  3. MySensors on ATTINY85
attiny
24 Posts 12 Posters 18.7k Views 4 Watching
  • V Offline
    V Offline
    vtento
    wrote on last edited by vtento
    Good night to everybody, I managed to run MySensor in an ATTiny 85 micro.
    Unfortunately, i don't know too much about Arduino Bootloader and how this work,
    then I miss space in program memory...
    Now I can only make a Themperature sensor and I/O device but I miss space for
    configuration program.
    If somebody can help me...
    Thanks and sorry for my bad eglish.
    axillentA 1 Reply Last reply
    • V vtento
      axillentA Offline
      axillentA Offline
      axillent
      @vtento can you explain in other words what kind of problem do you have?
      you could avoid using bootloader and this will save space.
      you also can switch off debugging in Mysensors and save space
      but do not expect too much with Mysensors on 8K FLASH
      it is recommended to have 32k for a sensor
      why you choose atmega85? it is about the same retail price as atmega328
      sense and drive
      • V Offline
        V Offline
        vtento
        I choose ATTINY85 becaus I would like develop a sensor Network small, cheap and easy to make.
        But using an Attiny micro I meet a lot of problem with memory space ....
        For example when I using a DS12B20 temperature sensor I should send value
        without conver in Celsius degrees (I can't divide by 16).
        I would like undestaind how many space use the Arduino bootloader in an Attiny chip
        • hekH Offline
          hekH Offline
          Wow, you got it running on ATTINY85! .
          You could probably strip down the library a few extra bytes by removing all routing functionality.
          • V Offline
            V Offline
            vtento
            I have already taken done to cut any library where possible (serial debug, utility / LowPower) I have already rewrite interrup WDT for sleep mode and pin change...
            Now I can only hope to take some byte from the arduino bootloader, but I don't know how?
            hekH tekkaT 2 Replies Last reply
            • V vtento
              hekH Offline
              hekH Offline
              @vtento
              Pretty hardcore.
              Afraid I can't help you much on the bootloader. Which arduino bootloader are you using. I imagine there are a few out there.
              • hekH Offline
                hekH Offline
                Is there enough pins to even connect the radio? Adding one wire on top of this? How did you do it?
                • V Offline
                  V Offline
                  vtento
                  • V Offline
                    V Offline
                    vtento
                    I share MOSI with 1-WIRE bus, I put in sleep mode the radio, then I read the sensor and after I send the value...
                    Unfortunately I can't use only 3 pin for the radio module because I work with a botton battery (I can't swith off) and I need TX and RX
                    • V vtento
                      axillentA Offline
                      axillentA Offline
                      axillent
                      wrote on last edited by axillent
                      @vtento cool work!
                      make sure to avoid floating numbers. also try to not use 32 bit numbers and limit usage of 16 bit numbers
                      division by 16 is better to do by >> right shift
                      DS18B20 code can be shrinked up to 400-500 bytes while some in examples it is eating 1-2k
                      sense and drive
                      • V vtento
                        tekkaT Offline
                        tekkaT Offline
                        tekka
                        Due to space constraints, I would omit the booloader and use the entire space for the sketch. However, the smallest bootloader is 0.5kb (Optiboot) and if OTA updates are important, then MYSBootloader (2kb). That said, it all depends how much you manage to squeeze the library code.
                        • J Offline
                          J Offline
                          Joseph Macaulay
                          Hi, can you share any of the source code you got running on the ATTiny85? I've got 5 ATTiny85s & 5 ATTiny84s. I've been running the TMRH20 RF24, Network, and Mesh on them, but I wanted to see if I can use the MySensor stuff. Thanks!
                          axillentA V 2 Replies Last reply
                          • J Joseph Macaulay
                            axillentA Offline
                            axillentA Offline
                            axillent
                            @Joseph-Macaulay the version of RF24 is comming with latest MySensor contains a software SPI driver able to work on tiny MCU
                            sense and drive
                            • J Joseph Macaulay
                              V Offline
                              V Offline
                              vtento
                              • @Joseph-Macaulay Hi, this is the sketch that I use for Themp sensor
                              MySensors85.ino
                              • M Offline
                                M Offline
                                mrendu43
                                hello
                                I dont understand why didnt you use reset, and delcare it as input pin?
