  3. Backlit Dimmable LED Mirror with Motion Sensor
43 Posts 12 Posters 32.0k Views 14 Watching
  • petewillP Offline
    petewillP Offline
    petewill
    Hi Everyone,
    I have created backlit mirror based on Bruce Lacey's dimmable LED sketch. I have added a motion sensor and some on/off and fade up/down buttons. There is some logic in the code to save the dim level when the buttons are pressed. I have all my motion turn on/off logic in my Vera controller using PLEG. It could be easily adapted to control the on/off functionality in the Arduino code but I like to have my automation logic in one place (my Vera).
    This was a fun project to work on and although it looks pretty ugly from the back my wife loves the way it looks in our master bathroom. I tried to document as best I could but please let me know if you have any questions.
    Here is a list of the parts I used
    • Items from MySensors Store http://www.mysensors.org/store/
      • Female Pin Header Connector Strip
      • Prototype Universal Printed Circuit Boards (PCB)
      • NRF24L01 Radio
      • Arduino Pro Mini
      • FTDI USB to TTL Serial Adapter
      • Capacitors (10uf and .1uf)
      • 3.3v voltage regulator
      • 5v voltage regulator
      • IRLZ44N Logic Level Transistor MOSFET
      • 12v Transformer (power supply)
      • 5 Meter LED Strip (I used 3528)
      • HC-SR501 PIR Motion Sensor Module
    • 22-24 gauge wire or similar (I used Cat5/Cat6 cable)
    • 2 Pole 5mm Pitch PCB Mount Screw Terminal Block
    Here is a video explaining how to build it yourself.
    http://youtu.be/jblaMddRDpc
    Here is the Fritzing (http://fritzing.org/) wiring diagram file if you want to view in more detail: Mirror LED Wiring Diagram.fzz
    https://codebender.cc/sketch:81486
    DwaltD RJ_MakeR H 3 Replies Last reply
    • petewillP petewill
      Hi Everyone,
        • NRF24L01 Radio
        • Arduino Pro Mini
      DwaltD Offline
      DwaltD Offline
      Dwalt
      @petewill
      Nice!
      I am curious about your power supply setup, do you mind sharing? e.g. Are you are running DC line through the attic (or crawlspace) and dropping within the walls? 12VDC? How many feeds, how long are your runs and what gauge wire are you using? I keep looking at my long dormant telephony wiring and wondering "what if...?"
      -Dwalt
      petewillP 1 Reply Last reply
      • DwaltD Dwalt
        @petewill
        Nice!
        -Dwalt
        petewillP Offline
        petewillP Offline
        petewill
        @Dwalt Thanks. Yep, I'm running DC through the walls/attic with 16 and 18 gauge wire (depending on amperage requirements). I think I have around 18 feeds of either 5v or 12v right now. I'm powering lights, blinds and MySensors devices. The longest length of wire is around 60 ft. I am lucky to have access to almost all my rooms via the basement or attic so for the most part it's relatively easy to pull lines.
        What gauge are your phone wires? Depending on gauge you could probably run some low draw sensors like motion, temp/humidity or door/window sensors.
        • FrancoisF Offline
          FrancoisF Offline
          Francois
          wrote on last edited by Francois
          @petewill under what version of mysensor library did you compile this sketch library 1.4 or 1.4.1? I compile you sketch under 1.4.1 and cannot get it to work
          Francois
          petewillP hekH 2 Replies Last reply
          • FrancoisF Francois
            Francois
            petewillP Offline
            petewillP Offline
            petewill
            @Francois I'm still using 1.4.
              Francois
              hekH Offline
              hekH Offline
              What compile error do you see? Did you use 1.4.1 on both GW and sensor?
                Hi Everyone,
                  • NRF24L01 Radio
                  • Arduino Pro Mini
                RJ_MakeR Offline
                RJ_MakeR Offline
                RJ_Make
                @petewill Somehow I missed this.. NICE JOB Pete!! I love it!!
                RJ_Make
                • RJ_MakeR Offline
                  RJ_MakeR Offline
                  RJ_Make
                  @petewill Also what kind of heat are you getting off that FET?
                  RJ_Make
                  • petewillP Offline
                    petewillP Offline
                    petewill
                    @ServiceXp thanks! In my setup I'm not getting any noticeable heat on any of my LED projects. I have run it for hours at 100% and it's not even warm to the touch.
                    • BulldogLowellB Offline
                      BulldogLowell
                      this is one of those "I want one" projects, yes?
                      a lot of cool ways to apply this.
                      • FrancoisF Offline
                        FrancoisF Offline
                        Francois
                        @hek Yes I am using 1.4.1 on both the sensor. This the error I am getting on the sensor node: The sensor was working on a different node it also has cap on VCC and GRD.
