  3. 💬 Various bootloader files based on Optiboot 6.2
optiboot
164 Posts 18 Posters 95.4k Views 18 Watching
    Samuel235
    Actually, i have no proof but i've been informed from the arduino standalone microcontroller forums, that using a external 8mhz crystal is good for power consumption. ONLY if its a sleeping module though, it enables it to perform its tasks quicker and then sleep quicker, resulting in more time sleeping.
    That error code is something i ran into, i'm guessing you're working inside of arduino IDE, if so its to do with your boards.txt entry. Its missing that entry that it speak about. Check that its there, if not enter it in manually.
    MySensors 2.1.1
    alexsh1A 1 Reply Last reply
    • S Samuel235
      alexsh1A
      alexsh1A
      alexsh1
      #46
      @samuel235
      Thanks - yes you are right it is about boards.txt.
      However, the problem is that I did not change anything. Two days ago I uploaded severa sketches and no errors were coming up and now two different boards are showing the same error. This is just odd...
      S 1 Reply Last reply
      • alexsh1A alexsh1
        @samuel235
        Samuel235
        @alexsh1, have you performed an Arduino IDE update? I had this exact issue simply because I updated my IDE.
        MySensors 2.1.1
        • GertSandersG
          GertSandersG
          GertSanders
          #48
          This message pops up since IDE 1.6.7
          The new IDE expects this entry for all boards, just add it or ignore (it's more a warning then an error).
          carlierdC 1 Reply Last reply
            Samuel235
            And there you go, the forever informative @GertSanders has andwered your questioning ;)
            MySensors 2.1.1
            • S Samuel235
              alexsh1A
              alexsh1A
              alexsh1
              @samuel235 Looks like you are right - without realising I did press update button thinking about a sketch rather than about the update :(
              Corrected this issue aleady in the boards.txt
              • GertSandersG GertSanders
                carlierdC
                carlierdC
                carlierd
                @GertSanders Hello ! I am trying to upload a sketch without success for the moment.
                Burning of the bootloader was done correctly (led on pin 8 lit three times) but impossible to load a sketch.
                For easy deployment I choose to create a new folder to include your bootloaders:
                But it seems that something is missing as upload is not possible:
                Le croquis utilise 1 030 octets (3%) de l'espace de stockage de programmes. Le maximum est de 32 256 octets.
                Les variables globales utilisent 9 octets (0%) de mémoire dynamique, ce qui laisse 2 039 octets pour les variables locales. Le maximum est de 2 048 octets.
                /Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbmodem1411 -b38400 -D -Uflash:w:/var/folders/2y/_n7gfzjx5_sgmtyh9t_lp0wc0000gn/T/build8919458311701309495.tmp/Blink.cpp.hex:i
                         User configuration file is "/Users/carlierd/.avrduderc"
                         Using Port                    : /dev/cu.usbmodem1411
                         Overriding Baud Rate          : 38400
                avrdude: ser_open(): can't open device "/dev/cu.usbmodem1411": No such file or directory
                ioctl("TIOCMGET"): Inappropriate ioctl for device
                avrdude done.  Thank you.
                Problème de téléversement vers la carte. Voir http://www.arduino.cc/en/Guide/Troubleshooting#upload pour suggestions.
                Any suggestion ?
                David.
                • carlierdC carlierd
                  Any suggestion ?
                  David.
                  GertSandersG
                  GertSandersG
                  GertSanders
                  @carlierd
                  I am almost certain that you are NOT using my boards.txt because you put the bootloaders outside the reach of the IDE (must be in the sketchfolder and within the hardware subfolder of the sketches folder).
                  carlierdC 2 Replies Last reply
                    @carlierd
                    carlierdC
                    carlierdC
                    carlierd
                    @GertSanders
                    No doubt that I using your file as I got the same problem as @alexsh1 with the arduino pin file.
                    Look at my board choice:
                    I find this method very good for deployment but only when it's working ;)
                    I check the bootloader with Nick Gammon sketch and it seems good.
                    David.
                    • carlierdC
                      carlierdC
                      carlierd
                      I burn the bootloader one more time and now I can upload without any change on configuration.
                      Perhaps I made a mistake the first time :)
                      I will continue my test.
                      David.
                        @carlierd
                        carlierdC
                        carlierdC
                        carlierd
                        @GertSanders One more question on the LED connected on B0.
