      sendState();
    void changeShuttersLevel(int level) {
      int dir = (level > currentShutterLevel) ? DIRECTION_UP : DIRECTION_DOWN;
      if (isMoving && dir != directionUpDown) {
        shuttersHalt();
      requestedShutterLevel = level;
    void initShutters() {
    #ifdef MY_DEBUG
      Serial.println("Init Cover");
      shuttersUp();
      wait((rollTime + timeOneLevel * LEVELS) * 1000);
      currentShutterLevel = STATE_UP;
    #ifdef MY_DEBUG
      Serial.println("recieved incomming message");
      Serial.println("Recieved message for sensor: ");
      Serial.println(String(message.sensor));
      Serial.println("Recieved message with type: ");
      Serial.println(String(message.type));
      if (message.sensor == CHILD_ID_COVER) {
        switch (message.type) {
          case V_UP:
            //Serial.println(", New status: V_UP");
            changeShuttersLevel(STATE_UP);
            //state = UP;
            //sendState();
            break;
          case V_DOWN:
            //Serial.println(", New status: V_DOWN");
            changeShuttersLevel(STATE_DOWN);
            //state = DOWN;
            //sendState();
            break;
          case V_STOP:
            //Serial.println(", New status: V_STOP");
            shuttersHalt();
            //state = IDLE;
            //sendState();
            break;
          case V_PERCENTAGE:
            //Serial.println(", New status: V_PERCENTAGE");
            //          if (!initial_state_sent) {
            //            #ifdef MY_DEBUG
            //            Serial.println("Receiving initial value from controller");
            //            #endif
            //            initial_state_sent = true;
            int per = message.getInt();
            if (per > STATE_UP) {
              per = STATE_UP;
            changeShuttersLevel(per);
            //InitShutters(message.getInt());//send value < 0 or > 100 to calibrate
            //sendState();
            break;
    else if (message.sensor ==  CHILD_ID_SET) {
        if (message.type == V_VAR1) {
          #ifdef MY_DEBUG
          Serial.println(", New status: V_VAR1, with payload: ");
          String strRollTime = message.getString();
          rollTime = strRollTime.toFloat();
          #ifdef MY_DEBUG
          Serial.println("rolltime value: ");
          Serial.println(String(rollTime));
          saveState(CHILD_ID_SET, rollTime);
    #ifdef MY_DEBUG
      Serial.println("exiting incoming message");
      return;
    void before() {
      // Setup the button
      pinMode(BUTTON_UP_PIN, INPUT_PULLUP);
      // Activate internal pull-up
    //  digitalWrite(BUTTON_UP_PIN, HIGH);
      //  attachInterrupt(digitalPinToInterrupt(BUTTON_UP_PIN), upButtonPress, FALLING);
      pinMode(BUTTON_DOWN_PIN, INPUT_PULLUP);
    //  digitalWrite(BUTTON_DOWN_PIN, HIGH);
      //  attachInterrupt(digitalPinToInterrupt(BUTTON_DOWN_PIN), downButtonPress, FALLING);
    //  pinMode(BUTTON_STOP_PIN, INPUT_PULLUP);
    //  digitalWrite(BUTTON_STOP_PIN, HIGH);
      debouncerUp.attach(BUTTON_UP_PIN);
      debouncerUp.interval(5);
      debouncerDown.attach(BUTTON_DOWN_PIN);
      debouncerDown.interval(5);
    //  debouncerStop.attach(BUTTON_STOP_PIN);
    //  debouncerStop.interval(5);
      pinMode(RELAY_UP_PIN, OUTPUT);
      pinMode(RELAY_DOWN_PIN, OUTPUT);
    void presentation() {
      sendSketchInfo(SKETCH_NAME, SKETCH_VER);
      present(CHILD_ID_COVER, S_COVER, PRESENT_MESSAGE, IS_ACK);
      // present(CHILD_ID_SET, S_CUSTOM);
    void setup(void) {
      //set up roll time if the saved value is not 255
      #ifdef MY_DEBUG
      Serial.println("getting rolltime from eeprom: ");
      float tmpRollTime = loadState(CHILD_ID_SET);
      if (tmpRollTime != 0xff) {
        rollTime = tmpRollTime;
      #ifdef MY_DEBUG
      int state = loadState(CHILD_ID_COVER);
      #ifdef MY_DEBUG
      Serial.println("getting state from eeprom: ");
      Serial.println(String(state));
    //  if (state == 0xff) {
    //    initShutters();
    //  } else {
        currentShutterLevel = state;
        requestedShutterLevel = state;
    void loop(void) {
    #ifdef MY_DEBUG
        sendState();
       // send(msgCode.set('20.0'));
        //    #ifdef MY_DEBUG
        //    Serial.println("Requesting initial value from controller");
        //    #endif
        //    request(CHILD_ID_COVER, V_PERCENTAGE);
        //    wait(2000, C_SET, V_PERCENTAGE);
      debouncerUp.update();
      value = debouncerUp.read();
      if (value == 0 && value != oldValueUp) {
        if(isMoving){
          shuttersHalt();
        else{
        calibrateUp = false;
        calibratedUp = false;
        //state = UP;
        //sendState();
      oldValueUp = value;
      debouncerDown.update();
      value = debouncerDown.read();
      if (value == 0 && value != oldValueDown) {
        if(isMoving){
          shuttersHalt();
        else{
        calibrateDown = false;
        calibratedDown = false;
        //state = DOWN;
        //sendState();
      oldValueDown = value;
    /*  debouncerStop.update();
      value = debouncerStop.read();
      if (value == 0 && value != oldValueStop) {
        shuttersHalt();
        //state = IDLE;
        //sendState();
      oldValueStop = value;
      if(currentShutterLevel != 100)
      if(currentShutterLevel != 0)
      if (isMoving)
        unsigned long _now = millis();
        if (_now - lastLevelTime >= timeOneLevel * 1000) {
          if (directionUpDown == DIRECTION_UP) {
            currentShutterLevel += 1;
          } else {
            currentShutterLevel -= 1;
          currentShutterLevel = constrain(currentShutterLevel, 0, 100);
          #ifdef MY_DEBUG
          Serial.println(String(requestedShutterLevel));
          lastLevelTime = millis();
        if (currentShutterLevel == requestedShutterLevel)
          if(currentShutterLevel == 0 && !calibratedDown)
            if(calibrateDown == false)
              calibrateDown = true;
              calibrationStartTime = _now;
            else
              if(calibratedDown == false)
                if (_now - calibrationStartTime >= calibrationTime * 1000)
                 calibratedDown = true;
          else if (currentShutterLevel == 100 && !calibratedUp)
            if(calibrateUp == false)
              calibrateUp = true;
            else
              if(calibratedUp == false)
                 calibratedUp = true;
          else
            shuttersHalt();
      else
        if (requestedShutterLevel != currentShutterLevel)
          if (requestedShutterLevel > currentShutterLevel) {
            shuttersUp();
          else {
            shuttersDown();
  • Mod
    @pepson did you change the gateway and all your nodes to use the new driver? Nodes with the old driver and the new drivers can not communicate.
