  3. Plotting graphs with plot.ly service with luup scene using REST API
plot.lygraphluupplot
56 Posts 10 Posters 28.8k Views 2 Watching
  • S Offline
    samppa
    wrote on last edited by samppa
    I have been searching for the easiest graphing solution to see how sensor data behaves and I think I have found it - at least it looks promising.
    After creating plot.ly account create API key in https://plot.ly/settings/api
    Then create scene with following luup that makes the REST API request to upload new the value into the plot.
    So the example here is that I record time series one data point at a time and trigger the scene with 5 minute interval schedule,
    Replace <username>, <APIKey>, <nameForGraph> and <graphTitle> below with your (hard coded) values and the datavelue is of course the sensor data that you want to plot (I plot humidity).
    LUUP CODE:
    local datavalue = luup.variable_get("urn:micasaverde-com:serviceId:HumiditySensor1", "CurrentLevel", 83)
    local http = require("socket.http")
    http.TIMEOUT = 5
    local ts = os.date("%Y-%m-%d %X")
    result, status = http.request("https://plot.ly/clientresp",'un=<username>&key=<APIKey>&origin=plot&platform=lisp&args=[{"x":["'..ts..'"],"y":['..datavalue..']}]&kwargs={"filename":"<nameForGraph>","fileopt":"extend","style":{"type":"scatter"},"traces":[0],"layout":{"title":"<graphTitle>"},"world_readable":false}')
    S 1 Reply Last reply
    • S samppa
      LUUP CODE:
      http.TIMEOUT = 5
      samppa
      Next I would like to plot a value from PLEG condition. But can those be accessed from scene luup code?
      • NuubiN Offline
        NuubiN Offline
        Nuubi
        Excellent, thanks! This is much needed.
        For some reason, can't get this to work...LUA error.
        I'm trying to send MySensors data to Plotly...
        Anyway, does e.g. <username> mean that you write username, or <username> to the script? (Oh yeah, username referring to the actual username :-) )
        • NuubiN Nuubi
          samppa
          @Nuubi
          Yes, the username and API key are shown on the plot.ly api settings page.
          Here is my code that works for 5 lines in one graph and appends data every 5 minutes:
          -- Get variables
          local BRHum = luup.variable_get("urn:micasaverde-com:serviceId:HumiditySensor1", "CurrentLevel", 83)
          local BRTemp = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1", "CurrentTemperature", 84)
          local ACBoost = 100 * luup.variable_get("urn:upnp-org:serviceId:SwitchPower1", "Status", 106)
          local ACMech = 100 * luup.variable_get("urn:upnp-org:serviceId:SwitchPower1", "Status", 107)
          local ACEff = luup.variable_get("urn:upnp-org:serviceId:Dimming1", "LoadLevelStatus", 88    )
          -- Send to plot
          http.TIMEOUT = 5
          result, status = http.request("https://plot.ly/clientresp",'un=<username>&key= <APIKey>&origin=plot&platform=lisp&args=[{"x":["'..ts..'"],"y":['..BRHum..'],"name":"Humidity"},{"x":["'..ts..'"],"y": ['..ACBoost..'],"name":"AC Boost"},{"x":["'..ts..'"],"y":['..BRTemp..'],"name":"Temperature"},{"x":["'..ts..'"],"y":['..ACMech..'],"name":"Mech Sensor"},{"x":["'..ts..'"],"y":['..ACEff..'],"name":"AC Efficiency"}]&kwargs={"filename":"BathroomHumidity","fileopt":"extend","style":{"type":"scatter"},"traces":[0,1,2,3,4],"layout":{"title":"Bathroom Humidity"},"world_readable":false}')
          I know the JSON syntax is cryptic in one line without pretty formatting..
          • korttomaK Offline
            korttomaK Offline
            korttoma
            @samppa this is sweet :+1: . Thank you so much for sharing this!
            • Tomas
            • NuubiN Offline
              NuubiN Offline
              Nuubi
              Uh...oh...still.. do you need to initialize the graph or what? Still not getting this to work, sorry for being such a dummie :-E
              • korttomaK Offline
                korttomaK Offline
                korttoma
                You should use username and not <username>. The same goes for the API key.
