Ethernet gateway with Homeassistant
  • I read a lot about Ethernet gateway problem with home assistant but i can't catch the reason for my problem as i get a different logs from both gateway and home-assistant i want to establish a connection between gateway and home-assistant using default Ethernet sketch and below configuration in home-assistant:
    mysensors:
    gateways:
    - device: '192.168.1.10'
    tcp_port: 5003
    persistence_file: '/home/homeassistant/.homeassistant/mysensors.json'
    persistence: true
    optimistic: false
    below are the logs from home-assistant:
    2018-11-29 21:12:39 ERROR (MainThread) [mysensors.gateway_tcp] Failed to connect to socket at ('192.168.1.10', 5003)
    2018-11-29 21:12:52 ERROR (MainThread) [mysensors.gateway_tcp] Failed to connect to socket at ('192.168.1.10', 5003)
    2018-11-29 21:13:05 ERROR (MainThread) [mysensors.gateway_tcp] Failed to connect to socket at ('192.168.1.10', 5003)
    2018-11-29 21:13:19 ERROR (MainThread) [mysensors.gateway_tcp] Failed to connect to socket at ('192.168.1.10', 5003)
    2018-11-29 21:13:32 ERROR (MainThread) [mysensors.gateway_tcp] Failed to connect to socket at ('192.168.1.10', 5003)
    also some times i get connection to socket time out.
    below are the logs from serial monitor which there are some of them unknown in Log Parser:
    0 MCO:BGN:INIT GW,CP=RNNGA---,VER=2.3.0
    3 TSM:INIT
    4 TSF:WUR:MS=0
    10 !TSM:INIT:TSP FAIL
    12 TSM:FAIL:CNT=1
    14 TSM:FAIL:DIS
    15 TSF:TDI:TSL
    10018 TSM:FAIL:RE-INIT
    10020 TSM:INIT
    10027 !TSM:INIT:TSP FAIL
    10030 TSM:FAIL:CNT=2
    10031 TSM:FAIL:DIS
    10033 TSF:TDI:TSL
    20036 TSM:FAIL:RE-INIT
    20038 TSM:INIT
  • Mod
    Welcome to the forum @ahmed-amin
    means that the gateway is unable to initialize the transport/radio. You're using the nrf24l01+ radio? Triple-check the wiring and post photos if you can't find any problem. A new pair of eyes is often necessary.
  • Thanks @mfalkvidd i'll check but i also wonder if i can establish and initialize a connection between controller and Ethernet gateway first then attach the sensors and actuators as from home-assistant logs it seems that the connection couldn't establish is it because what you mention.
    very thanks again for your support.
  • Mod
    @ahmed-amin the gateway will only start responding to incoming ethernet connections after it has successfully initialized the radio.
    So either fix the problem, or disable the radio by commenting the line that selects the radio and upload the modified sketch.
  • @mfalkvidd below is modified sketch as you mentioned :
    • The MySensors Arduino library handles the wireless radio link and protocol
    • between your home built sensors/actuators and HA controller of choice.
    • The sensors forms a self healing radio network with optional repeaters. Each
    • repeater and gateway builds a routing tables in EEPROM which keeps track of the
    • network topology allowing messages to be routed to nodes.
    • Created by Henrik Ekblad henrik.ekblad@mysensors.org
    • Copyright (C) 2013-2015 Sensnology AB
    • Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
    • Documentation: http://www.mysensors.org
    • Support Forum: http://forum.mysensors.org
    • This program is free software; you can redistribute it and/or
    • modify it under the terms of the GNU General Public License
    • version 2 as published by the Free Software Foundation.
    • REVISION HISTORY
    • Version 1.0 - Henrik EKblad
    • Contribution by a-lurker and Anticimex,
    • Contribution by Norbert Truchsess norbert.truchsess@t-online.de
    • Contribution by Tomas Hozza thozza@gmail.com
    • DESCRIPTION
    • The EthernetGateway sends data received from sensors to the ethernet link.
    • The gateway also accepts input on ethernet interface, which is then sent out to the radio network.
    • The GW code is designed for Arduino 328p / 16MHz. ATmega168 does not have enough memory to run this program.
    • LED purposes:
      • To use the feature, uncomment MY_DEFAULT_xxx_LED_PIN in the sketch below
      • RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
      • TX (yellow) - blink fast on radio message transmitted. In inclusion mode will blink slowly
      • ERR (red) - fast blink on error during transmission error or receive crc error
    • See http://www.mysensors.org/build/ethernet_gateway for wiring instructions.
