Temperature sensor sketch only sending battery info to mqtt
  • I have a newbie-pcb board with a Dallas temperature sensor attached. I mixed some sketches together to make it work.
    When starting the sensor the first time I can see all the actions performed. Reading temperature and battery percentage. But than after sleeping it is only reading and sending battery percentage (no voltage)? No temperature action is visible any-more. So, there must be a fault in my sketch which makes it read the temperature part only once? Any advice on this? Thanks.
    [code]
     * Version 1.0: Henrik EKblad
     * Dallas temperature sensor DS18B20
     HTU21D Humidity Sensor
     Hardware Connections (Breakoutboard to Arduino):
     -VCC = 3.3V
     -GND = GND
     -data  = D3 met pcb 470 uf resistor
    #define MY_NODE_ID 4
    #define MY_PARENT_NODE_ID 0
    // Enable debug prints
    //#define MY_RF24_PA_LEVEL RF24_PA_HIGH
    //#define MY_RS485
    //#include <Wire.h>
    #include <OneWire.h>
    // i.e. the sensor would force sending an update every
    //UPDATE_INTERVAL*FORCE_UPDATE_N_READS [ms]
    //static const uint8_t FORCE_UPDATE_N_READS = 10;
    #define COMPARE_TEMP 0 // Send temperature only if changed? 1 = Yes 0 = No
    // arrays to hold device address
    DeviceAddress insideThermometer;
    #define ONE_WIRE_BUS 3 // Pin where dallas sensor is connected
    #define MAX_ATTACHED_DS18B20 1
    int numSensors=0;
    bool receivedConfig = true;
    bool metric = true;
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_BATTERY 2
    #define CHILD_ID_VOLT 3
    //#define CHILD_ID_PRCNT 3
    float lastTemp;
    //float lastHum;
    uint8_t nNoUpdatesTemp;
    //uint8_t nNoUpdatesHum;
    //boolean metric = true;
      sendSketchInfo("Temperature Sensor", "1.1");
    //  present(CHILD_ID_HUM, S_HUM);
       present(CHILD_ID_BATTERY, S_MULTIMETER);
         present(i, S_TEMP);
    //unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)  60000
    static int oldBatteryPcnt = 0;
    //Create an instance of the object
      MyMessage msg(0,V_TEMP);
    //MyMessage msgHum(CHILD_ID_HUM, V_HUM);
    MyMessage msgBattery(CHILD_ID_BATTERY, V_VOLTAGE);
    //MyMessage msgBattery(CHILD_ID_BATTERY, V_PRC);
      sensors.begin();
        analogReference(INTERNAL1V1);
    #else
        analogReference(INTERNAL);
      sleep(conversionTime);
        float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
        #if COMPARE_TEMP == 1
        #else
          send(msg.setSensor(i).set(temperature,1));
    // some delay here
      //delay(500);
       // get the battery Voltage
        delay(500);
    #ifdef MY_DEBUG
        Serial.println(sensorValue);
    #ifdef MY_DEBUG
        float batteryV  = sensorValue * 0.003363075;
        Serial.print("Child ID ");
        Serial.print(CHILD_ID_BATTERY);
        Serial.print(batteryV);
        Serial.println(" V");
        Serial.print("Battery Percent: ");
        Serial.print(batteryPcnt);
        Serial.println(" %");
            // Power up radio after sleep
            oldBatteryPcnt = batteryPcnt;
      sleep(SLEEP_TIME); //sleep a bit
    [/code]```
    This is in the serial monitor:
    [code]```
    16 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.2.0
    26 TSM:INIT
    28 TSF:WUR:MS=0
    34 TSM:INIT:TSP OK
    36 TSM:INIT:STATID=4
    38 TSF:SID:OK,ID=4
    40 TSM:FPAR
    43 TSM:FPAR:STATP=0
    45 TSM:ID
    47 TSM:ID:OK
    47 TSM:UPL
    1730 !TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
    3739 TSM:UPL
    5421 !TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
    7430 TSM:UPL
    7477 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=OK:1
    7497 TSF:MSG:READ,0-0-4,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    7503 TSF:MSG:PONG RECV,HP=1
    7507 TSM:UPL:OK
    7510 TSM:READY:ID=4,PAR=0,DIS=1
    7518 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    7526 TSF:MSG:READ,0-0-4,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    7536 TSF:MSG:SEND,4-4-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.2.0
    7557 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    11247 !TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=11,pt=0,l=18,sg=0,ft=0,st=NACK:Temperature Sensor
    12939 !TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=1,st=NACK:1.1
    14628 !TSF:MSG:SEND,4-4-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=2,st=NACK:
