  3. OpenHAB
  4. voltage sensor via esp and mqtt
1 Posts 1 Posters 637 Views 1 Watching
    muhammed
    hello every one ,
    i’m trying to make a smart voltage meter to measure voltage and send the readings to a mobile phone using MQTT and openhab .
    hardware and circuit diagram :
    ESP8266-12E wifi module
    voltage sensor
    i have a problem in the code that have to be burned to the esp module .
    i have a pre-prepared code of a smart fire sensor that sends a notification when fire detected . i’m trying to modify this code to work with my voltage meter .
    those are the two codes :
    complete fire sensor code :
    Device Title: MK-FireSensor V2
    Device Description: MQTT Fire Sensor
    Device Explanation: This device connects to your existing
                    fire detectors and when they go off this
                    device sends an MQTT message to the server
    Device information: https://www.MK-SmartHouse.com/fire-sensor
    Author: Matt Kaczynski
    Website: http://www.MK-SmartHouse.com
    Code may only be distrbuted through http://www.MK-SmartHouse.com any other methods
    of obtaining or distributing are prohibited
    Copyright © 2016-2018
    Note: After flashing the code once you can remotely access your device by going to http://HOSTNAMEOFDEVICE.local/firmware
    obviously replace HOSTNAMEOFDEVICE with whatever you defined below. The user name and password are also defined below.
    /* ---------- DO NOT EDIT ANYTHING IN THIS FILE UNLESS YOU KNOW WHAT YOU ARE DOING---------- */
    #include <FS.h> //this needs to be first, or it all crashes and burns…
    #include <Servo.h>
    #include <ESP8266WiFi.h> //https://github.com/esp8266/Arduino
    #include <MQTTClient.h> //https://github.com/256dpi/arduino-mqtt
    #include <DNSServer.h>
    #include <ESP8266WebServer.h>
    #include <WiFiManager.h> //https://github.com/tzapu/WiFiManager
    #include <ArduinoJson.h> //https://github.com/bblanchon/ArduinoJson
    #include <ESP8266mDNS.h>
    #include <ESP8266HTTPUpdateServer.h>
    //define your default values here, if there are different values in config.json, they are overwritten.
    char host[34];
    char mqtt_server[40];
    char mqtt_port[6] = “1883”;
    char mqtt_topic[50];
    char mqtt_isAuthentication[7] = “FALSE”;
    char mqtt_username[40];
    char mqtt_password[40];
    char update_username[40];
    char update_password[40];
    char update_path[34] = “/firmware”;
    //Unique device ID
    const char* mqttDeviceID;
    //Form Custom SSID
    String ssidAP = “MK-FireSensor” + String(ESP.getChipId());
    //flag for saving data
    bool shouldSaveConfig = false;
    //callback notifying us of the need to save config
    void saveConfigCallback ()
    shouldSaveConfig = true;
    //the time when the sensor outputs a low impulse
    long unsigned int lowIn;
    //the amount of milliseconds the sensor has to be low
    //before we assume all detection has stopped
    long unsigned int pause = 100;
    //sensor variables
    boolean lockLow = true;
    boolean takeLowTime;
    //the digital pin connected to the fire sensor’s output
    int sensorPin = 13;
    ESP8266WebServer httpServer(80);
    ESP8266HTTPUpdateServer httpUpdater;
    WiFiClient net;
    MQTTClient client;
    unsigned long lastMillis = 0;
    void connect();
    if (SPIFFS.begin())
    if (SPIFFS.exists("/config.json"))
    //file exists, reading and loading
    File configFile = SPIFFS.open("/config.json", “r”);
    if (configFile)
    size_t size = configFile.size();
    // Allocate a buffer to store contents of the file.
    std::unique_ptr<char[]> buf(new char[size]);
        configFile.readBytes(buf.get(), size);
        DynamicJsonBuffer jsonBuffer;
        JsonObject& json = jsonBuffer.parseObject(buf.get());
        json.printTo(Serial);
        if (json.success())
          strcpy(host, json["host"]);
          strcpy(update_username, json["update_username"]);
          strcpy(update_password, json["update_password"]);
          strcpy(mqtt_isAuthentication, json["mqtt_isAuthentication"]);
          strcpy(mqtt_username, json["mqtt_username"]);
          strcpy(mqtt_password, json["mqtt_password"]);
          strcpy(update_path, json["update_path"]);
          strcpy(mqtt_server, json["mqtt_server"]);
          strcpy(mqtt_port, json["mqtt_port"]);
          strcpy(mqtt_topic, json["mqtt_topic"]);
        else
    else
    //end read
    // The extra parameters to be configured (can be either global or just in the setup)
    // After connecting, parameter.getValue() will get you the configured value
    // id/name placeholder/prompt default length
    WiFiManagerParameter custom_text0(“
    Select your wifi network and type in your password, if you do not see your wifi then scroll down to the bottom and press scan to check again.