    Reference: https://www.mysensors.org/apidocs/group__RFM69SettingGrpPub.html#ga76f4d3c7efe5c6236d5bb90be7c6645d
  • @mfalkvidd
    But on version 2.2.0 all works ok. Only on 2.3.0 is problem...
    Gateway i have on RPI3 build by this:
    1.
    git clone https://github.com/mysensors/MySensors.git --branch master
    cd MySensors
    ./configure --my-transport=rfm69 --my-rfm69-frequency=868 --my-is-rfm69hw --my-gateway=ethernet --my-port=5003 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18
    make
    TESTY
    sudo ./bin/mysgw -d
    sudo make install
    sudo systemctl enable mysgw.service
    sudo systemctl start mysgw.service
    How use new driver in building gateway on RPI3 ?
  • Mod
    RPI gw uses new driver only. I am sticking to 2.2 for now as I had some timing issues with the RPI3, if you make a gw with an arduino it would probably work better with 2.3
  • @gohan
    I want use gateway on RPI because i use special project PCB for gateway on RPI3.
    But on MySensors 2.2.0 i also use NEW DRIVER and all works ok. But why not works on 2.3.0 ?
  • Mod
    If I got it right it is related to RPI3, on RPI2 it should work
  • @gohan
    From where you have this information?
    Is any chance to fix this problem?
  • Mod
    I was talking to @tekka some time ago about the issues I had on 2.3 alpha, I don't know what he did after that.
  • @gohan
    And where we can send issue with this?
  • Mod
    github and if you attach the rfm69 verbose output both for gw and node
  • @gohan
    But how I can download info from gateway and node?
    On github created issue but nothing replay from developers...
  • Mod
    @pepson all core members are helping MySensors when they have free time. Quick replies can happen, but don't count on it. We have as many projects and as little time as you.
  • @mfalkvidd
    OK thanks
  • I run mysgw 2.30 on a RPi 3 Model B and all nodes on 2.20 with RFM69:
    cat /proc/cpuinfo
    Hardware	: BCM2835
    Revision	: a02082
    I did a git pull then configured:
    ./configure --my-transport=rfm69 --my-is-rfm69hw --my-rfm69-frequency=868
    make
    sudo make install
    Note that I don't use LED's or specify gateway. My Controller is Domoticz
    I then started the gateway with debug (note missing -d) (and the log is from today):
    pi@mysensors-gw:~ $ sudo /usr/local/bin/mysgw
    Jun 21 06:36:58 INFO  Starting gateway...
    Jun 21 06:36:58 INFO  Protocol version - 2.3.0
    Jun 21 06:36:58 DEBUG MCO:BGN:INIT GW,CP=RPNGL---,VER=2.3.0
    Jun 21 06:36:58 DEBUG TSF:LRT:OK
    Jun 21 06:36:58 DEBUG TSM:INIT
    Jun 21 06:36:58 DEBUG TSF:WUR:MS=0
    Jun 21 06:36:58 DEBUG TSM:INIT:TSP OK
    Jun 21 06:36:58 DEBUG TSM:INIT:GW MODE
    Jun 21 06:36:58 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
    Jun 21 06:36:58 DEBUG MCO:REG:NOT NEEDED
    Jun 21 06:36:58 DEBUG Listening for connections on 0.0.0.0:5003
    Jun 21 06:36:58 DEBUG MCO:BGN:STP
    Jun 21 06:36:58 DEBUG MCO:BGN:INIT OK,TSP=1
    Jun 21 06:37:18 DEBUG GWT:RFC:C=0,MSG=0;0;3;0;2;
    Jun 21 06:37:18 DEBUG GWT:RFC:C=0,MSG=0;0;3;0;2;Get Version
    Jun 21 06:37:20 DEBUG GWT:RFC:C=0,MSG=0;0;3;0;18;PING
    Jun 21 06:37:30 DEBUG GWT:RFC:C=0,MSG=0;0;3;0;18;PING
    Jun 21 06:37:37 DEBUG TSF:MSG:READ,22-22-0,s=1,c=1,t=0,pt=7,l=5,sg=0:23.3
    Jun 21 06:37:37 DEBUG TSF:MSG:READ,22-22-0,s=2,c=1,t=1,pt=7,l=5,sg=0:48.0
    After the debug check I pressed ctrl-c and started mysgw as a service
    System has been running without any hickup since then.
    If you check the commit 2175c993ef81b78527c85649f5bdc3585d2f41b2 you will notice that -d is removed and some other features has been added.
    git log 2175c993ef81b78527c85649f5bdc3585d2f41b2
    Author: Marcelo Aquino <marceloaqno@users.noreply.github.com>
    Date:   Fri Mar 23 07:00:34 2018 -0300
        Linux: Use config file for gateway settings (#1061)
        - The following settings can be use on the config file:
          - verbose=[debug,info,notice,warn,err] - Logging verbosity.
          - log_file[0|1] - Enable logging to a file.
          - log_filepath=(FILE) - Log file path.
          - log_pipe=[0|1] - Enable logging to a named pipe(aka fifo).
            Use this option to view your gateway's log messages from the
            log_pipe_file (defined below).
            To do so, run the following command on another terminal:
            - $ cat "log_pipe_file"
          - log_pipe_file=(FILE)
          - syslog=[0|1] - Enable logging to syslog.
          - eeprom_file=[/etc/mysensors.eeprom]
          - eeprom_size=[1024]
        - Change some mysgw parameters:
          - Added:
            - -q, --quiet:  for quiet mode, disable log messages written to the
            terminal.
          - Removed:
            - -d, --debug: removed, log messages are now enabled by default.
