MyController (Ubuntu) + Ethernet Gateway + Relay Board
  • Hi folks,
    I'm trying to get MyController to see my Ethernet Gateway and the 4xRelay board that's connected to it.
    I can use the relay board with a simple webserver sketch, seperate to mycontroller, so I can only assume that the wiring is correct.
    I can ping the MySensors(2.1.1) Gateway from my laptop and from the ubuntu server.
    I can add the Gatewat to MyController and it shows status as "Connected Successfully" and a nice green tick.
    And this is where I get stuck.
    Either I am not doing something correctly, or for some reason, my relay board isn't showing up/available.
    I am currently using sketches with as little modification as possible, gleaned directly from tutorials etc.
    Any advice greatly appreciated.
    TIA
    Zach
    Sketch Here:
    #define MY_GATEWAY_W5100
    // IP Connection
    #define MY_IP_ADDRESS 10,0,0,201                              // If this is disabled, DHCP is used to retrieve address
    #define MY_PORT 5003                                          // The port to keep open on node server mode / or port to contact in client mode
    #define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED     // MAC Address, can be anything, but must be unique on the network
    // Include the various Libraries
    #include <Ethernet.h>
    // Define relays
    #define RELAY_1  6            // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define NUMBER_OF_RELAYS 4    // Total number of attached relays
    #define RELAY_ON 1            // GPIO value to write to turn on attached relay
    #define RELAY_OFF 0           // GPIO value to write to turn off attached relay
    void before() {
        pinMode(pin, OUTPUT);
      sendSketchInfo("Audry - Gateway w/Relays", "0.1");
        present(sensor, S_LIGHT);
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
         // Write some debug info
         Serial.print(message.sensor);
  • Plugin Developer
    @zachflem Can you see a node 0? Select your gateway and run Discover
  • 17
  • 1
  • 1
  • 9
  • 1
