<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Unkown Touch switch PCB : How to make them push instead Toggle]]></title><description><![CDATA[<p dir="auto">Hello ,</p>
<p dir="auto">I have a chinese touch switch PCB with 3 HTTM touch sensor on it.<br />
Now its configures as Toggle , but i'm searching to make the Push<br />
Normally on the sensors you have to remove resistor or cut path , but don't know how with this.</p>
<p dir="auto">On the PCB there is word Modu-Y9B<br />
there are 3 IC : WS480L (RF receiver) , ATMHK218 and also another unknown IC (no type on it )</p>
<p dir="auto">i place here also The front and back</p>
<p dir="auto"><img src="https://i.ibb.co/Rh4n0Dk/IMG-2274.jpg" alt="alt text" class=" img-fluid img-markdown" /><br />
<img src="https://i.ibb.co/pvLHzn2/IMG-2275.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mysensors.org/topic/11157/unkown-touch-switch-pcb-how-to-make-them-push-instead-toggle</link><generator>RSS for Node</generator><lastBuildDate>Thu, 11 Jun 2026 13:20:12 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/11157.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 14 May 2020 15:36:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Unkown Touch switch PCB : How to make them push instead Toggle on Fri, 15 May 2020 03:27:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/helmuteke" aria-label="Profile: helmuteke">@<bdi>helmuteke</bdi></a> said in <a href="/post/105593">Unkown Touch switch PCB : How to make them push instead Toggle</a>:</p>
<blockquote>
<p dir="auto">ATMHK218</p>
</blockquote>
<p dir="auto">From google this looks like a serial eeprom.<br />
For the other chip if it has no writing then it's impossible to help, especially when the picture is in such low resolution.</p>
<p dir="auto">My guess is the HTTM sensors have no resistance soldered so there is no way to change it unless you remove them, add the resistance and put them back...</p>
]]></description><link>https://forum.mysensors.org/post/105596</link><guid isPermaLink="true">https://forum.mysensors.org/post/105596</guid><dc:creator><![CDATA[Nca78]]></dc:creator><pubDate>Fri, 15 May 2020 03:27:46 GMT</pubDate></item></channel></rss>