          - Replaced:
            - -b, --background: replaced by --daemon
        - isatty() is no longer used, log messages by default are printed to
          stderr unless the gateway is started with --quiet (#1022)
        - MY_LINUX_CONFIG_FILE: no longer holds the path to the eeprom file,
          but to the configuration file
    My nodes has these definitions (I don't use New Driver):
    #define   MY_SPLASH_SCREEN_DISABLED
    #define   MY_RFM69_FREQUENCY RFM69_868MHZ
  • @mickecarlsson
    Hi
    But you run gateway on 2.3.0 and node on 2.2.0 without NEW DRIVER and it was working ?
    Even though the gateway has a different version and nodes have a different ?
    All people tell that gateway and nodes must have the same version ?
  • Mod
    There have been versions in the past that were not backward compatible, but usually it is not necessary to have same version on gw and nodes
  • @gohan
    Ok thanks
  • @pepson
    Yes, I run gateway 2.30 and nodes on 2.20 without new driver. No probems.
  • Today i installed Gateway on RPI3 with version 2.3.0 but node has 2.2.0 with NEW_DRIVER and still is problem with communication.
    After come back to home i test it with change version on node to 2.2.0 without NEW_DRIVER.
    I give you and info...
    But tell me on what RPI you have run gateway version 2.3.0 ?
    I have RPI3 version B.
  • @mickecarlsson said in RFM69 new driver delay:
    > cat /proc/cpuinfo
    > Hardware	: BCM2835
    > Revision	: a02082
    Type as above and check the last entries, my RPi is revision a02082
    Se here for more info:
    Raspberry Pi revision codes
  • @mickecarlsson
    It is the same hardware and rev.
    Ok i done test...
    On Gateway on RPI3 i have installed MySensors 2.3.0
    On node i installed version 2.2.0
    One with NEW_DRIVER. Communication with gateway sometimes is ok but still with problem lost communication.
    Second test installed on node 2.2.0 without NEW_DRIVER and it no working. No communicate with gateway.
    Not working NODE. Any reaction to control relay.
    For me only all working when i have MySensors 2.2.0 also on Gateway and also on node with NEW DRIVER option.
    #define RFM69_868MH
    other
  • What kind of antenna do you have on the RPi for the radio? And what kind of antenna do you have on the node?
  • @mickecarlsson
    I have a wire length if I remember 82mm.
  • Just a hunch, add 4 mm to it so that it is 86 mm instead..
    And the power supply for the RPi must be able to provide at leat 1.5 A at 5Volt. Dont go for a cheap powersupply, it wont cope with the power drain from the ROi.
  • @mickecarlsson
    Hi
    my bug lenght antenna is 86mm. Sorry.
    Power for RPI is very good and original raspberry manufacturer provide about 2,5A
    After my tests only on MySensors 2.2.0 on Gateway and on Nodes 2.2.0 with NEW_DRIVER all works ok.
    In other like gateway 2.3.0 and node 2.2.0 or 2.3.0 with NEW_DRIVER or without NEW_DRIVER not working correct.
  • This post is deleted!
  • @kimot
    I dont must use NEW_DRIVER, but when i write sketch to my node without option NEW_DRIVER, it no working. I tested some combination...mix. Gateway 2.3.0 or 2.2.0 with node 2.2.0 and 2.3.0 and Only with NEW_DRIVER works ok and only on 2.2.0 on node and gateway.
    This is my sketch.
    //#define MY_RFM69_FREQUENCY RFM69_868MHZ
    #define RFM69_868MH
    #define RELAY_ON 0
    #define RELAY_OFF 1
    #define SKETCH_VER "2.2"
    int value = 0;
    int oldValueUp = 0;
    bool calibrateDown;
    bool calibrateUp;
    bool calibratedUp;
    enum CoverState {
      STOP,
    void sendState() {
      #ifdef MY_DEBUG
        wait(50);
      isMoving = true;
      coverState = UP;
      sendState();
      #ifdef MY_DEBUG
        wait(50);
      isMoving = true;
      coverState = DOWN;
      sendState();
    #ifdef MY_DEBUG
      isMoving = false;
    #ifdef MY_DEBUG
      coverState = STOP;
      sendState();
        shuttersHalt();
    #ifdef MY_DEBUG
      shuttersUp();
    #ifdef MY_DEBUG
          case V_UP:
            //state = UP;
            //sendState();
            break;
          case V_DOWN:
            //state = DOWN;
            //sendState();
            break;
          case V_STOP:
            shuttersHalt();
            //state = IDLE;
            //sendState();
            break;
          case V_PERCENTAGE:
            //            #ifdef MY_DEBUG
            //            #endif
              per = STATE_UP;
            //sendState();
            break;
          #ifdef MY_DEBUG
          #ifdef MY_DEBUG
    #ifdef MY_DEBUG
      return;
    void before() {
      // Setup the button
    void setup(void) {
      #ifdef MY_DEBUG
      #ifdef MY_DEBUG
      #ifdef MY_DEBUG
    //    initShutters();
    //  } else {
    void loop(void) {
    #ifdef MY_DEBUG
        sendState();
        //    #ifdef MY_DEBUG
        //    #endif
        if(isMoving){
          shuttersHalt();
        else{
        //state = UP;
        //sendState();
      oldValueUp = value;
        if(isMoving){
          shuttersHalt();
        else{
        //state = DOWN;
        //sendState();
        shuttersHalt();
        //state = IDLE;
        //sendState();
      if (isMoving)
          } else {
          #ifdef MY_DEBUG
            else
              calibrateUp = true;
            else
          else
            shuttersHalt();
      else
            shuttersUp();
          else {
            shuttersDown();
  • And is any chance to run gateway on RPI3 but on old default driver not with NEW DRIVER ?
    Anybody has any solution for my problem with communication on version 2.3.0 ?
  • I just checked all my nodes:
    1. Garage - measures temperature/humidity and power usage - uses NEW_DRIVER, Arduino UNO, powered all times.
    2. Storage - measures temperature/humidity and power usage - uses NEW_DRIVER, Arduino UNO powered all times.
    3. Greenhouse - measures temperature/humidity - uses "old" driver, Arduino Pro Mini, battery powered.
    4. Patio - measures temperature/humidity - uses "old" driver, Arduino Pro Mini, battery powered.
    5. Bedroom - measures temperature/humidity - uses "old" driver, Arduino Pro Mini, battery powered.
    6. Kitchen area - measures temperature/humidity - uses "old" driver, Arduino Pro Mini, battery powered.
    My nodes are within 40 meters from the gateway.
