  3. SX1278
SX1278
1 Posts 1 Posters 457 Views 1 Watching
  • P Offline
    P Offline
    plawrence14
    HI
    I am using a PIC18F45K22 and am trying to control a sx1278 radio module through the SPI I have tried bit banging as per the code below but dont seam to be getting any output I can see the states by slowing the programdown and watchingthe different pins state and i believe they are looping through bytes correctly. can anyone have a look and see if they can see a mistake?
    Thanks paul
    program bitBangSPI
    ' Declarations section
    dim NCS as sbit at LATA.4 'set a4 as nss output
    dim MCK as sbit at LATC.3 'set c3 as clk outout
    dim MOSI as sbit at LATC.5 'set c5 as write outpur
    dim MISO as sbit at PORTC.4 'set c4 as read input
    dim bitcnt as byte ' used as count for sending a byte
    dim address as byte ' used to hold register address to write too
    dim payload as byte ' used to hold data to be sent
    Sub procedure sendByte()
    MOSI = 0 'set MOSI start at 0
    NCS = 0 'NCS low to select sx1278
    MCK =0
    'first write address byte
    for bitcnt = 0 to 7 'counts through all bits in byte
    MCK = 0 'clock low
    if address AND 0x80 then 'checks MSB against address for 1to decide what to write to mosi
    MOSI = 1
    else
    MOSI = 0
    end if
    delay_ms (200)
    MCK = 1 'clock high
    delay_ms (200)
    address = address <<1
    next bitcnt
    'now write data      byte
        MCK = 0                          'clock low
        if payload AND 0x80 then            'checks MSB against payloadfor 1to decide what to write to mosi
            MOSI = 1
        else
            MOSI = 0
        end if
        delay_ms (200)                      'just used so I can watch the bits on dev board
        MCK = 1                             'clock high
        payload = payload <<1
    next bitcnt                             'loop to next bit in byte
    MCK = 0                                 'clock low
    NCS = 1                                 'NCS sent low unselecting sx1278
    end sub
    sub procedure Standby()
    address = 0x01 'OpMode reg address
    payload =   0x89                  ' in standby mode
    sendByte()
    end sub
    sub procedure FSTX()
    payload =   0x8A               ' in FSTX mode
    sendByte()
    end sub
    sub procedure transmit()
    payload =   0x8B               ' in TX mode  (used transmit as name of sub as TX reserved
    sendByte()
    end sub
    main:
    ' Main program
    OSCCON = 0x60        'set to 8 negs
    PLLEN_Bit = true     'multiple of 4 so 32 megs
    ANSELB = 0           ' set port b to digital
    ANSELC = 0           ' set port c to digital
    ANSELD = 0            ' set port d to digital
    TRISA = 0x00
    TRISD = 0X00         'SET AS OUT PUT
    TRISC = 0x10         'set port C as output except pin 4 thats an input
    TRISB0_bit =1        'sets RB0 pin as a input
    TRISB1_bit =1        'sets RB1 pin as a input
    TRISB2_bit =1        'sets RB2 pin as a input
    TRISB3_bit =1        'sets RB3 pin as a input
    NCS = 1
    Standby()                      ' in standby mode
    while true
          if (BUTTON(PORTB, 0, 1, 1)) then               ' check scondition of button attached to B0  run if pressed
             LATD = 0xFF
             FSTX()
             address =   0x00      'fifo reg address
             payload =   0x01      'data to be transmitted
             sendByte()
             transmit()
             LATD = 0x00
          end if
    wend
    end.
