Jeedom controller and gateway on the same Raspi
  • Hi,
    I've tried Domoticz with a NRF24 gateway on the same Raspberry Pi (no need to use specific gateway on an Arduino) and it works well with a virtual serial port to link the controller and the gateway.
    Now i'm trying to use Jeedom as a controller (more flexible than Domoticz) on a Raspberry pi with an NRF24L01. Is it possible to do the same thing: the Raspi doing also the gateway job ?
  • Mod
    @stef yes it is. Just disable the MySensors gateway on the Hardware page in Domoticz and add the MySensors gateway to Jeedom instead. Using the same gateway with more than one controller at the same time doesn't work unless the controllers are capable of coexisting, which most controllers aren't.
  • Thanks but when you've added the MySensors plugin, how to configure the gateway in the MySensors configuration page of Jeedom ?
  • 19
  • 7
  • 1
  • 4
11.3k
