MQTT Gateway floods logfile if broker is not reachable
  • mysgw (the mysensors gateway) sends a continuous flow of error messages to the log file if mysgw is started and the configured mqtt broker is not available. I am running a quite recent version (built on Dec 5, 2018), branch master.
    My problem with mysgw is the excessive logging. I know I can resolve it by configuring my mqtt broker, but mysgw should not produce such a massive amount of logging if the mqtt broker is not available.
    Dec  5 11:19:13 raspberrypi mysgw: failed to connect
    Dec  5 11:19:13 raspberrypi mysgw: GWT:RMQ:MQTT RECONNECT
    Dec  5 11:19:13 raspberrypi mysgw: connect: Connection refused
    Started on the command line (only first lines copied, there are hundreds of lines per second):
    root@raspberrypi:/home/pi# mysgw
    Dec 05 11:26:42 INFO  Starting gateway...
    Dec 05 11:26:42 INFO  Protocol version - 2.3.0
    Dec 05 11:26:42 DEBUG MCO:BGN:INIT GW,CP=RPNGL---,VER=2.3.0
    Dec 05 11:26:42 DEBUG TSF:LRT:OK
    Dec 05 11:26:42 DEBUG TSM:INIT
    Dec 05 11:26:42 DEBUG TSF:WUR:MS=0
    Dec 05 11:26:42 DEBUG TSM:INIT:TSP OK
    Dec 05 11:26:42 DEBUG TSM:INIT:GW MODE
    Dec 05 11:26:42 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
    Dec 05 11:26:42 DEBUG MCO:REG:NOT NEEDED
    Dec 05 11:26:42 DEBUG MCO:BGN:STP
    Dec 05 11:26:42 DEBUG MCO:BGN:INIT OK,TSP=1
    Dec 05 11:26:42 DEBUG GWT:RMQ:MQTT RECONNECT
    Dec 05 11:26:42 ERROR connect: Connection refused
    Dec 05 11:26:42 ERROR failed to connect
  • Mod
    @cvdenzen would you mind checking if the development branch has the same behavior? (the master branch is only updated when a new release is made so it has not changed since June)
  • @mfalkvidd The development branch has the same behavior. An edit in core/MyGatewayTransportMQTTClient.cpp (I added a "delay(3000)" after line 148 in reconnectMQTT(void)) made it a lot better!
  • Looks like this was solved in branch develop at Jan, 6, 2019:
    98355b2d ( tekka 2019-01-06 18:14:10 +0100 158) delay(1000);
  • Mod
  • 33
  • 9
  • 17
  • 8
  • 5
  • 11
26