    I will no reprogram the node 4 and 5 to use the new driver to see if that makes any difference.
    Node 1 and 2 are the nodes farthest away from the gateway, there is one brick wall and three wood walls between the node and the gateway.
  • @mickecarlsson
    Please also for all points give info what version MySensors use and if you can upload your sketches for all point.
    And Gateway has on RPI3 with version 2.3.0 ? By Serial or ethernet ? And tell me with what controller you use it ? I use with Home Assistant.
    And BTW tell me how long Arduino Mini Pro work for you on battery and what battery you use ... and show your project... Did you remove LED from Arduino to save power battery ?
    In Sketch you measure % power from battery ? And send to controller ? What controller you use ?
    @pepson @mickecarlsson
    in theory, if I remember well, length of antenna should be:
    • 86mm for 868mhz
    • 82mm for 915Mhz
      Better check which frequency you can use where you live.
    Also this is in ideal world, it depends on:
    • antenna material
    • gnd plane size
    • etc
    So when you want to tune your network, you could use a good, 868mhz for example, antenna on gateway (from a reliable supplier, as there are also a lot of unmatched antenna around).
    Then you can try to tune emprically, by checking rssi vs length. Add length or cut, and check. If you need more or less length is dependant on above factors.
    As already said, we don't recommand mixing new driver with older.. As packet has not the same format.
    No eta for fixing rfm69 if issues, too busy for the moment, but we'll try asap.
  • @scalz said in RFM69 new driver delay:
    Yes i have for my radio anntena 86mm.
    On nodes and gateway i am sure that i use freq 868MHz.
    Look on my command to build gateway and on my sketches node.
    On version 2.2.0 i use gateway (as people write by my command i use NEW DRIVER) and also on node also use NEW DRIVER and in this solution all works perfect with no problem.
    When i update gateway and node to 2.3.0 also with NEW DRIVER i have a problem that controll node and connection is no stabilish. In my Home Assistant sometimes i can controll relay but sometimes no reaction on click by Home Assistant. When use on node old driver (but on gateway NEW DRIVER) it is no working. Only on version 2.2.0 on gatewy and node all works perfect.
    Is any chance to build gateway on RPI3 with old driver to RFM69HW ? Because as people write in default building on gateway on RPI3 use NEW DRIVER and we can not change it.... It is true ?
    @pepson
    My comments about tuning antenna were general, it can be useful for optimizing your network.
    I already read what you said previously 😉 It should be normal that new&old driver not working together (unless a recent change..).
    We'll take a look at which changes are incorrect. I'm using experimental local mysensors version, so I'm a bit off topic regarding official release and no time for debugging, for the moment, as like I said we'll try to check that asap.
    Regarding RPI, I'm not using it as gw (I prefer a lower power gw that i can place where i want) so I'm not sure. Take it with a pinch of salt but if i remember, old rfm69 driver spi functions etc are not adapted to linux (whereas new driver is)
    If 2.3 is blocking, do you need a particular fix in 2.3 ? Else you could stick to 2.2
  • OK,
    Here goes what I have:
    Arduino Pro Mini, chinese clones. Regulator and led removed. Soldered on EasyPCB rev 9.
    Radio is RFM69 868 MHz with helicoil antenna on the nodes, 86 mm antenna on the Gateway
    Bootloader is from https://github.com/MCUdude/MiniCore
    The bootloader settings are:
    Board: ATmega328
    Bootloader: Yes
    Variant: 328P / 328PA
    BOD: 1.8v
    Clock: 1MHz internal
    Compiler LTO: Disabled (default)
    On the EasyPCB I have only soldered the radio, the antenna and the Arduino. No booster, no capacitors, no resistors.
    I have put a link on the REG and run the node on two AA batteries.
    The nodes only have one sensor, the BME280.
    The controller I use is Domoticz, latest version (I think).
    I have now reprogrammed some of the nodes to 2.30 and I use NEW_DRIVER.
    Gateway - 2.3.0
    Patio - 2.3.0
    Test-node - 2.3.0
    Kitchen - 2.3.0
    Bedroom - 2.3.0
    UV and LUX - 2.3.0
    No problems at all.
    However, I do not use the receive() function on my nodes.
    And I see that you use the REPEATER setting, if your node can reach the gateway the disable repeater.
  • @mickecarlsson
    Tell me for what you change bootloader ? And i also have clone chine arduino pro mini... I also must change bootloader on this Arduino Pro Mini CLONE CHINA ? Because i dont change bootloader after buy...
    And if you can show also your antenna...and where you buy this antenna ? I try found on Aliexpres but not found.
    But i can not use REPEATER function to to increase the range from the gate - something like the MESH network ?
    And is any chance to you test my SKETCH with relay on your arduino ?
  • You don't ned to change bootloader, I do because I run on battery and it fits my need.
    I can't test your sketch as I don't have the necessary hardware to test it.
    How far apart are your nodes?
    My antenna is from AliExpress
  • @mickecarlsson
    Now my node is very near my Gateway about 6meters. Because now i project my automation in my new home.
    But if you only have Arduino Pro Mini with Radio RFM69HW you can test my sketch. I think that you dont need 2xrelay to test it... Please...
    But for what is function REPEATER ? To increase range from Gateway to very far node ? Then the node with the repeater function extends the range?
    When come back to home i try build node without option REPEATER and try run this...
    Also can you give on priv info how upload this bootloader ? I can only write by ArduinoIDE or i must do other actions ?
  • You only need repeater fi you have a node far away that can’t reach the gateway, then you add repeater on a node nearer the gateway.
    See here: MySensors Network
    And if the node has repeater defined it must allways have power and no Sleep.
    Sorry, I can’t test the sketch.
  • @mickecarlsson
    Can you share me your all sketches ? Thanks
    And tell me how you have connected Gateway to RPI3? By ethernet or by serial ? Because i see in your building Gateway that you dont use parameter ETHERNET on port 5003
    And anybody has any contact to developer @tekka007 ?
    This is info what show in debug on version 2.3.0 gateway and also node on version 2.3.0
    pi@hassbian:~/MySensors $ sudo /usr/local/bin/mysgw
    Jun 22 17:22:49 INFO  Starting gateway...