    //#define MY_RADIO_NRF24
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    #define MY_GATEWAY_W5100
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    //#if !defined(MY_W5100_SPI_EN) && !defined(ARDUINO_ARCH_SAMD)
    //#define MY_SOFTSPI
    //#define MY_SOFT_SPI_SCK_PIN 14
    //#define MY_SOFT_SPI_MISO_PIN 16
    //#define MY_SOFT_SPI_MOSI_PIN 15
    //#endif
    //#ifndef MY_RF24_CE_PIN
    //#define MY_RF24_CE_PIN 5
    //#endif
    //#ifndef MY_RF24_CS_PIN
    //#define MY_RF24_CS_PIN 6
    //#endif
    // Enable UDP communication
    //#define MY_USE_UDP // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
    #define MY_IP_ADDRESS 192,168,1,10
    #define MY_IP_GATEWAY_ADDRESS 192,168,1,1
    #define MY_PORT 5003
    #define MY_CONTROLLER_IP_ADDRESS 192,168,1,6
    // Note that most of the Arduino examples use "DEAD BEEF FEED" for the MAC address.
    // Enable inclusion mode
    //#define MY_INCLUSION_MODE_BUTTON_PIN 3
    // Set blinking period
    // Flash leds on rx/tx/err
    //#define MY_DEFAULT_ERR_LED_PIN 7 // Error led pin
    //#define MY_DEFAULT_RX_LED_PIN 8 // Receive led pin
    //#define MY_DEFAULT_TX_LED_PIN 9 // Transmit led pin
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
    and next are the logs from serial monitor :
    0 MCO:BGN:INIT GW,CP=R-NGA---,VER=2.3.0
    564 GWT:TIN:IP=192.168.1.10
    1568 !GWT:TIN:ETH FAIL
    1570 MCO:BGN:STP
    1572 MCO:REG:NOT NEEDED
    1574 MCO:BGN:INIT OK,TSP=NA
    1579 !GWT:TSA:ETH FAIL
    1584 !GWT:TSA:ETH FAIL
    1589 !GWT:TSA:ETH FAIL
    1593 !GWT:TSA:ETH FAIL
    1598 !GWT:TSA:ETH FAIL
    1603 !GWT:TSA:ETH FAIL
    1608 !GWT:TSA:ETH FAIL (this keep repeating)
    actually now i can ping to the gateway but still get this from home-assistant logs:
    Dec 01 15:33:09 raspberrypi hass[291]: 2018-12-01 15:33:09 INFO (MainThread) [mysensors.gateway_tcp] Waiting 10.0 secs before trying to connect again
    Dec 01 15:33:19 raspberrypi hass[291]: 2018-12-01 15:33:19 INFO (MainThread) [mysensors.gateway_tcp] Trying to connect to ('192.168.1.10', 5003)
    Dec 01 15:33:29 raspberrypi hass[291]: 2018-12-01 15:33:29 ERROR (MainThread) [mysensors.gateway_tcp] Connecting to socket timed out for ('192.168.1.10', 5003)
    Dec 01 15:33:29 raspberrypi hass[291]: 2018-12-01 15:33:29 INFO (MainThread) [mysensors.gateway_tcp] Waiting 10.0 secs before trying to connect again
    Dec 01 15:33:39 raspberrypi hass[291]: 2018-12-01 15:33:39 INFO (MainThread) [mysensors.gateway_tcp] Trying to connect to ('192.168.1.10', 5003)
    Dec 01 15:33:49 raspberrypi hass[291]: 2018-12-01 15:33:49 ERROR (MainThread) [mysensors.gateway_tcp] Connecting to socket timed out for ('192.168.1.10', 5003)
    Dec 01 15:33:49 raspberrypi hass[291]: 2018-12-01 15:33:49 INFO (MainThread) [mysensors.gateway_tcp] Waiting 10.0 secs before trying to connect again
    Dec 01 15:33:59 raspberrypi hass[291]: 2018-12-01 15:33:59 INFO (MainThread) [mysensors.gateway_tcp] Trying to connect to ('192.168.1.10', 5003)
    Dec 01 15:34:09 raspberrypi hass[291]: 2018-12-01 15:34:09 ERROR (MainThread) [mysensors.gateway_tcp] Connecting to socket timed out for ('192.168.1.10', 5003)
    Dec 01 15:34:09 raspberrypi hass[291]: 2018-12-01 15:34:09 INFO (MainThread) [mysensors.gateway_tcp] Waiting 10.0 secs before trying to connect again
    Dec 01 15:34:19 raspberrypi hass[291]: 2018-12-01 15:34:19 INFO (MainThread) [mysensors.gateway_tcp] Trying to connect to ('192.168.1.10', 5003)
    Dec 01 15:34:29 raspberrypi hass[291]: 2018-12-01 15:34:29 ERROR (MainThread) [mysensors.gateway_tcp] Connecting to socket timed out for ('192.168.1.10', 5003)
    Dec 01 15:34:29 raspberrypi hass[291]: 2018-12-01 15:34:29 INFO (MainThread) [mysensors.gateway_tcp] Waiting 10.0 secs before trying to connect again
    i also checked the tcp port and found:
    tcp 0 1 192.168.1.6:55916 192.168.1.10:5003 SYN_SENT 291/python3
    which seems that it waits a respond from gateway in order to establish a connection
  • solved i just comment below line of my code:
    //#define MY_CONTROLLER_IP_ADDRESS 192,168,1,6
    //#define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
    and delete mysensors.pickle1 file .
    thanks @mfalkvidd for your trial to support me.
  • 1
  • 17
