Sensors added but no value seems received / interpreted
  • Hi everybdy,
    I am new to both mysensors and Vera but I managed to add my serial gateway to the veralite and my two sensors (connected to the same arduino) are detected and successfully added. But I don't receive any data on the vera.
    When i monitor the sensor serial port, everything seems to be OK:
    send: 1-1-0-0 s=0,c=1,t=1,pt=7,l=5,st=ok:44.0
    H: 44.00
    send: 1-1-0-0 s=1,c=1,t=0,pt=7,l=5,st=ok:13.0
    T: 13.00
    But in Veralite UI, I just see my temperature and humidity sensor with no value (the temperature one only displays "Temperature" and no value, humidity one displays nothing).
    Anybody has an idea to:
    • monitor Vera serial port directly from ssh on vera ?
    • what's happenning on my Veralite ?
      My firmware of vera is: 1.6.641
      In addition, first time I used the device created by the mysensors plugin, I could launch include mode but now i can't since all buttons have disappeared.
      Thanks for your answers
  • Making a SSH connection to Veralite i managed to see the LuaPNP.log and found that a xml file had been corrupted and was not found anymore. Now everything works fine !
11.3k