                        sensor started, id=25, parent=0, distance=2
                        send: 25-25-0-0 s=255,c=0,t=17,pt=0,l=5,st=fail:1.4.1
                        send: 25-25-0-0 s=255,c=3,t=6,pt=1,l=1,st=fail:0
                        read: 0-0-25 s=255,c=3,t=6,pt=0,l=1:M
                        send: 25-25-0-0 s=0,c=0,t=4,pt=0,l=5,st=fail:1.4.1
                        send: 25-25-0-0 s=1,c=0,t=1,pt=0,l=5,st=fail:1.4.1
                        send: 25-25-0-0 s=255,c=3,t=11,pt=0,l=10,st=fail:Mirror LED
                        lost parent
                        find parent
                        send: 25-25-255-255 s=255,c=3,t=7,pt=0,l=0,st=bc:
                        read: 0-0-25 s=255,c=3,t=8,pt=1,l=1:1
                        new parent=0, d=2
                        • hekH Offline
                          hekH Offline
                          Strange. Looks like distance to gw is 2 but you're actually communicating to it directly.
                          • FrancoisF Offline
                            FrancoisF Offline
                            Francois
                            @hek this is the sketch from about that that copy and recompile on 1.4.1. I did not used the codebender to compile the sketch.
                            This is the serial info on the MQTT Gateway:
                            0;0;3;0;9;read: 25-25-0 s=255,c=0,t=17,pt=0,l=5:1.4.1
                            0;0;3;0;9;read: 25-25-0 s=255,c=3,t=6,pt=1,l=1:0
                            0;0;3;0;9;send: 0-0-25-25 s=255,c=3,t=6,pt=0,l=1,st=ok:M
                            0;0;3;0;9;read: 25-25-0 s=0,c=0,t=4,pt=0,l=5:1.4.1
                            0;0;3;0;9;read: 25-25-0 s=1,c=0,t=1,pt=0,l=5:1.4.1
                            0;0;3;0;9;read: 25-25-0 s=255,c=3,t=11,pt=0,l=10:Mirror LED
                            MyMQTT/25/255/V_SKETCH_NAME
                            30 27 00 1B 4D 79 4D 51 54 54 2F 32 35 2F 32 35 35 2F 56 5F 53 4B 45 54 43 48 5F 4E 41 4D 45 4D 69 72 72 6F 72 20 4C 45 44
                            0;0;3;0;9;read: 25-25-255 s=255,c=3,t=7,pt=0,l=0:
                            0;0;3;0;9;send: 0-0-25-25 s=255,c=3,t=8,pt=1,l=1,st=ok:1
                            0;0;3;0;9;read: 0-25-25 s=255,c=3,t=8,pt=1,l=1:1
                            • FrancoisF Offline
                              FrancoisF Offline
                              Francois
                              Hi I got this sketch to work. There must have being something wrong with MySensor library 1.4.1 once I re-install it and recompile the sketch it is working.
                                petewillP Offline
                                petewillP Offline
                                petewill
                                @Francois Great to hear and thanks for letting us know!
                                • FrancoisF Offline
                                  FrancoisF Offline
                                  Francois
                                  @petewill I add a light sensor to your sketch and this now slow everything down what will the reason for this be? The motion sensor will not always pickup motion. I have another node with light and motion sensor and that is working right.
                                  Here is the code:
                                   * This sketch provides a Dimmable LED Light using PWM and based Henrik Ekblad
                                   * <henrik.ekblad@gmail.com> Vera Arduino Sensor project.
                                   * Developed by Bruce Lacey, inspired by Hek's MySensor's example sketches.
                                   * The circuit uses a MOSFET for Pulse-Wave-Modulation to dim the attached LED or LED strip.
                                   * The MOSFET Gate pin is connected to Arduino pin 3 (MIRROR_LED_PIN), the MOSFET Drain pin is connected
                                   * to the LED negative terminal and the MOSFET Source pin is connected to ground.
                                   * This sketch is extensible to support more than one MOSFET/PWM dimmer per circuit.