                                as i know it can be declared as io
                                • SweebeeS Offline
                                  SweebeeS Offline
                                  Sweebee
                                  wrote on last edited by Sweebee
                                  Oitzu and I (testing :P) are currently working on the Attiny support. To test you can download this library (the same as the original one except that it includes the attiny).
                                  Its working so far.
                                  Bugs:
                                  Your node id is the same as child id (if you set a different child id, somehow the attiny ignores it and makes it the same as your node id).
                                  Sleep is working with interrupt but it does the setup again after wake.
                                  Sleep / timer is not yet working.
                                  library: https://github.com/Oitzu/Arduino/tree/master/libraries/MySensors (You can replace it with your existing mysensors library)
                                  example sketch thats working: http://pastebin.com/xRu2JNQ9
                                  wiring:
                                                   1|o   |8  VCC/CE  RED/ORANGE
                                   YELLOW  CSN     2|    |7  SCK     GREEN
                                   -       SENSOR  3|    |6  MOSI    BLUE
                                  BLACK    GND     4|    |5  MISO    VIOLET
                                  T 1 Reply Last reply
                                  • A Offline
                                    A Offline
                                    Andy
                                    Awsome work Oitzu and Sweebee!
                                    Just tried it out and it works perfect :)
                                    Have you succeeded with getting the sleep/timer working? I've tried but discovered that my skills aren't good enough.
                                    mntlvrM 1 Reply Last reply
                                    • SweebeeS Offline
                                      SweebeeS Offline
                                      Sweebee
                                      Not yet. Maybe next week. To much work at school right now ^^. But when it works i'll post it here.
                                      • SweebeeS Sweebee
                                        A Offline
                                        A Offline
                                        Andy
                                        @Sweebee Got it working last night (I hope!), I haven't measured the power consumption yet.
                                        It doesn't have the resolution of ms. To save battery the attiny85 will sleep for 8 seconds, then wake up and go to sleep again. So if you call gw.deep_sleep(7), it will sleep fox 7x8=56 seconds. It is possible to get a more precise timer by calculating the best combination of sleep timers. For example if you want to sleep a minute, sleep 7x8s=56s and then an additional 1x4s=4, total 60s.
                                        It needs some cleaning up and correct naming/commenting/testing e.t.c.
                                        void MySensor::deep_sleep(int time) {
                                        	// Sleep alternatives:
                                        	// 0=16ms, 1=32ms,2=64ms,3=128ms,4=250ms,5=500ms, 6=1 sec,7=2 sec, 8=4 sec, 9= 8sec
                                        	int ii = 9;	// sleep 8 seconds at a time.
                                        	byte bb;
                                        	int ww;
                                        	if (ii > 9 ) ii=9;
                                        	bb=ii & 7;
                                        	if (ii > 7) bb|= (1<<5);
                                        	bb|= (1<<WDCE);
                                        	ww=bb;
                                        	MCUSR &= ~(1<<WDRF);
                                        	// start timed sequence
                                        	WDTCR |= (1<<WDCE) | (1<<WDE);
                                        	// set new watchdog timeout value
                                        	WDTCR = bb;
                                        	WDTCR |= _BV(WDIE);
                                        	// Count some sheeps.
                                        	for(int i=0;i<time;i++) {
                                        		RF24::powerDown();
                                        		cbi(ADCSRA,ADEN);                    // switch Analog to Digitalconverter OFF
                                        		set_sleep_mode(SLEEP_MODE_PWR_DOWN); // sleep mode is set here
                                        		sleep_enable();
                                        		sleep_mode();                        // System actually sleeps here
                                        		sleep_disable();                     // System continues execution here when watchdog timed out
                                        		sbi(ADCSRA,ADEN);                    // switch Analog to Digitalconverter ON
                                        • n3roN Offline
                                          n3roN Offline
                                          n3ro
                                          has someone tested digispark? That would be to test a lot easier.
                                          http://digistump.com/products/1
                                          pimatic + MySensors + Homeduino + z-way
                                          https://github.com/n3roGit/MySensors_n3ro
                                          11.8k
                                          113.2k
