Help in data send to Domoticz
  • Hi
    I'm using arduino UNO gateway + mysensors + Domoticz controller to send and receive data like "DHT", "soil moisture" and "relay state"
    I got problem about reading temp and humidity; both shows in one block and the humidity doesn't update anymore. how can I set them to different blocks?
    and my second problem is about soil moisture sensor, when I want to add "event" to automating relay by soil moisture data, I receive "nil value" error for event and something about global variable.
    this is my code please anyone could help me I'll be grateful.
    thanks in advance.
    #define MY_DEFAULT_LED_BLINK_PERIOD 500
    #define MY_WITH_LEDS_BLINKING_INVERSE
    #define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
    #define MY_DEFAULT_TX_LED_PIN  7  // the PCB, on board LED
    #include <DHT.h>
    DHT dht;
    #define DHTTYPE DHT22
    #define DHT_DATA_PIN 3
    #define SENSOR_TEMP_OFFSET 0
    const int buzzer = 5;
    #define MY_REPEATER_FEATURE
    #define RELAY_PIN 4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define RELAY_ON 0  // GPIO value to write to turn on attached relay
    #define RELAY_OFF 1 // GPIO value to write to turn off attached relay
    #define CHILD_ID_SOIL 3
    MyMessage msg(CHILD_ID_SOIL, V_LEVEL);
    uint32_t SLEEP_TIME = 5000; // Sleep time between reads (in milliseconds)
    int sensorValue;
    int val;
    int soilPin = A0;
    int soilPower = 6;
    #define CHILD_ID_HUM 1
    #define CHILD_ID_TEMP 2
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    static const uint64_t UPDATE_INTERVAL = 5000;
    void before()
    	for (int sensor=1, pin=RELAY_PIN; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
    		pinMode(pin, OUTPUT);
     pinMode(buzzer, OUTPUT);
      pinMode(soilPower, OUTPUT);//Set D6 as an OUTPUT
    digitalWrite(soilPower, LOW);
    		present(sensor, S_BINARY);
        sendSketchInfo("Humidity and Temperature", "1.1");
      present(CHILD_ID_HUM, S_HUM);
      sendSketchInfo("Soil Moisture Sensor", "1.0");
      present(CHILD_ID_SOIL, S_MOISTURE);
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        Serial.println(temperature);
      } else {
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
      } else {
        nNoUpdatesHum++;
      sensorValue = readSoil();
    send(msg.set(sensorValue));
      sleep(UPDATE_INTERVAL);
    	if (message.type==V_STATUS) {
    		// Change relay state
    		digitalWrite(message.sensor-1+RELAY_PIN, message.getBool()?RELAY_ON:RELAY_OFF);
    		// Store state in eeprom
    		// Write some debug info
    		Serial.print(message.sensor);
        tone(buzzer, 850); // Send 1KHz sound signal...
      delay(500);        // ...for 1 sec
      noTone(buzzer);     // Stop sound...
      delay(500);
    int readSoil()
    digitalWrite(soilPower, HIGH);
    delay(10);//wait 10 milliseconds
    val = analogRead(soilPin);
    return val;//send current moisture value
  • Mod
    Do some debug on the node and on gateway and check if data is actually sent from the node and received by gateway. Also use wait instead of sleep if you are using it as a repeater and relay actuator.
  • 5
  • 51
  • 37
  • 11
  • 1
  • 8
  • 7
  • 9