                                   * Version 1.0 - February 15, 2014 - Bruce Lacey
                                   * Version 1.1 - February 4, 2014 - Pete B - added buttons to control on/off and dim level and a motion sensor
                                  #define SN "Mirror LED with PIR and LDR"
                                  #define SV "1.2"
                                  #define NODE_ID 50  //change to a number to assign a specific ID
                                  #include <Bounce2.h>
                                  #include <MySigningNone.h>
                                  #include <MyTransportNRF24.h>
                                  #include <MyHwATMega328.h>
                                  #define MIRROR_LED_CHILD 0    //ID of the LED child
                                  #define MOTION_CHILD 1  //ID of the motion sensor child
                                  #define CHILD_ID_LIGHT 2 //ID for LDR sensor
                                  #define LIGHT_SENSOR_ANALOG_PIN 0
                                  #define MIRROR_LED_PIN 3      // Arduino pin attached to MOSFET Gate pin
                                  #define UP_BUTTON_PIN 8  // Arduino Digital I/O pin number for the fade up button
                                  #define DOWN_BUTTON_PIN 7  // Arduino Digital I/O pin number for the fade down button
                                  #define POWER_BUTTON_PIN 4  // Arduino Digital I/O pin number for the power button
                                  #define MOTION_PIN  6  // Arduino pin tied to trigger pin on the motion sensor.
                                  #define FADE_DELAY 10  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
                                  #define FADE_PERCENTAGE 10 //The percentage the fade level will be changed when a button is pressed
                                  MyHwATMega328 hw;
                                  MySensor gw(radio, hw);
                                  //MySensor gw; //Don't need to define pins unless they are changing from the default
                                  static int currentLevel = 0;  // Current dim level...
                                  uint8_t fadeLevel = 0; //used to store the fade level when using the buttons
                                  uint8_t upPreviousValue;
                                  uint8_t downPreviousValue;
                                  uint8_t powerPreviousValue;
                                  Bounce upDebouncer = Bounce();
                                  Bounce downDebouncer = Bounce();
                                  Bounce powerDebouncer = Bounce();
                                  //motion sensor
                                  uint8_t lastMotion = 0;
                                  unsigned long previousMillis = 0; // last time update //see http://stackoverflow.com/questions/10773425/performing-a-function-after-x-time for more details on this
                                  unsigned long motionDelay = 10000; // interval at which to keep motion sensor trippped (milliseconds).  Used to prevent too frequent updates to Vera.
                                  unsigned long upPreviousMillis = 0;
                                  unsigned long downPreviousMillis = 0;
                                  unsigned long buttonFadeDelay = 200;
                                  int lastLightLevel;
                                  boolean metric = true;
                                  MyMessage motionMsg(MOTION_CHILD, V_TRIPPED);
                                  MyMessage dimmerMsg(MIRROR_LED_CHILD, V_DIMMER);
                                  //MyMessage lightMsg(LED_CHILD, V_LIGHT);  removed, updating with dimmer values only
                                   * Dimmable LED initialization method
                                    Serial.println( SN );
                                    gw.begin( incomingMessage,  NODE_ID);
                                    gw.present(MIRROR_LED_CHILD, S_DIMMER );
                                    gw.present(MOTION_CHILD, S_MOTION);
                                    gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL);
                                    gw.sendSketchInfo(SN, SV);
                                     // Setup the button
                                    pinMode(UP_BUTTON_PIN,INPUT);
                                    pinMode(DOWN_BUTTON_PIN,INPUT);
                                    pinMode(POWER_BUTTON_PIN,INPUT);
                                    // Activate internal pull-up
                                    digitalWrite(UP_BUTTON_PIN,HIGH);
                                    digitalWrite(DOWN_BUTTON_PIN,HIGH);
                                    digitalWrite(POWER_BUTTON_PIN,HIGH);
                                    upDebouncer.attach(UP_BUTTON_PIN);
                                    downDebouncer.attach(DOWN_BUTTON_PIN);
                                    powerDebouncer.attach(POWER_BUTTON_PIN);
                                    upDebouncer.interval(5);
                                    downDebouncer.interval(5);
                                    powerDebouncer.interval(5);
                                   *  Dimmable LED main processing loop
                                    //process the LED commands from gateway
                                    gw.process();
                                   int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
                                   // Serial.println(lightLevel);
                                        gw.send(msg.set(lightLevel));
                                        lastLightLevel = lightLevel;
                                    //motion sensor code
                                       if(currentMillis - previousMillis > motionDelay){
                                        uint8_t motionDetect = digitalRead(MOTION_PIN);
                                        if(motionDetect != lastMotion){
                                  //        Serial.print("motionDetect Value: ");
                                  //        Serial.println(motionDetect);
                                          gw.send(motionMsg.set(motionDetect));  // Send tripped value to gw
                                          if(motionDetect == 1){
                                            previousMillis = currentMillis;  //"Tripped" delay
                                          else{
                                            previousMillis = currentMillis - motionDelay + 1000; //"Not tripped" delay for 1 second to stop rapid "not tripped" and "tripped" updates to Vera
                                           lastMotion = motionDetect;
                                  There are 3 buttons attached to the mirror.  One is an on/off button and the other two will fade up/fade down.
                                  The sensor will remember the last fade state and fade the lights to that level next time they are turned on.
