  3. MCP9700 Readings flucuate
6 Posts 2 Posters 3.5k Views 1 Watching
  • D
    den2k
    wrote on last edited by den2k
    Does anyone else have this similar issue?
    When using power through a USB FTDI dongle, reading are very stable (beginning part of chart showing roughly 72F), but when I plug in just the battery source at around 11PM, the readings swing dramatically as you can see. This is my hookup minus the DPT sensor, swapped in with a MCP9700 sensor.
    DwaltD 1 Reply Last reply
    • D den2k
      DwaltD
      DwaltD
      Dwalt
      @den2k You are getting noise from the voltage regulator. From the data sheet:
      ... it is recommended that a decoupling
      capacitor of 0.1 µF to 1 µF be used between the VDD
      and GND pins. In high-noise applications, connect the
      power supply voltage to the VDD pin using a 200ohm
      resistor with a 1 µF decoupling capacitor. A high fre-
      quency ceramic capacitor is recommended. It is neces-
      sary that the capacitor is located as close as possible
      to the VDD and GND pins in order to provide effective
      noise protection.
      • D
        den2k
        Thanks for the input. Just to clarify, are you talking the stepup data sheet?
        But aren't the caps on the stepup module enough to dampen and stabilize the power. I shouldn't assume it does, but figure I'd ask.
        • D den2k
          DwaltD
          DwaltD
          Dwalt
          @den2k I was referring to the MCP9700 data sheet.
          • D
            den2k
            This is the hookup I have for the MCP9700. Hmm. Any additional thoughts? I'm going to try adding a 1uF and 200 ohm resistor and see if anything happens.
            upload-3c15885c-71dc-44ed-bac3-657a48c5da79
            • D
              den2k
              Problem solved. For those interested. The issue was the 3.3V Step up board. When the radio turns on there is a large power draw which causes the voltage on the 3.3V rail to drop. This caused the temperature reading fluctuations I was seeing. I added a large cap between the Vout / GND of the step up. Problem solved.
