@tjay4x4 I completely understand.
Until about 3-4 weeks ago I did not even know what an Arduino was.
Yet, here I am creating a plugin for Indigo (I did not know about Indigo until about 8 weeks ago) and creating/testing very basic sensors.
Today I started creating my first 'home-grown' sensor and guess what: You have to try it to understand it
I know from experience that you can ask just about anything when you get stuck...
Well, sure enough we work on sensors but more related to home automation. Industrial automation requires higher quality stuff and usually the sensor types are different.
About other forum start searching "industrial automation forum" there are some coming out, also I bet there are some in your specific country too. Communities are everywhere
Automatic node ID's are now also supported!
There is a step-by-step install guide here:
https://github.com/tsathishkumar/MySController-rs/issues/30
You can easily run this alongside Domoticz.
Burn an image for the Mozilla Gateway onto an SD card.
Follow the guide above to install MySController-rs.
Install Domoticz at port 8081 and 444 (instead of 8080 and 443, as the Mozilla Gateway is already at those ports).
@Yveaux said in serial, Ethernet to MQTT:
Of course, but MySensors MQTT gateway runs just as fine when connected over cabled ethernet, as when connected over wifi
I do not know that
Now on this tool, I do not see much benefit from ethernet to MQTT
Still, it is good from serial to MQTT.
If anyone is interested in trying out the implementation using UDP packets sent to the subnet broadcast address, check out my pull request https://github.com/mysensors/Arduino/pull/66
@hek I have two sensors in my network ( temp , Hum ) and motion detection. both working in auto mode and request node id from controller ( raspberry pi ) node via gateway . but unfortunately, reponse code of both nodes get same node id 1.
may be bug in sendNextAvailableSensorId() function response.
any idea?
thanks
