[SOLVED] I use serial GW 2.1.1 and my sensor node won't connect
  • I have programmed a Arduino Nano with GW 2.1.1 and my node below is not connecting.
    What I find a bit strange is that my "old" 1.5.4 nodes are connecting to the serial gatewayt and appears in Domoticcz - which I somehow then think I am using old version of gateway version?
    I am using Ubuntu 16.04LTS, Arduino 1.8.5 and Mysensors 2.1.1 according to the library manager.
    My node is an Arduino Pro mini, (as it's a reuse of an old 1.5.4 I have cleared eeprom memory).
    Anyone can help getting further?
    Below is the serial outpout from my node, it seems that it's not find a gateway?
    0 TSM:INIT
    0 TSF:WUR:MS=0
    16 TSM:INIT:TSP OK
    16 TSM:FPAR
    32 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2064 !TSM:FPAR:NO REPLY
    2064 TSM:FPAR
    2080 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4112 !TSM:FPAR:NO REPLY
    4112 TSM:FPAR
    4128 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6160 !TSM:FPAR:NO REPLY
    6160 TSM:FPAR
    6176 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    8208 !TSM:FPAR:FAIL
    8208 TSM:FAIL:CNT=1
    8208 TSM:FAIL:PDT
    18235 TSM:FAIL:RE-INIT
  • I can answer myself as I found this very useful link
    https://www.mysensors.org/build/parser
    No potential parents replied to find parent request, so I assume the gateway isn't adding the node to the network
  • serial output from Gateway
    0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.1
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSF:WUR:MS=0
    0;255;3;0;9;TSM:INIT:TSP OK
    0;255;3;0;9;TSM:INIT:GW MODE
    0;255;0;0;18;2.1.1
    0;255;3;0;9;MCO:BGN:STP
    0;255;3;0;9;TSF:MSG:READ,2-12-0,s=1,c=1,t=13,pt=2,l=2,sg=0:30
    2;1;1;0;13;30
    0;255;3;0;9;!TSF:MSG:LEN,0!=9
    0;255;3;0;9;TSF:MSG:READ,12-12-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;TSF:MSG:BC
    0;255;3;0;9;TSF:MSG:FPAR REQ,ID=12
    0;255;3;0;9;TSF:PNG:SEND,TO=0
    0;255;3;0;9;TSF:CKU:OK
    0;255;3;0;9;TSF:MSG:GWL OK
    0;255;3;0;9;!TSF:MSG:SEND,0-0-12-12,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
  • I just wonder why the gateway isn't accepting and providing a node number to the node?
  • Hardware Contributor
    GW doesn't provide id to nodes, so in this case you need to use static id.
    in case it still don't work, perhaps try a cleareeprom, or dev branch.
    Else it's maybe on hardware side. We ran a few intensive tests with a dozen of nodes yesterday, and it was looking good here but that wasn't the same config (not same mcus, but i had two nrf24 in the equation, plus some others different radios).
    If you can't get it working, could you also upload your sketch please?
  • I only used the template for binary sensor, and added voltage measurement.
    I thought that the node gets an id from gateway? in the "old" 1.5.4 I didn't do anything special to assign node id. I was sure that nodes automatically gets assigned an node id form gateway?
    my sketch below:
     * Interrupt driven binary switch example with dual interrupts
     * Author: Patrick 'Anticimex' Fallberg
     * Connect one button or door/window reed switch between
     * digitial I/O pin 3 (BUTTON_PIN below) and GND and the other
     * one in similar fashion on digital I/O pin 2.
