Help Finding Problem
  • Hardware Contributor
    Hello all, I've been tring finnaly to assemble my mysensors, and I can't get the gateway to work with the node. I installed de MQTT Gateway on a Arduino Nano, I'm using a NRF24L as radio and a W5100 internet module. So I used The GatewayW5100MQTTClient.
    The Gateway is able to gain IP and connect to my MQTT server, I can see the messages and if I publish a message in "mygateway1-in" I can see them in my serial monitot
    When I connect the node to the power I can see a new message on my MQTT server, and a new input on my Gateway serial:
    0;255;3;0;9;TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;TSF:MSG:BC
    0;255;3;0;9;TSF:MSG:FPAR REQ,ID=255
    0;255;3;0;9;TSF:PNG:SEND,TO=0
    0;255;3;0;9;TSF:CKU:OK
    0;255;3;0;9;TSF:MSG:GWL OK
    0;255;3;0;9;TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    0;255;3;0;9;TSF:MSG:READ,255-255-0,s=255,c=3,t=3,pt=0,l=0,sg=0:
    0;255;3;0;9;Sending message on topic: mygateway1-out/255/255/3/0/3
    But in my node I get:
    x00x000 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.1
    4 TSM:INIT
    4 TSF:WUR:MS=0
    12 TSM:INIT:TSP OK
    14 TSM:FPAR
    16 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    36 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    43 TSF:MSG:FPAR OK,ID=0,D=1
    2025 TSM:FPAR:OK
    2025 TSM:ID
    2027 TSM:ID:REQ
    2031 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    4038 TSM:ID
    4038 TSM:ID:REQ
    4042 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    6049 TSM:ID
    6049 TSM:ID:REQ
    6053 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    8062 TSM:ID
    8062 TSM:ID:REQ
    8067 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    10074 !TSM:ID:FAIL
    10076 TSM:FAIL:CNT=1
    10078 TSM:FAIL:PDT
    20082 TSM:FAIL:RE-INIT
    20084 TSM:INIT
    20090 TSM:INIT:TSP OK
    20094 TSM:FPAR
    20097 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    20830 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    20836 TSF:MSG:FPAR OK,ID=0,D=1
    22106 TSM:FPAR:OK
    22108 TSM:ID
    22108 TSM:ID:REQ
    22112 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    24121 TSM:ID
    24121 TSM:ID:REQ
    24125 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    I tried to replace the radios on both, and double checked the connections. I'm using the schematic from https://www.mysensors.org/build/ethernet_gateway on WizNET (W5100) Ethernet module.
    Any ideas?
    Thank You
    Best Regards
    Just to colmplete, my Full Log
    Gateway
    x00x000;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.1
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSF:WUR:MS=0
    0;255;3;0;9;TSM:INIT:TSP OK
    0;255;3;0;9;TSM:INIT:GW MODE
    IP: 192.168.2.30
    0;255;3;0;9;MCO:BGN:STP
    IP: 192.168.2.30
    0;255;3;0;9;MQTT connected
    0;255;3;0;9;Sending message on topic: mygateway1-out/0/255/0/0/18
    0;255;3;0;9;TSF:CKU:OK,FCTRL
    Node
    4 TSM:INIT
    4 TSF:WUR:MS=0
    12 TSM:INIT:TSP OK
    14 TSM:FPAR
    59 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    65 TSF:MSG:FPAR OK,ID=0,D=1
    2025 TSM:FPAR:OK
    2025 TSM:ID
    2027 TSM:ID:REQ
    4038 TSM:ID
    4038 TSM:ID:REQ
    6049 TSM:ID
    6049 TSM:ID:REQ
    8062 TSM:ID
    8062 TSM:ID:REQ
    10074 !TSM:ID:FAIL
    10078 TSM:FAIL:PDT
    20084 TSM:INIT
    20094 TSM:FPAR
    20930 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    20936 TSF:MSG:FPAR OK,ID=0,D=1
    22106 TSM:FPAR:OK
    22108 TSM:ID
    22108 TSM:ID:REQ
    24121 TSM:ID
    24121 TSM:ID:REQ
    26134 TSM:ID
    26134 TSM:ID:REQ
    26138 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    28147 TSM:ID
    28147 TSM:ID:REQ
    28151 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    30162 !TSM:ID:FAIL
    30164 TSM:FAIL:CNT=2
    30167 TSM:FAIL:PDT
    40171 TSM:FAIL:RE-INIT
    40173 TSM:INIT