                                  If fade up or fade down button is pressed it should store that value into a variable and when the ON button is pressed
                                  it will fade to that previous value.
                                      upDebouncer.update();
                                      // Get the update value
                                      uint8_t upValue = upDebouncer.read();
                                      unsigned long upCurrentMillis = millis();
                                      if(upCurrentMillis - upPreviousMillis > buttonFadeDelay){
                                        if ((upValue == LOW) && (fadeLevel<100)) { //Because of the internal pullup resistors LOW = button is presssed
                                          fadeLevel += FADE_PERCENTAGE;
                                          fadeLevel = fadeLevel > 100 ? 100 : fadeLevel;
                                          fadeToLevel( fadeLevel );
                                        upPreviousMillis = upCurrentMillis;
                                      downDebouncer.update();
                                      uint8_t downValue = downDebouncer.read();
                                      unsigned long downCurrentMillis = millis();
                                      if(downCurrentMillis - downPreviousMillis > buttonFadeDelay){
                                        if ((downValue == LOW) && (fadeLevel>0)) {
                                          fadeLevel -= FADE_PERCENTAGE;
                                          fadeLevel = fadeLevel < 0 ? 0 : fadeLevel;
                                          //powerState = fadeLevel; //Remember fade level for when power button is pressed
                                        downPreviousMillis = downCurrentMillis;
                                      powerDebouncer.update();
                                      uint8_t powerValue = powerDebouncer.read();
                                      if(powerValue != powerPreviousValue){
                                        if (powerValue == LOW) {
                                        Serial.print("Power Button Pressed. fadeLevel is ");
                                        Serial.println(fadeLevel);
                                          if (currentLevel > 0) {
                                            fadeToLevel( 0 );
                                          else{
                                            if (fadeLevel == 0) {
                                              fadeToLevel(50);
                                              fadeLevel = 50;
                                            else{
                                              fadeToLevel(fadeLevel);
                                        powerPreviousValue = powerValue;
                                    if (message.type == V_LIGHT || message.type == V_DIMMER) {
                                      requestedLevel *= ( message.type == V_LIGHT ? 100 : 1 );
                                      // Clip incoming level to valid range of 0 to 100
                                  //    Serial.print( "Changing level to " );
                                  //    Serial.print( requestedLevel );
                                  //    Serial.print( ", from " );
                                  //    Serial.println( currentLevel );
                                      fadeToLevel( requestedLevel );
                                   *  This method provides a graceful fade up/down effect
                                  void fadeToLevel( int toLevel ) {
                                  //  Serial.print("toLevel Value: ");
                                  //  Serial.println(toLevel);
                                  //  Serial.print("currentLevel Value: ");
                                  //  Serial.println(currentLevel);
                                    int delta = ( toLevel - currentLevel ) < 0 ? -1 : 1;
                                    while ( currentLevel != toLevel ) {
                                      currentLevel += delta;
                                      analogWrite( MIRROR_LED_PIN, (int)(currentLevel / 100. * 255) );
                                      delay( FADE_DELAY );
                                    //gw.send(lightMsg.set(currentLevel > 0 ? 1 : 0));  //used to send status of light (on/off) to Vera
                                    gw.send( dimmerMsg.set(currentLevel) );
                                    Here is the code:
                                    #define SV "1.2"
                                    MyHwATMega328 hw;
                                    //motion sensor
                                    int lastLightLevel;
                                       // Setup the button
                                      gw.process();
                                            else{
                                              fadeToLevel( 0 );
                                            else{
                                                fadeToLevel(50);
                                                fadeLevel = 50;
                                              else{
                                    petewillP Offline
                                    petewillP Offline
                                    petewill
                                    @Francois I usually put a "millis" delay for all of my sensors that don't need instant updates (temperature, humidity, light, etc). I have had some of my sensors updating too frequently and causing communication issues for the rest of my sensors. Maybe that's what's happening to you? Try adding some code so the light sensor only updates once per 10 seconds or what ever interval you feel is good. You can use my motion sensor code as an example for adding a delay with millis.
                                      Hi Everyone,
                                        • NRF24L01 Radio
                                        • Arduino Pro Mini
                                      H Offline
                                      H Offline
                                      henno
                                      @petewill Just wanted to let you know that I've built two of these for my daughters but instead of putting them behind a mirror I put it under their bed. Works really good, thanks for sharing!
                                      petewillP hekH DrJeffD 3 Replies Last reply
                                      • H henno
                                        petewillP Offline
                                        petewillP Offline
                                        petewill
                                        @henno Cool idea!
                                        • H henno
                                          hekH Offline
                                          hekH Offline
                                          Scares away all the monsters? :trollface:
                                          113.2k
