MQTT with mycontroller, No Connection to Node/Sensor
  • Hi,
    i installed following setup:
    Raspberry Pi 3b with MGTT Gateway (0) and mycontroller installed
    TestSensor ist a humidity sensor dht11 on arduino uno
    Connected with nRF24L01
    I can see with mysgw -d that there are messages from the sensor (255) and they will be published on MQTT.
    With a MQTT Client i can receive this messages (mysensor-out)
    Within mycontroller i can connect to the gatway, but I don't find the right configuration for the node to get it work. I try different things wit ne node is - I think it is 0, but it seems that mxcontroller can't connect. It is not possible for me to get a node and/or sensor working.
    Anybody know's a hint?
    Should the MQTT Broker within mycontroll activeade or deaktivated? Try both 😉 But don't work.
    Regards
    Sven
  • Mod
    You need to post your code of the node and the debug from node and gateway, otherwise we can't help
  • 17
  • 1
  • 1
  • 9
  • 1