    Jun 22 17:22:49 INFO  Protocol version - 2.3.0
    Jun 22 17:22:49 DEBUG MCO:BGN:INIT GW,CP=RPNGL---,VER=2.3.0
    Jun 22 17:22:49 DEBUG TSF:LRT:OK
    Jun 22 17:22:49 DEBUG TSM:INIT
    Jun 22 17:22:49 DEBUG TSF:WUR:MS=0
    Jun 22 17:22:49 DEBUG TSM:INIT:TSP OK
    Jun 22 17:22:49 DEBUG TSM:INIT:GW MODE
    Jun 22 17:22:49 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
    Jun 22 17:22:49 DEBUG MCO:REG:NOT NEEDED
    Jun 22 17:22:49 DEBUG Listening for connections on 0.0.0.0:5003
    Jun 22 17:22:49 DEBUG MCO:BGN:STP
    Jun 22 17:22:49 DEBUG MCO:BGN:INIT OK,TSP=1
    Jun 22 17:22:54 DEBUG TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    Jun 22 17:22:54 DEBUG TSF:MSG:BC
    Jun 22 17:22:54 DEBUG TSF:MSG:FPAR REQ,ID=2
    Jun 22 17:22:54 DEBUG TSF:CKU:OK,FCTRL
    Jun 22 17:22:54 DEBUG TSF:MSG:GWL OK
    Jun 22 17:22:54 DEBUG TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=O                 K:0
    Jun 22 17:22:56 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    Jun 22 17:22:56 DEBUG TSF:MSG:PINGED,ID=2,HP=1
    Jun 22 17:22:57 DEBUG TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=                 OK:1
    Jun 22 17:22:57 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    Jun 22 17:22:58 DEBUG TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=                 OK:0100
    Jun 22 17:22:59 DEBUG TSF:MSG:READ,2-2-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.3.0
    Jun 22 17:23:00 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
    Jun 22 17:23:03 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=11,pt=0,l=25,sg=0:1xRelay &                  Button-Sypialni
    Jun 22 17:23:03 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=12,pt=0,l=5,sg=0:2.2.0
    Jun 22 17:23:04 DEBUG TSF:MSG:READ,2-2-0,s=1,c=0,t=3,pt=0,l=0,sg=0:
    Jun 22 17:23:05 DEBUG TSF:MSG:READ,2-2-0,s=1,c=0,t=3,pt=0,l=0,sg=0:
    Jun 22 17:23:05 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
    Jun 22 17:23:06 DEBUG TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
    Jun 22 17:23:07 DEBUG TSF:MSG:READ,2-2-0,s=1,c=1,t=2,pt=2,l=2,sg=0:0
    Jun 22 17:23:08 DEBUG TSF:MSG:READ,2-2-0,s=1,c=1,t=2,pt=2,l=2,sg=0:0
    Jun 22 17:23:08 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=1,pt=0,l=0,sg=0:
    Jun 22 17:23:09 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=1,pt=0,l=0,sg=0:
  • @mickecarlsson I done next test.
    Updated my Gateway on RPI3 to 2.3.0
    Then also update my nodes to 2.3.0
    One node which i use is to control Switch Relay. It works ok also with Repeater function and also without Repeater function.
    Second node is to control cover by relay. It no working correct also with Reapeater and also without Repeater function. Status is not update in the same time. Sometimes no respod reaction on click button.
    Below i see SWITCH releay SKETCH and also to Cover.
    Please help me.
    Also i need help to convert this sketch for Switch 1xRelay to Switch 2x Releay. ANybody can help me. ?
       Relay with button sketch
       modified to work with no uplink
       to gateway and try to maintain sync to controller
    #define MY_DEBUG                               // Enable debug prints to serial monitor
    #define RFM69_868MH
    #define MY_NODE_ID 2                       // Node id defaults to AUTO (tries to fetch id from controller)
    #define MY_TRANSPORT_WAIT_READY_MS 5000        //set how long to wait for transport ready in milliseconds
    #define MY_REPEATER_FEATURE                    // Enabled repeater feature for this node
    #define RELAY_PIN  5      // Arduino Digital I/O pin number for relay
    #define BUTTON_PIN  3     // Arduino Digital I/O pin number for button
    #define CHILD_ID 1        // Id of the sensor child
    #define RELAY_ON 0
    #define RELAY_OFF 1
    Bounce debouncer = Bounce();
    int oldValue = 0;
    bool uplinkAvailable = true;
    bool state = false;
    bool requestState;
    bool firstStart = true;
    unsigned long uplinkCheckTime ;                // holder for uplink checks
    unsigned long uplinkCheckPeriod = 30*1000;     // time between checks for uplink in milliseconds
    unsigned long returnWait = 1000;               // how long to wait for return from controller in milliseconds.. adjust as needed
    unsigned long oldTime = 0;
    unsigned long newTime = 0;
    MyMessage msg(CHILD_ID, V_STATUS);
    void setup(){
      pinMode(BUTTON_PIN, INPUT_PULLUP);           // Setup the button pin, Activate internal pull-up
      debouncer.attach(BUTTON_PIN);                // After setting up the button, setup debouncer
      debouncer.interval(5);
      pinMode(RELAY_PIN, OUTPUT);                 // set relay pin in output mode
      digitalWrite(RELAY_PIN, RELAY_OFF);         // Make sure relay is off when starting up
      send(msg.set(RELAY_OFF), false);           // notify controller to show off state
      sendSketchInfo("1xRelay & Button-Sypialnia", "2.2.0");
      present(CHILD_ID, S_BINARY);
    void loop(){
      if (firstStart) {                            // this code is only run once at startup
        Serial.println("First run started");
        requestTime();                             // get time from controller
        wait (returnWait);                         // delay to allow time to return
        if (oldTime == 0){                         // check to see if there was a return from the time request
          Serial.println("uplink not available");
          uplinkAvailable = false;                 // no uplink established
          uplinkCheckTime = millis();
         else{
          Serial.println("uplink available");
          request( CHILD_ID, V_STATUS);            // get status of switch on controller
          wait (returnWait);                       //wait needed to allow request to return from controller
          Serial.print("controller state --- ");
          Serial.println(requestState);
          if (requestState != state) {             // check that controller is corectly showing the current relay state
            send(msg.set(state), false);           // notify controller of current state
      firstStart = false;                                          // set firstStart flag false to prevent code from running again
      debouncer.update();
      int value = debouncer.read();                               // Get the update value
      if (value != oldValue && value == 0) {                      // check for new button push
        state =  !state;                                          // Toggle the state
        digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF);    // switch the relay to the new state
        requestTime();
        if (oldTime != newTime){                                  // if times are different then uplink is available
          oldTime = newTime;
        else{                                                    // if times are the same no uplink is available
