<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[The Big Picture. Will this work?]]></title><description><![CDATA[<p dir="auto">Greetings everybody.</p>
<p dir="auto">I'm beginning to dig myself into the topic of DIY homeautomation :D But there are also some questions i can't answer myself properly :(<br />
I'm planning the following setup:</p>
<ul>
<li>raspi as OpenHAB Base with raspbian</li>
<li>MQTT Gateway (installed on the pi? possible?)</li>
<li>sensors:
<ul>
<li>energy source: battery for all. I don't want to cut cables into my walls (besides: my wife would kill me :D ) runtimes should be at least 6 months ^^</li>
<li>transmission sensors -&gt; gateway: WiFi with (WPA2 enabled) would be awesome, maybe bluetooth4 (with bluetooth low energy ??)</li>
<li>sensor types: temp, humidy and door/window sensors</li>
</ul>
</li>
</ul>
<p dir="auto">Any chance to archieve this?</p>
<p dir="auto">Thx</p>
]]></description><link>https://forum.mysensors.org/topic/1136/the-big-picture-will-this-work</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 17:29:28 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/1136.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 21 Mar 2015 08:44:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to The Big Picture. Will this work? on Sat, 21 Mar 2015 22:16:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dakky" aria-label="Profile: dakky">@<bdi>dakky</bdi></a></p>
<p dir="auto">look here <a href="http://forum.mysensors.org/topic/1021/security-introducing-signing-support-to-mysensors" rel="nofollow ugc">http://forum.mysensors.org/topic/1021/security-introducing-signing-support-to-mysensors</a></p>
]]></description><link>https://forum.mysensors.org/post/11657</link><guid isPermaLink="true">https://forum.mysensors.org/post/11657</guid><dc:creator><![CDATA[tbowmo]]></dc:creator><pubDate>Sat, 21 Mar 2015 22:16:23 GMT</pubDate></item><item><title><![CDATA[Reply to The Big Picture. Will this work? on Sat, 21 Mar 2015 18:26:39 GMT]]></title><description><![CDATA[<p dir="auto">Under Development is a great thread about security:</p>
<p dir="auto">[security] Introducing signing support to MySensors</p>
]]></description><link>https://forum.mysensors.org/post/11651</link><guid isPermaLink="true">https://forum.mysensors.org/post/11651</guid><dc:creator><![CDATA[maha]]></dc:creator><pubDate>Sat, 21 Mar 2015 18:26:39 GMT</pubDate></item><item><title><![CDATA[Reply to The Big Picture. Will this work? on Sat, 21 Mar 2015 16:12:44 GMT]]></title><description><![CDATA[<p dir="auto">u i got trapped .... the nrf24l01+ does't do WiFi. It just uses the same band :( i would prefer real WPA2 protected WiFi. Is anything like that possible (with battery power)?<br />
if <strong>NOT</strong>, how "secure" is it, to use open radio transmission for communication?</p>
]]></description><link>https://forum.mysensors.org/post/11647</link><guid isPermaLink="true">https://forum.mysensors.org/post/11647</guid><dc:creator><![CDATA[dakky]]></dc:creator><pubDate>Sat, 21 Mar 2015 16:12:44 GMT</pubDate></item><item><title><![CDATA[Reply to The Big Picture. Will this work? on Sat, 21 Mar 2015 13:42:57 GMT]]></title><description><![CDATA[<p dir="auto">hmm do you have a hint for me? I'm trying to understand the way the gateway works. The ethernet part is ok. But what about the NRF24L01+ and WiFi? Do u have some docs/tutorials/codesnipplets for me?</p>
]]></description><link>https://forum.mysensors.org/post/11645</link><guid isPermaLink="true">https://forum.mysensors.org/post/11645</guid><dc:creator><![CDATA[dakky]]></dc:creator><pubDate>Sat, 21 Mar 2015 13:42:57 GMT</pubDate></item><item><title><![CDATA[Reply to The Big Picture. Will this work? on Sat, 21 Mar 2015 11:25:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dakky" aria-label="Profile: dakky">@<bdi>dakky</bdi></a> Well you can do the gateway for around $13ish and thats easy. Adding the gateway module to the running OpenHab could be easy if they can coexist. I have not done that, so again, it could be easy. But since you are just starting out, keep it easy.<br />
And afterwards, you can reuse the uno for other projects..</p>
]]></description><link>https://forum.mysensors.org/post/11639</link><guid isPermaLink="true">https://forum.mysensors.org/post/11639</guid><dc:creator><![CDATA[Magiske]]></dc:creator><pubDate>Sat, 21 Mar 2015 11:25:11 GMT</pubDate></item><item><title><![CDATA[Reply to The Big Picture. Will this work? on Sat, 21 Mar 2015 11:09:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tbowmo" aria-label="Profile: tbowmo">@<bdi>tbowmo</bdi></a><br />
jep thats the target on the sensor side. I'd select an ardiuno pro micro (3,3V), strip the LED from it an connect the sensors and the NRF24L01+ to it. Of course i could buy your sensor board (and maybe, depending on price an availability i will), but where is the fun and the learning progress? :D</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/magiske" aria-label="Profile: Magiske">@<bdi>Magiske</bdi></a><br />
but why an extra device for the gateway? Is it really "too hard" to connect the receiving NRF24L01+ via the gpio and run it under raspbian? An extra device means extra costs and extra wiring (power, LAN).</p>
]]></description><link>https://forum.mysensors.org/post/11637</link><guid isPermaLink="true">https://forum.mysensors.org/post/11637</guid><dc:creator><![CDATA[dakky]]></dc:creator><pubDate>Sat, 21 Mar 2015 11:09:56 GMT</pubDate></item><item><title><![CDATA[Reply to The Big Picture. Will this work? on Sat, 21 Mar 2015 10:48:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dakky" aria-label="Profile: dakky">@<bdi>dakky</bdi></a></p>
<p dir="auto">have seen <a href="http://www.mysensors.org/hardware/micro" rel="nofollow ugc">http://www.mysensors.org/hardware/micro</a> ? (temperature/humidity sensor, battery powered)</p>
]]></description><link>https://forum.mysensors.org/post/11636</link><guid isPermaLink="true">https://forum.mysensors.org/post/11636</guid><dc:creator><![CDATA[tbowmo]]></dc:creator><pubDate>Sat, 21 Mar 2015 10:48:05 GMT</pubDate></item><item><title><![CDATA[Reply to The Big Picture. Will this work? on Sat, 21 Mar 2015 09:02:52 GMT]]></title><description><![CDATA[<p dir="auto">OpenHab on a pi is a good choice.<br />
I would use an Arduino Uno with an ethernet shield for the MQTT gateway, so much easier to setup.<br />
A good 18650 3.7v battery should give you more than 6 months if you power trim you sensors.<br />
And the transmission would be by using NRF24L01+'s.</p>
<p dir="auto">So all about making it easy for yourself:)</p>
<p dir="auto">So to answer you question.. Yes, should be easy to achieve fairly fast.</p>
]]></description><link>https://forum.mysensors.org/post/11631</link><guid isPermaLink="true">https://forum.mysensors.org/post/11631</guid><dc:creator><![CDATA[Magiske]]></dc:creator><pubDate>Sat, 21 Mar 2015 09:02:52 GMT</pubDate></item></channel></rss>