    16318 !TSF:MSG:SEND,4-4-0-0,s=2,c=0,t=30,pt=0,l=0,sg=0,ft=3,st=NACK:
    16324 MCO:REG:REQ
    18010 !TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=4,st=NACK:2
    21698 !TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=5,st=NACK:2
    21706 !TSM:READY:UPL FAIL,STATP
    25389 !TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=NACK:2
    29079 !TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=NACK:2
    31088 MCO:BGN:STP
    31137 MCO:BGN:INIT OK,TSP=1
    31141 MCO:SLP:MS=94,SMS=0,I1=255,M1=255,I2=255,M2=255
    31148 TSF:TDI:TSL
    31150 MCO:SLP:WUP=-1
    31154 TSF:TRI:TSB
    903
    Child ID 2Battery Voltage: 3.04 V
    Battery Percent: 90 %
    31657 !TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=2,st=NACK:90
    31668 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    31674 TSF:TDI:TSL
    31676 MCO:SLP:WUP=-1
    31678 TSF:TRI:TSB
    31682 MCO:SLP:MS=94,SMS=0,I1=255,M1=255,I2=255,M2=255
    31688 TSF:TDI:TSL
    31690 MCO:SLP:WUP=-1
    31692 TSF:TRI:TSB
    831
    Child ID 2Battery Voltage: 2.79 V
    Battery Percent: 83 %
    32202 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=3,st=OK:83
    32208 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    32217 TSF:TDI:TSL```
  • Mod
    First of all there are too many NACKs in the log, meaning you have a serious communication problem and you need to resolve that.
    Battery voltage is not sent because you are only sending battery %
  • @gohan
    Well the NACKS are gone 🙂 by setting the RF_24_PA_HIGH but still I do not get any temperature after the first one while starting up:
    26 TSM:INIT
    28 TSF:WUR:MS=0
    34 TSM:INIT:TSP OK
    38 TSF:SID:OK,ID=4
    40 TSM:FPAR
    43 TSM:FPAR:STATP=0
    45 TSM:ID
    47 TSM:ID:OK
    47 TSM:UPL
    3739 TSM:UPL
    7430 TSM:UPL
    7452 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=OK:1
    7460 TSF:MSG:READ,0-0-4,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    7467 TSF:MSG:PONG RECV,HP=1
    7471 TSM:UPL:OK
    7473 TSM:READY:ID=4,PAR=0,DIS=1
    7491 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    7499 TSF:MSG:READ,0-0-4,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    7512 TSF:MSG:SEND,4-4-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.2.0
    7530 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    9545 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=11,pt=0,l=18,sg=0,ft=0,st=OK:Temperature Sensor
    9586 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
    9801 TSF:MSG:SEND,4-4-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
    9840 TSF:MSG:SEND,4-4-0-0,s=2,c=0,t=30,pt=0,l=0,sg=0,ft=0,st=OK:
    9848 MCO:REG:REQ
    9861 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    9869 TSF:MSG:READ,0-0-4,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    9875 MCO:PIM:NODE REG=1
    9877 MCO:BGN:STP
    9926 MCO:BGN:INIT OK,TSP=1
    911
    Child ID 2Battery Voltage: 3.06 V
    Battery Percent: 91 %
    10438 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:91
    10446 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    10452 TSF:TDI:TSL
    10455 MCO:SLP:WUP=-1
    10457 TSF:TRI:TSB
    831
    10967 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:83
    10975 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    10981 TSF:TDI:TSL
    10983 MCO:SLP:WUP=-1
    10985 TSF:TRI:TSB
    830
    11493 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    11501 TSF:TDI:TSL
    11503 MCO:SLP:WUP=-1
    11505 TSF:TRI:TSB
    833
    Child ID 2Battery Voltage: 2.80 V
    12013 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    12021 TSF:TDI:TSL
    12023 MCO:SLP:WUP=-1
    12025 TSF:TRI:TSB
    830
    12533 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    12541 TSF:TDI:TSL```
  • You seem to send the temp messages under a different ChildID than it is presented:
    presentation takes "1", send uses "0". You have to allign that, e.g. by using
    send(msg.setSensor(i+CHILD_ID_TEMP).set(temperature,1));
    But as long as there's just one DS18B20 doing that dynamically doesn't really make sense. Using the defined message structure (MyMessage msgTemp...) could make things more transparent.
    Also there's no sending command for voltage. So why do you expect the controller to receive also voltage?
  • 16
  • 5
  • 5
  • 8
  • 12
  • 87
18
11.3k
