  3. Vera
  4. UI7
UI7
27 Posts 13 Posters 13.6k Views 4 Watching
  • O Offline
    O Offline
    olaeke
    wrote on last edited by olaeke
    Finally I have got my relay sensor to work with my Vera Edge (UI7) with Ehternet Gateway. The serial doesn't work because the serial port is not working on any Edge, quit amazing they can release a new hardware and "forget" to test the USB device.
    Anyway the device looks a "bit" (understatement) different in UI7 compared to UI5. I'm trying to change the Json code för UI7 so my question is if anyone can provide me with screendumps on MySensors in UI5.
    • greglG Offline
      greglG Offline
      gregl
      @olaeke Cool - i tried many months ago to see if i could work it out (formatting/layout)...but i know little about such things so failed quite quickly.
      There are some UI5 screenshots here: http://www.mysensors.org/controller/vera
      This isnt the only plugin where this is an issue:
      http://forum.micasaverde.com/index.php?topic=30179.0
      this thread may also assist on your quest..
      http://forum.micasaverde.com/index.php/topic,26649.0.html
      O 1 Reply Last reply
      • greglG gregl
        O Offline
        O Offline
        olaeke
        @gregl Yes I have seen the dump on http://www.mysensors.org/controller/vera but how does the setting page looke like in UI5 ?
        • axillentA Offline
          axillentA Offline
          axillent
          do you have any other issues except look&feel?
          I also failed with serial gateway on UI7 and going to build ethernet gateway
          sense and drive
          • axillentA axillent
            O Offline
            O Offline
            olaeke
            @axillent No so far it is only "look and feel", but I have only tested my Relay node
            • O Offline
              O Offline
              olaeke
              I have now modified the json files (and some more) to make the UI better match the UI7. I have moved most of the information to the Settings tab to keep the dashboard clean and hopefully keep the space down. Now it turns out that the "brick" on the dashboard still is ridiculous big (70% whitspace) but i hope this is a bug in UI7 that "Vera Control" will fix (soon...).
              Anyone interested to get the modified files ?
              When I'm "online" i must complain on "Vera Control", what was they thinking on when designed this
              new dashboard? I'm new to Vera so I have only 10 devices so far but I plan for 30-50 devices then
              I think the dashboard (or even the total UI) will be totally useless, it is to much whitespace
              which makes to much scrolling in the UI.
              Here is an example of the result:
              axillentA 1 Reply Last reply
              • O olaeke
                axillentA Offline
                axillentA Offline
                axillent
                @olaeke It will be a good value for the project to have your modification. Are you ready to do commitments to the source repository? It will be good to have a branch for UI7 in the sources
                sense and drive
                • greglG Offline
                  greglG Offline
                  gregl
                  Looks good!.
                  I'm happy to have a look at the files - so pls share.
                  It would also be nice if the front brick ( i like your term) could also show the last update in plain englsh - ie: Tuesday 22:34.10 - i believe the data is available in epoch time...
                  Yes they did make a pretty poor effort on their layout...dont think its going to get any better any time soon.
                  @hek - Any thoughts?
                  Also - have you read this thread? http://forum.micasaverde.com/index.php/topic,28913.0.html
                  • hekH Offline
                    hekH Offline
                    wrote on last edited by hek
                    Great work @olaeke
                    Looks good!
                    Agree on the unused space. Lots of white going on in UI7.
                      O Offline
                      O Offline
                      olaeke
                      @axillent Sure what do I need to place it in the source control? I have an account on GitHub
                      • hekH Offline
                        hekH Offline
                        I've created a UI7-branch.
                        https://github.com/mysensors/Vera/tree/UI7
                        Maybe you could create a pull request on that when you're finished?
                        http://forum.mysensors.org/topic/330/how-to-contribute-code-to-the-mysensors-project
                          O Offline
                          O Offline
                          olaeke
                          @hek Done, I have not used GitHub before (more used to MS Tools) and there was some steps to take to check in but I hope I managed to do it.
                          • greglG Offline
                            greglG Offline
                            gregl
                            Have you guys seen this : http://forum.micasaverde.com/index.php/topic,30310.0/topicseen.html
                            i havent tested it yet, but great there seems a way to make the UI7 more usable!
                            • hekH Offline
                              hekH Offline
                              Ok, a couple of UI7 PRs has been merged here:
                              Testers needed.
                              • F Offline
                                F Offline
                                filipq
                                Just uploaded files to my Vera Lite. Screenshot's below. I'm using Internet Explorer 11. Firefox looks identical.
                                It looks much better.
                                • D Offline
                                  Dany
                                  I have a VeraEdge, but I have with lot of problem.
                                  I'm using an Ethernet gateway, and downloaded the latest Vera plugins and libraries mysensors from Github.
                                  • blaceyB Offline
                                    blaceyB Offline
                                    blacey
                                    Here are the requested screenshots from UI5...
                                    • D Dany
                                      O Offline
                                      O Offline
                                      olaeke
                                      @Dany Can you ping your gateway? Sometimes I have problem that my Ethernet just "die", but after reset on card and Arduino it works again.
                                      D 1 Reply Last reply
                                      • O olaeke
                                        Dany
                                        @olaeke Yes, I can ping the gateway. This board works fine as MQTT gateway with the openhab.
                                        But the library version is 1.4, not 1.4.1. How can I download the libraries 1.4.1?
                                        • A Offline
                                          A Offline
                                          abalazs
                                          @olaeke & @Dany Clumsy is not the problem that the original bootloader to use it? The Ethernet gateway both of us produces the same error. OpenHAB all worked well as MQTT.
                                          11.8k
                                          113.2k