          uplinkAvailable = false;                                // no uplink available, set flag false
          uplinkCheckTime = millis();                             // start the timer from now
      oldValue = value;
      if (!uplinkAvailable && (millis() - uplinkCheckTime > uplinkCheckPeriod) ) {       // test to see if function should be called
        uplinkCheck();        // call uplink checking function
    /*-------------------start of functions--------------------------*/
      if (message.type == V_STATUS) {                                   // check to see if incoming message is for a switch
        switch (message.getCommand()) {                                 // message.getCommand will give us the command type of the incomming message
          case C_SET:                                                   //message is a set command  from controller to update relay state
            state = message.getBool();                                  // get the new state
            digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF);      // switch relay to new state
            send(msg.set(state));
            uplinkAvailable = true;                                     //  uplink established
            /*---- Write some debug info----*/
            Serial.print(message.sensor);
            break;
          case C_REQ:                                               // message is a returning request from controller
            requestState = message.getBool();                       // update requestState with returning state
            break;
    void uplinkCheck() {
        requestTime();
        wait (returnWait);                       // wait for time return.. this may need to be varied for your system
         Serial.println("uplink re-established");
          send(msg.set(state), false);            // notify controller of current state no ack
          oldTime = newTime;
      uplinkCheckTime = millis();                // reset the checktime
      Serial.println("uplinkchecktime reset");
    void receiveTime(unsigned long time)
      if (firstStart){
        oldTime = time;
        newTime = time;
      else{
      newTime = time;
      Serial.print("time received---- " );
      Serial.println(time);
  • // Enable debug prints to serial monitor
    #define RFM69_868MH
    // #define MY_REPEATER_FEATURE
    #define RELAY_ON 0
    #define RELAY_OFF 1
    int value = 0;
    int oldValueUp = 0;
    bool calibrateDown;
    bool calibrateUp;
    bool calibratedUp;
    enum CoverState {
      STOP,
    void sendState() {
      #ifdef MY_DEBUG
        wait(50);
      isMoving = true;
      coverState = UP;
      sendState();
      #ifdef MY_DEBUG
        wait(50);
      isMoving = true;
      coverState = DOWN;
      sendState();
    #ifdef MY_DEBUG
      isMoving = false;
    #ifdef MY_DEBUG
      coverState = STOP;
      sendState();
        shuttersHalt();
    #ifdef MY_DEBUG
      shuttersUp();
    #ifdef MY_DEBUG
          case V_UP:
            //state = UP;
            //sendState();
            break;
          case V_DOWN:
            //state = DOWN;
            //sendState();
            break;
          case V_STOP:
            shuttersHalt();
            //state = IDLE;
            //sendState();
            break;
          case V_PERCENTAGE:
            //            #ifdef MY_DEBUG
            //            #endif
              per = STATE_UP;
            //sendState();
            break;
          #ifdef MY_DEBUG
          #ifdef MY_DEBUG
    #ifdef MY_DEBUG
      return;
    void before() {
      // Setup the button
    void setup(void) {
      #ifdef MY_DEBUG
      #ifdef MY_DEBUG
      #ifdef MY_DEBUG
    //    initShutters();
    //  } else {
    void loop(void) {
    #ifdef MY_DEBUG
        sendState();
        //    #ifdef MY_DEBUG
        //    #endif
        if(isMoving){
          shuttersHalt();
        else{
        //state = UP;
        //sendState();
      oldValueUp = value;
        if(isMoving){
          shuttersHalt();
        else{
        //state = DOWN;
        //sendState();
        shuttersHalt();
        //state = IDLE;
        //sendState();
      if (isMoving)
          } else {
          #ifdef MY_DEBUG
            else
              calibrateUp = true;
            else
          else
            shuttersHalt();
      else
            shuttersUp();
          else {
            shuttersDown();
  • Finally
    In my opinion on MySensors 2.2.0 all my sketches (switch relay and cover ) works better. With no problem. NO PROBLEM.
    Cover works perfect and switch works perfect without any timeout and delay. ANd all node works without REPEATER.
    My opinion is that in version 2.3.0 something not working correct with radio RFM69HW.
    Maybe for sensors which send data from time to time is ok , but for cover which transfer data when cover is roll, it is problem... and gateway can not recived all data when node send position cover. Maybe developer read this thread and can do any changes to correct it.
  • @mickecarlsson
    ANd tell me how you connect Gateway to your Domoticz Controller ? What path to usb or serial you setup in Domoticz ?
    @pepson said in RFM69 new driver delay:
    Like I said, we will take a look as soon as we get time. For the moment, busy (at least on my side). And we're a few, using rfm69.
    So if 2.2 fixes your issue, it can be a good idea.
  • @scalz
    Ok thanks. WAiting for info... and good info for me will be that problem with RFM69HW on version 2.3.0 will be resolve and i can update to this version. Now i must come back to version 2.2.0
  • Mod
    If you don't need specific features in 2.3, then stick to 2.2 that works well.
    Finally
    RFM69W / HW user here. I can confirm that V 2.3.0 on both nodes and PI has some broken. My nodes, stable for 3+ months, with new version they have issues. In detail, they cannot get ACK. In my sketch, I check for ACK when transmitting, to force the watchdog or no. NO ACK received (1 every 20/30) 😞
    And my nodes are "perfect". LifePo4 or AA, someone feeded directly, RPI3 with 2.5a... And I repeat, no issues in 3+ months from switching from NRF to RFM.
  • This is my generic temperature/humidity/battery level sketch that I use. I have upgraded all my nodes and gateway to 2.3.0 yesterday and I don't have any issue whatsoever 🙂
     * This is a sketch I use to measure temperature, humidity and battery level on
     * my Easy/Newbie PCB for MySensors (rev 9)
     * Hardware used:
     * Easy/Newbie PCB for MySensors
     * BME280 (I only use temperature and humidity, all code for barometic pressure removed)
    //#define MY_DEBUG
    #define   MY_SPLASH_SCREEN_DISABLED  // This saves a couple of bytes
    #include <Wire.h>       // Enables the Wire communication protocol.
    // Bosch BME280 Embedded Adventures MOD-1022 weather multi-sensor Arduino code,
    // written originally by Embedded Adventures.