     * This example is designed to fit Arduino Nano/Pro Mini
    #define SKETCH_NAME "Valdemar Binary Sensor"
    #define SKETCH_MAJOR_VER "1"
    #define SKETCH_MINOR_VER "0"
    #define PRIMARY_CHILD_ID 3
    #define SECONDARY_CHILD_ID 4
    #define PRIMARY_BUTTON_PIN 2   // Arduino Digital I/O pin for button/reed switch
    #define SECONDARY_BUTTON_PIN 3 // Arduino Digital I/O pin for button/reed switch
    #if (PRIMARY_BUTTON_PIN < 2 || PRIMARY_BUTTON_PIN > 3)
    #error PRIMARY_BUTTON_PIN must be either 2 or 3 for interrupts to work
    #if (SECONDARY_BUTTON_PIN < 2 || SECONDARY_BUTTON_PIN > 3)
    #error SECONDARY_BUTTON_PIN must be either 2 or 3 for interrupts to work
    #if (PRIMARY_BUTTON_PIN == SECONDARY_BUTTON_PIN)
    #error PRIMARY_BUTTON_PIN and BUTTON_PIN2 cannot be the same
    #if (PRIMARY_CHILD_ID == SECONDARY_CHILD_ID)
    #error PRIMARY_CHILD_ID and SECONDARY_CHILD_ID cannot be the same
    MyMessage msg(PRIMARY_CHILD_ID, V_TRIPPED);
    MyMessage msg2(SECONDARY_CHILD_ID, V_TRIPPED);
    int oldBatteryPcnt = 0;
    	// Setup the buttons
    	pinMode(PRIMARY_BUTTON_PIN, INPUT);
    	pinMode(SECONDARY_BUTTON_PIN, INPUT);
    	// Activate internal pull-ups
    	digitalWrite(PRIMARY_BUTTON_PIN, HIGH);
    	digitalWrite(SECONDARY_BUTTON_PIN, HIGH);
        analogReference(INTERNAL1V1);
      #else
        analogReference(INTERNAL);
    	sendSketchInfo(SKETCH_NAME, SKETCH_MAJOR_VER "." SKETCH_MINOR_VER);
    	// Register binary input sensor to sensor_node (they will be created as child devices)
    	present(PRIMARY_CHILD_ID, S_DOOR);
    	present(SECONDARY_CHILD_ID, S_DOOR);
    	uint8_t value;
    	static uint8_t sentValue=2;
    	static uint8_t sentValue2=2;
    	sleep(5);
    	value = digitalRead(PRIMARY_BUTTON_PIN);
    	if (value != sentValue) {
    		// Value has changed from last transmission, send the updated value
    		send(msg.set(value==HIGH));
    		sentValue = value;
    	value = digitalRead(SECONDARY_BUTTON_PIN);
    	if (value != sentValue2) {
    		send(msg2.set(value==HIGH));
    		sentValue2 = value;
        // get the battery Voltage
      #ifdef MY_DEBUG
        Serial.println(sensorValue);
      #ifdef MY_DEBUG
        float batteryV  = sensorValue * 0.003363075;
        Serial.print(batteryV);
        Serial.println(" V");
        Serial.print(batteryPcnt);
        Serial.println(" %");
            oldBatteryPcnt = batteryPcnt;
    	// Sleep until something happens with the sensor
    	sleep(PRIMARY_BUTTON_PIN-2, CHANGE, SECONDARY_BUTTON_PIN-2, CHANGE, 0);
  • @scalz
    so it might be my Domoticz controller that won't provide a id to the sensor?
    I have tried in Domoticz to "allow new sensors for 5 min" but the sensor wont get an id...
  • @bjacobse I may be completely off the beam here as have not read through it all, and still new at all this, but... Have you enabled "#define MY_INCLUSION_MODE_FEATURE" on the Gateway?
    I read somewhere that this is needed for Domoticz after I could not get a Node to similarly connect.
  • Admin
    @bjacobse
    What does the log in domoticz tell you, when you power up gateway / nodes?
    "old" nodes (pre 2.1'ish) should be able to communicate with a new gateway (2.1), while the opposite is not true (new nodes running 2.1 is not able to connect to an old 1.5 gateway)
    Anyways, check logs on both ends (node, and gateway) to see if there is anything suspicious there..
  • @zboblamont
    I used the "original sketch and only updated the #define MY_RF24_PA_LEVEL RF24_PA_MAX
    * The ArduinoGateway prints data received from sensors on the serial link.
    * The gateway accepts input on seral which will be sent out on radio network.
    * The GW code is designed for Arduino Nano 328p / 16MHz
    * Wire connections (OPTIONAL):
    * - Inclusion button should be connected between digital pin 3 and GND
    * - RX/TX/ERR leds need to be connected between +5V (anode) and digital pin 6/5/4 with resistor 270-330R in a series
    * LEDs (OPTIONAL):
    * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
    // RF24_PA_MIN RF24_PA_LOW RF24_PA_HIGH RF24_PA_MAX
    //#define MY_RF24_PA_LEVEL RF24_PA_HIGH
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
    #if F_CPU == 8000000L
    #define MY_BAUD_RATE 38400
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
  • @tbowmo
    Thank you for the input
    the Domotics log:
    2017-11-14 20:42:04.586 MySensors: Using serial port: /dev/ttyUSB-mysensor
    2017-11-14 20:42:06.075 MySensors: Gateway Ready...