                        When you wrote that the LED lit on arduino reset, it's when the reset button is pushed ? when the arduino start ? or both ?
                        David.
                          David.
                          GertSandersG
                          GertSandersG
                          GertSanders
                          #56
                          @carlierd
                          When the atmega328 is reset, the LED will flash three times if the boot loader is in memory. This also happens when you send a new sketch via the Arduino IDE to the atmega328.
                          So if you connect pin 1 shortly to GND, the led should flash.
                          The first time you load a boot loader, the atmega328 will "loop" between the startup procedure of the boot loader (and will flash the led), and then try to load the sketch. If there never is a sketch, it will start the boot loader again and again ...
                            @carlierd
                            carlierdC
                            carlierdC
                            carlierd
                            @GertSanders
                            So it confirms that your bootloader was correctly burnt in the atmega as the first time I failed to upload a sketch the LED flash three time again and again !
                            Thanks !
                            David.
                            • carlierdC
                              carlierdC
                              carlierd
                              I tested two bootloaders today:
                              • optiboot_atmega328_08M_038400_B0.hex
                              • optiboot_atmega328_01M_009600_B0.hex
                              But I am pretty sure you already tested them.
                              I got some issue with 1MHz bootloader but probably because I am using signing feature.
                              I will check the forum to be sure.
                              David.
                                David.
                                GertSandersG
                                GertSandersG
                                GertSanders
                                @carlierd
                                Indeed I am using these two boot loaders already. The 1Mhz in my very slim nodes and the 8Mhz in the red board battery based nodes.
                                I also use the 16Mhz in my AC based board (as a repeater or as SMS gateway).
                                I will make an AC board with a 20Mhz crystal just to test the faster versions of the bootloader.
                                  @carlierd
                                  carlierdC
                                  carlierdC
                                  carlierd
                                  @GertSanders
                                  Hello, as I got some issue with the 1MHz bootloader, I tried without the signing feature and I still got st=fail.
                                  One question for you, perhaps stupid but I need to be sure ;)
                                  Do you need to set the same serial speed on both node and gateway ?
                                  David.
                                    @GertSanders
                                    David.
                                    GertSandersG
                                    GertSandersG
                                    GertSanders
                                    @carlierd
                                    No, the serial speed is not something relevant for the radio communication.
                                    When I compile the boot loader, I just need to choose the CPU frequency and make sure I also choose an upload speed which is compatible with that CPU frequency. Some combinations of CPU frequency and upload speed give errors and the error rate of the serial upload communication can not be above 2% or AVRDUDE will fail.
                                    For node to gateway communication (and your ST=FAIL errors) this is not relevant.
                                    ST=FAIL errors can (in my case) be reduced by lowering the power output of the radio on the node (is default set to MAX, I put it mostly to HIGH).
                                    st=fail errors can also be the result of poor power to the radio.
                                      @carlierd
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      Or just a bad radio. There is a huge thread on the forum about fake radio modules.
                                      I have gone through quite a few - what a waste of time....
                                      • carlierdC
                                        carlierdC
                                        carlierd
                                        I am using RFM69. No fake as it's working perfectly at other frequency.
                                        @GertSanders
                                        I tried three different configurations:
                                        • 16 MHz with crystal
                                        • 8 MHz internal
                                        • 1 MHz internal (with some st=fail)
                                        I measured power consumption in sleep mode and found that it's very close to 4uA with all configurations. So why using the 1 MHz ? Do you have better consumption when using 1 MHz ?
                                        The best configuration for me will be the 8 MHz internal as it avoid to used the crystal.
                                        David.
                                        GertSandersG S 2 Replies Last reply
                                          @GertSanders
                                          • 8 MHz internal
                                          David.
                                          GertSandersG
                                          GertSandersG
                                          GertSanders
                                          @carlierd
                                          In sleep mode it does not matter which frequency is used. The watchdog timer runs off its own clock and that is the same for all three cases. The fact that you get around 4 uA is just because you still have a watchdogtimer running. With full deep sleep and complete shutdown of the radio we should see 1-2 uA if external pullup of more then 2MOhm is used.
                                          The mcu frequency is important for the active time. Higher frequency means faster startup and faster completion of tasks.
                                          8Mhz is a good compromise as the internal oscillator is less powerhungry then fullswing crystal.
                                          And you need less parts.
