  3. One way on how to reuse 433MHZ alarming sensors for Mysensors
5 Posts 3 Posters 4.6k Views 2 Watching
  • axillentA Offline
    axillentA Offline
    axillent
    wrote on last edited by axillent
    At house I'm having an alarming system with radio 433MHz operated sensors (motion, door, fire etc.).
    Those sensors are one way informers but for many purposes it is fine.
    The sensors I have are compatible with RCSwitch library and any alert is just a 4 bytes ID.
    Just released a prototype. This prototype combines a sensor node with radio retransmitter.
    While recieving ID from 433MHZ I look into EEPROM for a child_id and then resend alert to gateway using NRF24 and Mysensors protocol.
    I have to use two modes of operation, In first mode a first ID received is stored into EEPROM with allocated child_id. Also Mysensors presentation will be send to gateway. In this mode I can register RF433 sensor on the Controller.
    In second mode any ID recieved is resend to gateway while the ID is found in EEPROM with corresponding child_id
    Here is my prototype based on UNO and Humidity sketch. The 433MHZ receiver is attached to it. it is still behaves
    and some video http://www.youtube.com/watch?v=E4ZgnhwedXg
    sense and drive
    • J Offline
      J Offline
      jesper
      It is interesting , it is possible to see the program code
      axillentA 1 Reply Last reply
      • J jesper
        axillentA Offline
        axillentA Offline
        axillent
        @jesper yes, sure. I get problem inserting it here. Is some one can guide me on how to insert the code?
        sense and drive
        • E Offline
          E Offline
          ericvdb
          @axillent if i remember well, you have to indent your code with 4 spaces
          • axillentA Offline
            axillentA Offline
            axillent
            i see a bug, been without a motion events for a while it is stop working
            at the same time it can work for a while in case of motion events
            hmm... fix needed
            but it is just a prototype. I plan to support 4-6 types of sensors (at least types I have with my security system). Currently only motion sensors are supportde (actually any alert sensor can be treated as a motion sensor but it will be better to differentiate)
            double radio transmittion is also not good, will be better to have an ethernet gateway directly working with RF433
            This way I'm connecting very simple RF433 sensors one way (alert is comming from sensor to home controller). Same idea but different hardware and different sketch are needed to soport RF433 relays and wall switches.
            #include <avr/eeprom.h>
            #include <DHT.h>
            #include <RCSwitch.h>
            #define CHILD_ID_HUM 0
            #define CHILD_ID_TEMP 1
            DHT dht;
            float lastTemp;
            float lastHum;
            boolean metric = true;
            RCSwitch mySwitch = RCSwitch();
            #define RF433_CHILDS_MAX	20
            typedef struct {
            	unsigned long	key;
            	uint8_t			child_id;
            } rf433_child_type;
            uint8_t				*eeprom_last_id = (uint8_t*)EEPROM_LOCAL_CONFIG_ADDRESS;
            rf433_child_type	*eeprom_rf433_array = (rf433_child_type*)EEPROM_LOCAL_CONFIG_ADDRESS+1;
            unsigned long dht_period;
              gw.begin();
              mySwitch.enableReceive(0);  // Receiver on inerrupt 0 => that is pin #2
              digitalWrite(5, HIGH);
              gw.sendSketchInfo("Humidity", "1.0");
              if(digitalRead(5)) {
            	Serial.println("-- enetered RF433 init mode");
            	unsigned long t = millis();
            	while(millis() - t < 60000) {
            	  if (mySwitch.available()) {
            		unsigned long key = mySwitch.getReceivedValue();
            		mySwitch.resetAvailable();
            		uint8_t child_id = rf_find_child(key);
            		Serial.print("--- child_id - ");
            		if(child_id == 255) {
            			// key is not presented in EEPROM
            			uint8_t last_id = rf_get_last_id();
            			if(last_id < RF433_CHILDS_MAX) {
            				// a new id should be created
            				rf433_child_type child;
            				// prepare data to be stored in eeprom
            				child.key = key;
            				child.child_id = last_id + 2;
            				eeprom_write_block(&child, &eeprom_rf433_array[last_id], sizeof(child));
            				// store new last_id
            				last_id++;
            				rf_set_last_id(last_id);
            				Serial.print("new ");
            				Serial.println(last_id);
            				gw.present(child.child_id, S_MOTION);
            			} else {
            				// no more space in EEPROM
            				Serial.println("no space");
            		} else {
            			// existing key
            			Serial.println(child_id);
            			gw.present(child_id, S_MOTION);
            		break;
            	Serial.println("-- left RF433 init mode");
            	  // motion event
            	  Serial.print("-- rf key ");
            	  Serial.print(key);
            	  Serial.print(" child_id ");
            	  if(child_id != 255) {
            		  MyMessage msg(child_id, V_TRIPPED);
            		  gw.send(msg.set("1"));  // Send tripped value to gw
            		  delay(2000);
            		  gw.send(msg.set("0"));
              if(dht_period < millis()) {
            	  //delay(dht.getMinimumSamplingPeriod());
            	  if (isnan(temperature)) {
            		lastTemp = temperature;
            		if (!metric) {
            		Serial.print("T: ");
            		Serial.println(temperature);
            	  if (isnan(humidity)) {
            		  lastHum = humidity;
            		  Serial.print("H: ");
            		  Serial.println(humidity);
            	  //gw.sleep(SLEEP_TIME); //sleep a bit
            	  dht_period = millis() + SLEEP_TIME;
            uint8_t rf_get_last_id() {
            	uint8_t x = eeprom_read_byte(eeprom_last_id);
            	if(x == 255) x = 0;
            	return x;
            void rf_set_last_id(uint8_t last_id) {
            	eeprom_write_byte(eeprom_last_id, last_id);
            uint8_t rf_find_child(unsigned long key) {
            	uint8_t id = 0;
            	while(id != last_id) {
            		eeprom_read_block(&child, &eeprom_rf433_array[id], sizeof(child));
            		if(child.key == key) return child.child_id;
            	return 255;
            sense and drive
            11.9k
            113.3k
