Comminucation without controller
  • Sometimes i forgot to plug usb serial and my sensors, relays stoped after 2-3 times what they do normaly. Is there any way if these nodes stop working than reboot itself? Or any idea to keep working?
  • How can i get "fail" to a String from serial monitor?
    send: 51-51-0-0 s=1,c=1,t=2,pt=2,l=2,st=fail:0
  • Admin
    You get a fail if no hw-ack is received from the recipient.
  • @hek Thank you but my goal is to keep it working when there is no controller. My light will not be on or off if there is no controller so i want to add a some code like this;
    re = String(message.sensor);
    if (re.indexOf("fail") >=0)
    asm volatile (" jmp 0"); //reboot
  • Admin
    @C.r.a.z.y.
    Sorry, I don't understand what your setup looks like or what your´re trying to archive.
  • @hek I am using Relay with Button sketch. When there is no controller-no hw-ack, my lights work 2-3 more times and i got "fail" then i can't change the lights state manually.
    When i see "fail" i have to restart the nano.
  • Admin
    The hw ack is handled by the library/radio itself. Controller is not involved.
    So, what is your button sketch communicating with?
  • This Sketch works 1 on and 1 off when there is no controller;
    repeater started, id 0
    send: 0-0-0-0 s=255,c=0,t=18,pt=0,l=5,st=fail:1.4.1
    send: 0-0-0-0 s=255,c=3,t=6,pt=1,l=1,st=fail:0
    send: 0-0-0-0 s=255,c=3,t=11,pt=0,l=5,st=fail:Relay
    send: 0-0-0-0 s=255,c=3,t=12,pt=0,l=3,st=fail:1.0
    send: 0-0-0-0 s=1,c=0,t=3,pt=0,l=5,st=fail:1.4.1
    **send: 0-0-0-0 s=1,c=1,t=2,pt=2,l=2,st=fail:0
    "#include <MySensor.h>
    "#include <SPI.h>
    "#include <Bounce2.h>
    "#define RELAY_1 3 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    "#define NUMBER_OF_RELAYS 1 // Total number of attached relays
    "#define RELAY_ON 1 // GPIO value to write to turn on attached relay
    "#define RELAY_OFF 0 // GPIO value to write to turn off attached relay
    "#define CHILD_ID 1
    "#define TRIGGER_PIN 7 // Arduino pin tied to trigger pin on the ultrasonic sensor.
    unsigned long SLEEP_TIME = 700; // Sleep time between reads (in milliseconds)
    //int hey =50;
    int dist;
    int kac;
    int value;
    int oldValue=0;
    bool state;
    Bounce debouncer = Bounce();
    Bounce debouncer2 = Bounce();
    MyMessage msg(CHILD_ID, V_LIGHT);
    gw.sendSketchInfo("Relay", "1.0");
    gw.present(sensor, S_LIGHT);
    pinMode(pin, OUTPUT);
    state = gw.loadState(CHILD_ID);
    digitalWrite(pin, state?RELAY_ON:RELAY_OFF);
    debouncer.attach(TRIGGER_PIN);
    debouncer2.attach(RELAY_1);
    debouncer.interval(5); debouncer2.interval(5);
    gw.process();
    debouncer.update();
    dist = debouncer.read();
    debouncer2.update();
    kac = debouncer2.read();
    if (dist == 0)
        if(kac==0  ) //MANUAL ON-OFF
         digitalWrite(RELAY_1, HIGH );  // gw.send(msg.set(1));
         delay(1000); //  gw.sleep(SLEEP_TIME);
        else  //MANUAL ON-OFF
          digitalWrite(RELAY_1, LOW );   // gw.send(msg.set(0));
           delay(1000);//  gw.sleep(SLEEP_TIME);
     //NORMAL PROCESS FOR MYSENSORS.h
      if (dist != oldValue && dist==0) {
       gw.send(msg.set(state?false:true), true); // Send new state and request ack back
       oldValue = dist;
    if (message.type==V_LIGHT) {
    // digitalWrite(message.sensor-1+RELAY_1, message.getBool()?RELAY_ON:RELAY_OFF);
    Serial.print(message.sensor);
  • Admin
    Wierd. even if the node loses it's parent it should retry finding a new each time you press the "button" and send a new state.
  • Admin
    There has been a few edge-case bugfixes done recently on github/master.
    Could you just download latest and try the again to check if it has been fixed already?
  • Admin
    You cannot use id=0 for a repeater node.
    Id 0 is reserved for gateway.
  • New master file didn't make difference. When i see "fail" i can't change the state with original RelayWithButtonActuator sketch.
    Ok id is not "0" now.
  • 1
  • 10
  • 15
11.3k
