  3. OpenHAB
  4. Openhab 2.5.5, raspberry pi 4 with usb boot ssd
22 Posts 2 Posters 2.9k Views 2 Watching
  • TRS-80T TRS-80
    @CraigDubya said in Openhab 2.5.5, raspberry pi 4 with usb boot ssd:
    You are welcome.
    take a break
    Some times it is the best thing, and actually can make progress quicker.
    I tend to keep many different projects going at once, not only for this reason but also so I can order cheap parts and I'm not in a hurry for them, as there is always something else to work on. ;)
    C
    C
    CraigDubya
    @TRS-80
    It works!
    What the hell did I do? I wish I knew!!!
    So, I came back after my break. I decided that I really needed to get Arduino IDE up and running so I could use the Serial Monitor. I uninstalled Arduino using - sudo apt-get remove arduino.
    Then, I downloaded the Linux Arm 32-bit version of Arduino from there website and installed it from the download file which got me up and running with it.
    The IDE allowed me to choose /dev/ttyUSB0 as a port, but when I opened the serial monitor the error message displayed port not found. I did a ls /dev/tty* and indeed the port was missing.
    I unplugged the serial gateway, and plugged it back in
    Then /dev/tty* showed it in the list, but this time it was in yellow text like all the other ports, instead of blue(?)
    I then did - sudo chmod a+rw /dev/ttyUSB0 (thought we did this earlier? - can't remember)
    Back to Openhab PaperUI and inbox search for my sensors and it found my sensors!
    I'm confused how I got here, but at least now I know it works with all the changes I had made :upside_down_face:
    • TRS-80T
      TRS-80T
      TRS-80
      wrote on last edited by TRS-80
      #22
      That's great news! Now back to the fun part! :)
      I prefer to have a repeatable, definable failure mode, and then fix that, rather than an unknown success, but that's just me. :D