    2017-11-14 20:42:06.150 MySensors: Gateway Version: 2.1.1
    I am not sure how I also get debug/serial info out from the gateway meanwhile it's connected to the RPI that is running the Domoticz server, I will check the forum posts, as I haven't thought of this
  • @bjacobse Ok, not experienced enough to offer any further suggestions as still fumbling my own way,...
    In my own setup it is standardised on RFM69 radio modules, and the Nework ID is defined at the Gateway and Node, the Node ID is defined at the Node.
  • Admin
    @bjacobse
    As a start, you could shut down the domoticz instance, and connect a terminal program directly to your serial port instead. Then power cycle a few nodes, while recording the output from the gateway.
    at the same time, if you could capture the serial output from the power up sequence / first transmission of one of the nodes.
  • @tbowmo
    Thank you Thomas for good ideas 🙂 I will try this when I get time within a few days
  • Gateway startup
    0;255;0;0;18;2.1.1
  • Finally I got it, as I have used same hw configuration for ver1.5.4 as for ver 2.1.1 I did not expect any power issues...
    a hint for debugging in consol mode linux then use screen
    apt-get install screen
    then use like this, note that I use udev to always get Domoticz to use correct ttyUSBx, as I have several USB devices attached attached
    sudo screen /dev/ttyUSB-mysensor 115200
    to kill screen CTRL-a then k and y for confirm
    Then I realised that if I use gateway sketch un-modified it is working, and Domoticz is providing node id, (If Domotics is set to allow new sensors, in settings)
    So when I change on the PA_LEVEL_HIGH or PA_LEVEL_MAX and use more power consumption, apparently the gateway isn't working. I do have a amplified PA RF24L01 moduleboard.
    It's working when set as default PA_LEVEL_LOW
    //#define MY_RF24_PA_LEVEL RF24_PA_MAX
    I might have to look into a power USB hub 😉
    Thank you guys for providing input to solve my issue
  • I too had problems with my GW resetting.
    I use custom designed PCBs with Atmega328p-au using the internal oscillator. With some nodes the GW will reset when I turn them on. Sometimes changing to another NRF-module solved it but this time none of my NRF-modules worked so I searched and found this thread. Flashed the GW with v2.2.0-rc.2 and now all my problems are gone.
  • Hi,
    I've got across similar problem. What works for you doesn't solve problem in my case.
    Decreasing power to PA_LEVEL_LOW or switching to MySensors v2.2.0-rc.2 gives no positive result.
    I have some experience with Arduino, but it is my first try with MySensors and Domoticz.
    If someone could advice how to cope with, thank you in advance.
    My Hardware:
    Arduino Nano, NRF21+ for GW & Node,
    the node is simple actuator: relay with button.
    GW output on Serial monitor:
    0;255;0;0;18;2.1.1
    Node output on Serial Monitor:
    0 MCO:BGN:INIT REPEATER,CP=RNNRA--,VER=2.1.1
    3 TSM:INIT
    4 TSF:WUR:MS=0
    11 TSM:INIT:TSP OK
    13 TSM:FPAR
    15 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2023 !TSM:FPAR:NO REPLY
    2025 TSM:FPAR
    2027 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4035 !TSM:FPAR:NO REPLY
    4037 TSM:FPAR
    4039 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6047 !TSM:FPAR:NO REPLY
    6049 TSM:FPAR
    6051 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    8060 !TSM:FPAR:FAIL
    8061 TSM:FAIL:CNT=1
    8064 TSM:FAIL:PDT
    18067 TSM:FAIL:RE-INIT
    18069 TSM:INIT
    18076 TSM:INIT:TSP OK
    18078 TSM:FPAR
    18080 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    20088 !TSM:FPAR:NO REPLY
    20090 TSM:FPAR
    20092 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    22102 !TSM:FPAR:NO REPLY
    22104 TSM:FPAR
    22106 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    24114 !TSM:FPAR:NO REPLY
    24116 TSM:FPAR
    24118 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    26126 !TSM:FPAR:FAIL
    26127 TSM:FAIL:CNT=2
    26129 TSM:FAIL:PDT
    etc...