                In UI5 you can test your Lua in Vera from APPS -> Develop Apps -> Test Luup code
                Here is a few more examples of variable_get:
                local InAirHum = luup.variable_get("urn:micasaverde-com:serviceId:HumiditySensor1", "CurrentLevel", 347)
                local OutTemp = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 229)
                local InAirTemp = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 346)
                local InAirQ = luup.variable_get("urn:upnp-org:serviceId:VContainer1", "Variable1", 348)
                • Tomas
                • korttomaK Offline
                  korttomaK Offline
                  korttoma
                  I'm having trouble with one variable to. I would like to have the status of a qubino switch in the same graph.
                  I tried this:
                  local VentOn = 100 luup.variable_get("urn:upnp-org:serviceId:BinaryLight1", "Status", 356)
                  It gives me the value 100 in the graph. Please let me know what this 100 in front of the luup.variable_get does. If I remove it the Luup code fails.
                  • Tomas
                  • korttomaK korttoma
                    I tried this:
                    samppa
                    I tried this:
                    Actually there should be asterisk character between 100 and the luup.variable_get and the (forum editor does not show that) since the returned value 1 or 0 is scaled to 100 so try:
                    local VentOn = 100 * luup.variable_get("urn:upnp-org:serviceId:BinaryLight1", "Status", 356)
                    Then you get 100 if binary light is on. Remove the 100 if you like it to be 1 or 0.
                    korttomaK 1 Reply Last reply
                    • NuubiN Nuubi
                      samppa
                      You just send the data and the graph named with "filename":"xxxx" gets created if not yet existing.
                      NuubiN 1 Reply Last reply
                      • S samppa
                        I tried this:
                        korttomaK Offline
                        korttomaK Offline
                        korttoma
                        I thought it was a multiplier of some kind. Anyhow the code fails allso if I add the asterisk so I thik it has a problem with:
                        Any suggestions what I should try instead? Tried also this but no luck:
                        luup.variable_get("urn:micasaverde-com:serviceId:BinaryLight1", "Status", 356)
                        • Tomas
                        • korttomaK Offline
                          korttomaK Offline
                          korttoma
                          Had a chat with @BulldogLowell and he taught me that you can hover the mouse on a variable to check the complete variable name so it turned out I had to use the following:
                          luup.variable_get("urn:micasaverde-com:serviceId:SwitchPower1", "Status", 356)
                          • Tomas
                          • S samppa
                            NuubiN Offline
                            NuubiN Offline
                            Nuubi
                            @samppa Yep, works now, thanks!
                            The problem turned out to be the actual value I wanted to send. Need to figure out how to read MySensors based values in LUA...
                            • NuubiN Nuubi
                              BulldogLowellB Offline
                              BulldogLowell
                              @Nuubi
                              have you tried luup.inet.wget( )
                              local brightness = luup.variable_get("urn:upnp-org:serviceId:Dimming1", "LoadLevelStatus", 118)
                              luup.inet.wget("192.168.1.50//?brightLevel="..brightness.."&", 1)
                              • korttomaK Offline
                                korttomaK Offline
                                korttoma
                                Anyone figured out a way to add another variable to an old graph without deleting the file from plot.ly? Seems like it does not include the new variable unless you delete and create a new file.
                                • Tomas
                                  samppa
                                  I have noticed the same thing; If you want to add a trace you need to delete the file..
                                  So perhaps it is wise to be prepared and add a few extra traces for some future use.
                                  • S samppa
                                    korttomaK Offline
                                    korttomaK Offline
                                    korttoma
                                    Good suggestion for a workaround but it does not seem to pick up name changes for the trace either. Tried also to edit one of the plots on the website but when I wanted to save I could not save the changes to the file used by "Vera". I had to save the file with a different name so no editing seems to be possible.
                                    • Tomas
                                    • korttomaK Offline
                                      korttomaK Offline
                                      korttoma
                                      Since the nightly heal at 2 in the morning no data is transferred to plot.ly any more :( anyone else see this and know how to solv it?
                                      • Tomas
                                      DwaltD 1 Reply Last reply
                                        DwaltD Offline
                                        DwaltD Offline
                                        Dwalt
                                        @korttoma
                                        My plots stopped last night as well, last data point transmitted was at 12:03am GMT, but not after a nightly heal.
                                        -Dwalt
                                        • korttomaK Offline
                                          korttomaK Offline
                                          korttoma
                                          12 GMT is 2 in my timezone so I guess it was just a coincidence that it happened at the time of the heel. Maybe plot.ly blocked us for some reason.
                                          • Tomas
                                          113.2k