    40179 TSM:INIT:TSP OK
    40183 TSM:FPAR
    40185 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    40794 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    40800 TSF:MSG:FPAR OK,ID=0,D=1
    42196 TSM:FPAR:OK
    42199 TSM:ID
    42199 TSM:ID:REQ
    42203 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    44212 TSM:ID
    44212 TSM:ID:REQ
    44216 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    46225 TSM:ID
    46225 TSM:ID:REQ
    46229 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    48238 TSM:ID
    48238 TSM:ID:REQ
    48242 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    50251 !TSM:ID:FAIL
    50253 TSM:FAIL:CNT=3
    50255 TSM:FAIL:PDT
    60258 TSM:FAIL:RE-INIT
    60260 TSM:INIT
    60266 TSM:INIT:TSP OK
    60270 TSM:FPAR
    60272 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    62281 !TSM:FPAR:NO REPLY
    62283 TSM:FPAR
    62285 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    62638 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    62644 TSF:MSG:FPAR OK,ID=0,D=1
    64296 TSM:FPAR:OK
    64299 TSM:ID
    64299 TSM:ID:REQ
    64303 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    66312 TSM:ID
    66312 TSM:ID:REQ
    66316 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    68325 TSM:ID
    68325 TSM:ID:REQ
    68329 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    70338 TSM:ID
    70338 TSM:ID:REQ
    70342 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    72351 !TSM:ID:FAIL
    72353 TSM:FAIL:CNT=4
    72355 TSM:FAIL:PDT
    82358 TSM:FAIL:RE-INIT
    82360 TSM:INIT
    82366 TSM:INIT:TSP OK
    82370 TSM:FPAR
    82372 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    84381 !TSM:FPAR:NO REPLY
    84383 TSM:FPAR
    84385 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    84475 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    84482 TSF:MSG:FPAR OK,ID=0,D=1
    86394 TSM:FPAR:OK
    86396 TSM:ID
    86396 TSM:ID:REQ
    86401 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    88410 TSM:ID
    88410 TSM:ID:REQ
    88414 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    90423 TSM:ID
    90423 TSM:ID:REQ
    90427 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    92436 TSM:ID
    92436 TSM:ID:REQ
    92440 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    94449 !TSM:ID:FAIL
    94451 TSM:FAIL:CNT=5
    94453 TSM:FAIL:PDT
    104456 TSM:FAIL:RE-INIT
    104458 TSM:INIT
    104466 TSM:INIT:TSP OK
    104468 TSM:FPAR
    104470 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    105340 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    105347 TSF:MSG:FPAR OK,ID=0,D=1
    106479 TSM:FPAR:OK
    106481 TSM:ID
    106481 TSM:ID:REQ
    106485 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    108494 TSM:ID
    108494 TSM:ID:REQ
    108498 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    110508 TSM:ID
    110508 TSM:ID:REQ
    110512 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    112521 TSM:ID
    112521 TSM:ID:REQ
    112525 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    114534 !TSM:ID:FAIL
    114536 TSM:FAIL:CNT=6
    114538 TSM:FAIL:PDT
    I can get the node to go to the loop method... I think That it will only go when resisted with the GW
  • Mod
    @soloam communication works fine (indicated by ST=ok).
    The node is asking your controller for an ID, but gets no reply (indicated by !TSM:ID:FAIL)
    Most controllers can not hand out IDs over MQTT.
    Most simple solution is to set a static ID on the node by using
    #define MY_NODE_ID
    (reference)
    The log parser can be useful when troubleshooting.
    OH MY GOD... THAT WAS IT =D
    Thank You
    Just one final question... is the approach to MQTT correct or should I stick with simple Ethernet? I was planning on using OpenHab or Home Assistant.
    Thank You all
  • 18
  • 22
  • 1
  • 6
