Sending a string in send() - not doing as I want it to do
  • Hi,
    I have this function in my sketch:
    void CheckRSSI()
      char SendingRSSI[10];
      char ReceivingRSSI[10];
      char TxPowerLevel[10];
      char TxPowerPercent[10];
      String sendRSSI;
      itoa(RFM69_getSendingRSSI(), SendingRSSI,10);
      wait(200);
      itoa(RFM69_getReceivingRSSI(), ReceivingRSSI,10);
      wait(200);
      itoa(RFM69_getTxPowerLevel(), TxPowerLevel,10);
      wait(200);
      itoa(RFM69_getTxPowerPercent(), TxPowerPercent,10);
      wait(200);
      // Now, combine all values and send it in
      // Line should look like "T:-90 R:-81 PL:20 PP:100"
      sendRSSI = "T: ";
      sendRSSI.concat(SendingRSSI);
      sendRSSI.concat(" R:");
      sendRSSI.concat(ReceivingRSSI);
      sendRSSI.concat(" PL:");
      sendRSSI.concat(TxPowerLevel);
      sendRSSI.concat(" PP:");
      sendRSSI.concat(TxPowerPercent);
    #ifdef MY_DEBUG
      Serial.print(F("RSSI String: "));
      Serial.println(sendRSSI);
      send(msgRSSI.set(sendRSSI));
    The output is:
    RSSI String: T: -59 R:-51 PL:-2 PP:0
    TSF:MSG:SEND,13-13-0-0,s=1,c=1,t=47,pt=0,l=23,sg=0,ft=0,st=1
    Why does send() only send 1 instead of the string?
    Using 2.2.0-rc.1
  • Mod
    How is msgRSSI created?
  • // Debug
    #define   MY_RADIO_RFM69
    #define   MY_IS_RFM69HW
    #define   MY_RFM69_NEW_DRIVER
    #define   MY_RFM69_FREQUENCY RFM69_868MHZ
    // #define   MY_RFM69_ENABLE_ENCRYPTION
    #define SKETCH_NAME    "Test-text"
    #define SKETCH_VERSION "1.0"
    #define CHILD_ID_RSSI_INFO  1
    // Mysensors settings
    MyMessage msgRSSI(CHILD_ID_RSSI_INFO, V_TEXT);
    void before()
      Serial.begin(115200); // for serial debugging.
      Serial.println(F("Start up sensor."));
      present(CHILD_ID_RSSI_INFO, S_INFO, "RSSI Info");
    #ifdef MY_DEBUG
      Serial.println(F("Starting new measurements"));
      CheckRSSI();
      // Sleep
    #ifdef MY_DEBUG
      Serial.println(F("Waiting 1 minute"));
      wait(60000);
  • Mod
    @mickecarlsson sendSketchInfo is missing. Not sure if that affects anything.
    The presentation call is strange. I haven't seen it used with three paramters before.
    Edit: seems to be my inexperience, so presentation is probably ok.
  • Mod
    @mickecarlsson see if changing
    to
      send(msgRSSI.set(sendRSSI.c_str()));
    helps
  • THANKS!!
    That did it:
    RSSI String: T: 127 R:-49 PL:-2 PP:0
    TSF:MSG:SEND,13-13-0-0,s=1,c=1,t=47,pt=0,l=23,sg=0,ft=0,st=OK:T: 127 R:-49 PL:-2 PP:0
  • Mod
  • 1
  • 24
11.3k
