  3. My Relay Module
My Relay Module
21 Posts 8 Posters 24.7k Views 6 Watching
  • gigiG Offline
    gigiG Offline
    gigi
    I started a project with Mysensors to automate some parts of my home, I made the first gateway with Arduino and an ethernet shield.
    My goal was to have a 220V controlled by Vera Lite.
    What you need:
    -Arduino Nano
    -Radio module NRF24L01 +
    -capacitors
    -resistances
    -breadboard thousand holes
    -Relay Module 10A
    -cables and plugs
    The wiring diagram.
    is important to the condensoatore of VCC and GND of the radio to the stability and the good reception of the same.
    Here's my self-built PCB
    we put it all in a box of Gewiss 8cm x 12 cm
    We insert the power supply
    finally finished work:
    Vera display
    Link code
    Thanks to All
    Vera lite - mysensors Ethernet gateway - AirWik sensor - Relay Module
    • N Offline
      N Offline
      NotYetRated
      Very nice write up! Next add some current sensing ability to see what your load is pulling. :) Although if used for lighting, mostly negligible I suppose haha.
      gigiG 1 Reply Last reply
      • hekH Offline
        hekH Offline
        Nice setup @gigi!
        • N NotYetRated
          gigiG Offline
          gigiG Offline
          gigi
          A non invasive sensor would be ideal. I alredy use energimonitor for solar panels!!!!!
          • N Offline
            N Offline
            Nicola Reina
            Bello GiGi! Nice GiGi.
            If you want pm me as I understand we are from the same country.
            May be we can exchange some experience in italian ;-)
            Will copy your design
            • N Nicola Reina
              gigiG Offline
              gigiG Offline
              gigi
              @Nicola-Reina Ok
              • J Offline
                J Offline
                jemish
                if we put this box in wall then power supply will safe or not?
                5v power supply adapter's temperature will afact or not?
                • D Offline
                  dayve218
                  any one care to confirm whats happening with the AC wires in this? i cant quite make it out from the photos
                  • Michel - ItM Offline
                    Michel - It
                    Hello everyone , I have a problem . maybe it's stupid , I have a server with raspberry domoticz , I downloaded code, but by the following errorCattura.PNG
                    • hekH Offline
                      hekH Offline
                      You seem to have downloaded the development branch of the MySensors library. The code you're trying to run is 1.5.
                        Michel - It
                        wrote on last edited by Michel - It
                        I downloaded this , https://github.com/mysensors/Arduino . I Submitted libraries entirely within the zip file in my briefcase Arduino library.
                        however it from the library is the 1.5 readme. Where am I wrong ?
                        il codice è il seguente
                        #include <Bounce2.h>
                        #define RELAY_PIN 4 // Arduino Digital I/O pin number for relay
                        #define BUTTON_PIN 3 // Arduino Digital I/O pin number for button
                        #define CHILD_ID 1 // Id of the sensor child
                        #define RELAY_ON 1
                        #define RELAY_OFF 0
                        Bounce debouncer = Bounce();
                        int oldValue=0;
                        bool state;
                        MyMessage msg(CHILD_ID,V_LIGHT);
                        gw.sendSketchInfo("Relay & Button", "1.0");
                        // Setup the button
                        pinMode(BUTTON_PIN,INPUT);
                        // Activate internal pull-up
                        debouncer.attach(BUTTON_PIN);
                        debouncer.interval(5);
                        gw.present(CHILD_ID, S_LIGHT);
                        pinMode(RELAY_PIN, OUTPUT);
                        state = gw.loadState(CHILD_ID);
                        * Example on how to asynchronously check for new messages from gw
                        gw.process();
                        debouncer.update();
                        // Get the update value
                        int value = debouncer.read();
                        if (value != oldValue && value==0) {
                        gw.send(msg.set(state?false:true), true); // Send new state and request ack back
                        oldValue = value;
                        if (message.isAck()) {
                        // Change relay state
                        state = message.getBool();
                        // Store state in eeprom
                        gw.saveState(CHILD_ID, state);
                        // Write some debug info
                        Serial.print(message.sensor);
                        • hekH Offline
                          hekH Offline
                          mysensors.org/download/
                            Michel - It
                            thank you! I apologize for my level , I hope to fix with your help.
                              Michel - It
                              Here is the improved code that I used on my Arduino Mega to create a home automation controller
                              New optimized code to arduino mega
                              https://codebender.cc/sketch:206446
                                Michel - It
                                Update: Forget it, the code works with Arduino Mini and 2 relay. I tried one after the code of Arduino Mega and not working. Something wrong but I do not know what I require help
                                I found mistakes on Arduino Mega solvable at the following link
                                http://forum.mysensors.org/topic/2161/the-mysensor-1-5-code-is-not-compiling-for-my-arduino-mega-2560-board/1
                                but I do not have this kind of problem you can get support? I connected NRF24L01 to Arduino Mega, as if it were an Arduino Nano, right?
                                • hekH Offline
                                  hekH Offline
                                  The SPI pins has different pin numbers on the Mega.
                                  Here is an example that runs the the Mega:
                                  http://www.mysensors.org/build/scene_controller
                                    Michel - It
                                    I connected the radio module as follows
                                    AtMega 2650 Arduino Step Down Module/Radio
                                    GND > GND
                                    5V > Step Down module VCC
                                    14 > SCK
                                    15 > MOSI
                                    16 > MISO
                                    17 > CE
                                    18 > CSN
                                    I tried but it did not work I tried to connect also IrQ
                                    2 > IRQ
                                    it did not work. I tried to connect to 3v3 with the capacitor. it did not work. I tried adding the line in the code
                                    #include <MyTransportNRF24.h>
                                    #include <MyHwATMega328.h>
                                    but to no avail. I am groping in the dark
                                    • hekH Offline
                                      hekH Offline
                                      You haven't said what problem you experience. Logs or anything else...
                                        Michel - It
                                        I have "check wires" error on the serial arduino....
                                        where do I fit in debug mode there is a guide?
                                        I saw a video that uses MQTT program on mac.
                                        I have downloaded windows MYSController I can be of help? How do I connect my PC? It is all new and are a little confused. :dizzy_face: :u7a7a:
                                        I "atmega adk" is a problem?
                                        https://www.arduino.cc/en/uploads/Main/ArduinoADK_R3_Front_450px.jpg
                                        • P Offline
                                          P Offline
                                          pjr
                                          Have you defined using softspi since using those pins?
                                          I'm using different pins with mega and everything started to work after adding capacitor to radio:
                                          GND > GND
                                          3.3 > VCC
                                          52 > SCK
                                          51 > MOSI
                                          50 > MISO
                                          9 > CE
                                          10 > CSN
                                          2 > IRQ
                                          11.8k
                                          113.2k