    // https://github.com/embeddedadventures/BME280
    #include <BME280_MOD-1022.h>
    // Internal battery measurement https://github.com/Yveaux/arduino_vcc
    #include <Vcc.h>
    // Change all text variables here, no need to hunt them down in the sketch
    // For sendSketchInfo()
    #define SKETCH_NAME       "Generic Temeperature/Humidity"
    #define SKETCH_VERSION    "1.13"
    // For present()
    #define PRESENT_TEMP_TEXT "Temperature Generic"
    #define PRESENT_HUM_TEXT  "Humidity Generic"
    #define PRESENT_BAT_TEXT  "Batteri Test-3"
    // Battery measurements
    const float VccMin        = 1.8*1.0;  // Min Vcc level, in Volts. Example for 2xAA Alkaline.
    const float VccMax        = 2.0*1.5;  // Max Vcc level, in Volts. Example for 2xAA Alkaline.
    const float VccCorrection = 1.0/1.0;  // Measured Vcc by multimeter divided by reported Vcc
    Vcc vcc(VccCorrection);
    // VARIABLES YOU CAN CHANGE
    // Send temperature only if it has changed? 1 = Yes 0 = No.
    #define COMPARE_TEMP 0
    // Set this value to the minimum change in temperature to measure.
    // BME280 has +-0.5 degrees precision, so it really doesn't matter that much.
    float tempThreshold = 0.5;
    // Send temperature only if changed? 1 = Yes 0 = No.
    #define COMPARE_HUM 0
    // Set this value to the minimum change in humidity to measure.
    // BME280 has +-3% relative humidity precision, so it really doesn't matter that much.
    float humThreshold = 0.5;
    #define TEMP_CHILD_ID       1
    #define HUM_CHILD_ID        2
    #define VOLTAGE_CHILD_ID    3
    float lastTemperature = -1;   // Store previous measurement
    float lastHumidity =    -1;   // Stores the previous measurement
    bool reportRSSI = false;      // true = send RSSI to controller
    int sendBattery = 6;          // report battery level only after 6 loops = 6*4 minutes = 24 minutes
    // Placeholder for batteryloop, set to one above sendBattery so that we get a report on startup
    int batteryLoop = sendBattery + 1;
    // Time between send (in milliseconds), in this case, 4 minutes.
    unsigned long FOUR_MINUTE_SEND_FREQUENCY = 4 * 60000;
    // MYSENSORS COMMUNICATION VARIABLES
    MyMessage temperatureMsg(TEMP_CHILD_ID, V_TEMP);
    MyMessage humidityMsg(HUM_CHILD_ID, V_HUM);
    MyMessage voltageMsg(VOLTAGE_CHILD_ID, V_VOLTAGE);
    #ifdef MY_DEBUG
      Serial.begin(115200);
      Wire.begin(); // For the BME280 sensor
    #ifdef MY_DEBUG
      Serial.println(F("Starting ..."));
      // Present the sensors to the gateway and controller
      present(TEMP_CHILD_ID, S_TEMP, PRESENT_TEMP_TEXT);
      present(HUM_CHILD_ID, S_HUM, PRESENT_HUM_TEXT);
      present(VOLTAGE_CHILD_ID, S_MULTIMETER, PRESENT_BAT_TEXT);
    #ifdef MY_DEBUG
      Serial.println(F("Read BME280 and report it's values."));
      GetTemperatureHumidity();                 // Get temperature and humidity
      if(batteryLoop > sendBattery) {           // Is the batteryLoop higher than sendBattery?
    #ifdef MY_DEBUG
        Serial.println(F("Read the battery voltage and report it."));
        MeasureBattery();                      // Measure and report battery level
        batteryLoop = 0;                       // Reset batteryLoop count
    #ifdef MY_DEBUG
      Serial.print(F("Go to sleep for: "));
      Serial.print(FOUR_MINUTE_SEND_FREQUENCY / 60000);
      Serial.println(F(" minutes."));
      batteryLoop++;                           // Increase batteryLoop before we sleep.
      sleep(FOUR_MINUTE_SEND_FREQUENCY);       // Sleep for 4 minutes
    * GetTemperatureHumidity()
    * Routine for measuring temperature and humidity
    * Generic one that fits my need
    void GetTemperatureHumidity()
    #ifdef MY_DEBUG
      Serial.println("");
      Serial.println(F("BME280 - Requesting new data from sensor module."));
      BME280.readCompensationParams();            // Need to read the NVM compensation parameters.
      // Normal mode for regular automatic samples
      BME280.writeStandbyTime(tsb_0p5ms);         // tsb = 0.5ms
      BME280.writeFilterCoefficient(fc_16);       // IIR Filter coefficient 16
      BME280.writeOversamplingPressure(os16x);    // pressure x16
      BME280.writeOversamplingTemperature(os8x);  // temperature x8
      BME280.writeOversamplingHumidity(os8x);     // humidity x8
      BME280.writeMode(smNormal);
    #ifdef MY_DEBUG
      Serial.println(F("Getting new values"));
      while (BME280.isMeasuring()) {              // Wait for BME280 to fininsh reading data
    #ifdef MY_DEBUG
        Serial.println("Measuring...");
        delay(50);
      Serial.println("Done!");
      // Read out the data - must do this before calling the getxxxxx routines
      BME280.readMeasurements();
      float temperature = BME280.getTemperatureMostAccurate();  // Get the temperature first.
      float humidity = BME280.getHumidityMostAccurate();        // Get the humidity.
    #ifdef MY_DEBUG
      Serial.print(F("BME280 - Temperature = "));
      Serial.print(temperature);
      Serial.println(" °C");
      Serial.print(F("BME280 - Humidity = "));
      Serial.print(humidity);
      Serial.println(F(" %"));
      // Now, let's send the measurements to the gateway.
      // Send temperature if the temperature difference bigger than the threshold
      if (COMPARE_TEMP == 1 && abs(temperature - lastTemperature) < tempThreshold) {
    #ifdef MY_DEBUG
        Serial.print(temperature - lastTemperature);
        Serial.println(F(" Temperature difference too small, don't send it to gateway."));
      } else {
    #ifdef MY_DEBUG
          Serial.println(F("Sending new temperature to the gateway."));
          send(temperatureMsg.set(temperature, 1));
          lastTemperature = temperature; // Save temperatures for compare in the next round.