    Scratches:
    //Gateway
    #define MY_INCLUSION_MODE_DURATION 120
    Node:
    #define MY_REPEATER_FEATURE
    #include <MyConfig.h>
    #include <Bounce2.h>
    #define RELAY_PIN  4  // Arduino Digital I/O pin number for relay
    #define BUTTON_PIN  5  // Arduino Digital I/O pin number for button
    #define CHILD_ID 10   // Id of the sensor (child)
    #define RELAY_ON 1
    #define RELAY_OFF 0
    Bounce debouncer = Bounce();
    int oldValue=0;
    bool state;
    MyMessage msg(CHILD_ID,V_LIGHT);
      // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Setup debouncer
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      // set relay on when starting up
      pinMode(RELAY_PIN, OUTPUT);
      state=true;
      digitalWrite(RELAY_PIN, RELAY_ON);
    void presentation()  {
      sendSketchInfo("Relay & Button", "1.0");
      present(CHILD_ID, S_LIGHT);
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue && value==0) {
          send(msg.set(state?false:true), true); // Send new state and request ack back
          Serial.println("zmiana value na 0");
          // Change relay state localy, anyway
          state = !state;
          Serial.print("state = ");
          Serial.println(state);
      oldValue = value;
      if (message.isAck()) {
         state = message.getBool();
         // Write some debug info
         Serial.print(message.sensor);
  • @mario64
    Which home automation system are you using?
    If using domoticz, then it's vital to accept new sensors, you find it setup->settings
    Hardware/Devices:
    Accept new Hardware Devices
    if this is disabled, no sensors are allowed to be created
  • Hi @bjacobse,
    thank you for answer. I'm back to my project after e few days.
    Actually, the "Accept new Hardware Devices" switch is on. I also used the "Alow for 5 minutes" button. Let me share more details:
    • pls find log of Domoticz:
     2018-01-22 09:55:34.871 MySensors: retrying in 30 seconds...
    2018-01-22 09:56:00.874 MySensors: Serial Worker stopped...
    2018-01-22 09:56:11.130 New sensors allowed for 5 minutes...
    2018-01-22 09:56:43.077 MySensors: Using serial port: /dev/ttyUSB0
    2018-01-22 10:02:38.123 MySensors: Serial Worker stopped...
    2018-01-22 10:02:39.134 MySensors: Using serial port: /dev/ttyUSB0
    2018-01-22 10:03:38.156 New sensors allowed for 5 minutes...
    2018-01-22 10:04:00.048 Error: Gwx hardware (2) nothing received for more than 1 Minute!....
    2018-01-22 10:04:01.049 Error: Restarting: Gwx
    2018-01-22 10:04:01.146 MySensors: Serial Worker stopped...
    2018-01-22 10:04:02.157 MySensors: Using serial port: /dev/ttyUSB0
    2018-01-22 10:05:30.219 Error: Gwx hardware (2) nothing received for more than 1 Minute!....
    2018-01-22 10:05:31.220 Error: Restarting: Gwx
    2018-01-22 10:05:32.170 MySensors: Serial Worker stopped...
    2018-01-22 10:05:33.181 MySensors: Using serial port: /dev/ttyUSB0
    2018-01-22 10:07:00.204 Error: Gwx hardware (2) nothing received for more than 1 Minute!....
    etc
    • screen shots:
  • @mario64
    one update information (Gateway)
    when I press reset button on Arduino Nano board, I get one additional line on serial monitor:
    0;255;3;0;2;2.1.1
    and on domoticz HW setup screen, I get one children of node with name: S_ARDUINO_REPEATER_NODE. see screenshot:
    ![ ]https://drive.google.com/file/d/1Pjqy7XKA5V9nZYmP90V8hR-pfDy26hc8/view?usp=sharing
  • @mario64
    That is normal, if you use the Log Parser (Search) you will understand the message...
    Domoticz does that with nodes "S_ARDUINO_REPEATER_NODE", no need to worry....
  • maybe trying to use an "older" version for BOTH serial gateway and node. remember for the node to use the special sketch that erases/clear eeprom, as it contains the node id given from the gateway.
    I
    m out of good ideas
  • Thanks. I will try with an older version. If you would share known "mix" of software working together, it would be good to start with. I mean" Arduino IDE/MySensors/Domoticz. ?
  • @zboblamont
    So, gateway works as repeater by default? I also expected that on reset, whole initial sequence should appear, not just 0;255;3;0;2;2.1.1.
  • @mario64 It does not work as a repeater, it registers via Domoticz as a node with a child ID of 255 (Internal effectively) under Setup/Hardware/Nodes, sometimes listed as a Repeater.
    It baffled me originally as I have no repeaters nor a need for them, but that is what Domoticz does. Since you can activate which child sensors are active under Domoticz, you can simply ignore them anyway.
    Not sure if you have figured this out yet without reading back to confirm it, but until you send a sensor reading after presentation the device will not show up within Domoticz and remains in the background....
  • 1
  • 15
  • 24
11.3k