      // Send humidity if the humidity difference is bigger than the threshold.
      if (COMPARE_TEMP == 1 && abs(humidity - lastHumidity) < humThreshold) {
    #ifdef MY_DEBUG
        Serial.print(humidity - lastHumidity);
        Serial.println(F(" Humidity difference too small, don't send it to the gateway."));
      } else {
    #ifdef MY_DEBUG
        Serial.println(F("BME280 - Sending the new humidity to the gateway."));
        send(humidityMsg.set(humidity, 1));
        lastHumidity = humidity; // Save new humidity to be able to compare in the next round.
    #ifdef MY_DEBUG
      Serial.println(F("BME280 - Measurement complete. Putting sensor to sleep."));
      BME280.writeMode(smSleep);  // set the BME280to sleep mode, save battery
    } // End of GetTemperatureHumidity
    * MeasureBattery()
    * Routine for measuring battery level
    * NOTE: You need to calibrate the measurement to get correct readings
    void MeasureBattery()
      float Vbat = vcc.Read_Volts();
      int batteryPercent = static_cast<int>(vcc.Read_Perc(VccMin, VccMax));
    #ifdef MY_DEBUG
      Serial.print(F("Battery percent: "));
      Serial.print(batteryPercent);
      Serial.println(" %");
      Serial.print(F("Battery Voltage: "));
      Serial.print(Vbat);
      Serial.println(F(" Volts"));
        sendBatteryLevel(batteryPercent);
        send(voltageMsg.set(Vbat,2)); //send battery in Volt 2 decimal places
  • @pepson said in RFM69 new driver delay:
    I use Ethernet to connect to my Domoticz.
    The reason that you don't see my configuration for ETHERNET or PORT is because they are default when you configure.
    If you look at the file Makefile.inc you will see the build options. In my case the file looks like this:
    SOC=BCM2837
    CPPFLAGS=-march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_RFM69 -DMY_RFM69_NEW_DRIVER -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_RFM69_FREQUENCY=RFM69_868MHZ -DMY_IS_RFM69HW
    LDFLAGS=-pthread
    PREFIX=/usr/local
    CC=gcc
    CXX=g++
    BUILDDIR=build
    BINDIR=bin
    GATEWAY_DIR=/usr/local/bin
    INIT_SYSTEM=systemd
    SPI_DRIVER=BCM
    So in my case I have these defines:
    MY_RADIO_RFM69
    MY_RFM69_NEW_DRIVER
    MY_GATEWAY_LINUX
    MY_DEBUG
    LINUX_SPI_BCM
    MY_IS_RFM69HW
  • @mickecarlsson
    You dont have issue becuase temp/hum send data from time to time every defined time.
    My sketch with relay also looks that works ok.
    But problem is on sketch with relay to control covers. WHen cover roll node send still data and it is problem...
    This is my opinion.
    LDFLAGS=-pthread
    Tell me you have BME280 this :
    https://www.aliexpress.com/item/3In1-BME280-GY-BME280-Digital-Sensor-SPI-I2C-Humidity-Temperature-and-Barometric-Pressure-Sensor-Module-1/32847825408.html?spm=2114.search0104.3.1.6d76301deOqjBT&ws_ab_test=searchweb0_0,searchweb201602_3_10152_10151_10065_10344_10068_5722815_10342_10343_10340_5722915_10341_5722615_10696_10084_10083_10618_10304_10307_10820_10301_10821_5722715_10843_10059_306_100031_10103_10624_10623_10622_5722515_10621_10620,searchweb201603_1,ppcSwitch_5&algo_expid=8f90a51c-aded-4f24-a909-68e32bf05b4b-0&algo_pvid=8f90a51c-aded-4f24-a909-68e32bf05b4b&priceBeautifyAB=0
    My defined is the same:
    SOC=BCM2837
    CPPFLAGS=-march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_RFM69 -DMY_RFM69_NEW_DRIVER -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_DEFAULT_TX_LED_PIN=18 -DMY_DEFAULT_RX_LED_PIN=16 -DMY_DEFAULT_ERR_LED_PIN=12 -DMY_PORT=5003 -DMY_IS_RFM69HW -DMY_RFM69_FREQUENCY=RFM69_868MHZ
    LDFLAGS=-pthread
    PREFIX=/usr/local
    CC=gcc
    CXX=g++
    BUILDDIR=build
    BINDIR=bin
    INIT_SYSTEM=systemd
    SPI_DRIVER=BCM
    @pepson
    just to know, when you get this issue, do you send to one shutter only? (because i see you're sending each %, each 200ms). Well we have already did a stress test in the past, one packet each 50-70ms with a dozen of nodes and it worked but that was with a local unoffcial lib, and not with rpi as gw.
    I don't remember if buffer has been implemented in regular branch, for rfm69 (but I think so). And it should work like you said it works with 2.2
    We'll be able retry some stress tests, unfortunately not on rpi as gw (not using this setup), I'm not sure but maybe only marceloaqno may be using rpi with rfm69 (not sure), and we're a very few rfm69 users. Let us check if it's a general problem or rpi as gw only.
    Sorry for disturbance 😉
  • @scalz
    Hmmm
    I am not advanced user. This sketch i found on github from other user. I can change sometinh in sketch to test it ? Can you help me what change in sketch to test ?
    @pepson
    no idea if it will help you, but what i meant is sending less msg .
    I think i recognize some parts of this sketch, not sure 🙂
    So, in your sketch, here you can see it sends at each %
      if (isMoving)
          } else {
          #ifdef MY_DEBUG
    try to change this last line, by:
    if (currentShutterLevel % 5 == 0) send(msgPercentage.set(currentShutterLevel)); // change 5 by 10 if you want to send each 10% for example
    no worry about shutter level update in controller, because when it will stop it will send its level (with sendstate in shutterhalt).
    As your settings in top of sketch is 20sec for a complete roll, then it should send each second instead of 200ms previously (except if you did some calibration), and if i'm not wrong, I quickly read it!
  • @scalz
    Sorry but i dont know what line chage with this your line
    if (currentShutterLevel % 5 == 0) send(msgPercentage.set(currentShutterLevel)); // change 5 by 10 if you want to send each 10% for example```
    @pepson
    I extracted a part of your sketch above. change the last line of the extract
  • @scalz
    Should looks like this ?
    if (isMoving)
          } else {
          #ifdef MY_DEBUG
  • Ok tested as show in previus post. And the same problem. Maybe a little better. But maybe no...
    On 2.2.0 is a very very better.
  • 1
  • 24
  • 10