    WiFiManagerParameter custom_text1(“
    Hostname/MQTT ID
    WiFiManagerParameter custom_text2(“
    Enter a name for this device which will be used for the hostname on your network and identify the device from MQTT.
    WiFiManagerParameter custom_host(“name”, “Device Name”, host, 32);
    WiFiManagerParameter custom_text3(“
    MQTT
    WiFiManagerParameter custom_text4(“
    Enter the details of your MQTT server and then enter the topic for which the device sends Fire Detector State MQTT messages to. If your server requires authentication then set it to True and enter your server credentials otherwise leave it at false and keep the fields blank.
    WiFiManagerParameter custom_mqtt_server(“server”, “MQTT Server IP”, mqtt_server, 40);
    WiFiManagerParameter custom_mqtt_port(“port”, “MQTT Server Port”, mqtt_port, 5);
    WiFiManagerParameter custom_mqtt_topic(“topic”, “MQTT Out Topic”, mqtt_topic, 50);
    WiFiManagerParameter custom_mqtt_isAuthentication(“isAuthentication”, “MQTT Authentication?”, mqtt_isAuthentication, 7);
    WiFiManagerParameter custom_mqtt_username(“userMQTT”, “Username For MQTT Account”, mqtt_username, 40);
    WiFiManagerParameter custom_mqtt_password(“passwordMQTT”, “Password For MQTT Account”, mqtt_password, 40);
    WiFiManagerParameter custom_text5(“
    Web Updater
    WiFiManagerParameter custom_text6(“
    The web updater allows you to update the firmware of the device via a web browser by going to its ip address or hostname /firmware ex. 192.168.0.5/firmware you can change the update path below. The update page is protected so enter a username and password you would like to use to access it.
    WiFiManagerParameter custom_update_username(“user”, “Username For Web Updater”, update_username, 40);
    WiFiManagerParameter custom_update_password(“password”, “Password For Web Updater”, update_password, 40);
    WiFiManagerParameter custom_device_path(“path”, “Updater Path”, update_path, 32);
    WiFiManagerParameter custom_text7(“
    To reset device settings restart the device and quickly move the jumper from RUN to PGM, wait 10 seconds and put the jumper back to RUN.
    WiFiManagerParameter custom_text8(””);
    //WiFiManager
    //Local intialization. Once its business is done, there is no need to keep it around
    WiFiManager wifiManager;
    //set config save notify callback
    wifiManager.setSaveConfigCallback(saveConfigCallback);
    //set static ip
    //wifiManager.setSTAStaticIPConfig(IPAddress(10,0,1,99), IPAddress(10,0,1,1), IPAddress(255,255,255,0));
    //add all your parameters here
    wifiManager.setCustomHeadElement(".c{text-align: center;} div,input{padding:5px;font-size:1em;} input{width:95%;} body{text-align: center;font-family:oswald;} button{border:0;background-color:#313131;color:white;line-height:2.4rem;font-size:1.2rem;text-transform: uppercase;width:100%;font-family:oswald;} .q{float: right;width: 65px;text-align: right;} body{background-color: #575757;}h1 {color: white; font-family: oswald;}p {color: white; font-family: open+sans;}a {color: #78C5EF; text-align: center;line-height:2.4rem;font-size:1.2rem;font-family:oswald;}");
    wifiManager.addParameter(&custom_text0);
    wifiManager.addParameter(&custom_text1);
    wifiManager.addParameter(&custom_text2);
    wifiManager.addParameter(&custom_host);
    wifiManager.addParameter(&custom_text3);
    wifiManager.addParameter(&custom_text4);
    wifiManager.addParameter(&custom_mqtt_server);
    wifiManager.addParameter(&custom_mqtt_port);
    wifiManager.addParameter(&custom_mqtt_topic);
    wifiManager.addParameter(&custom_mqtt_isAuthentication);
    wifiManager.addParameter(&custom_mqtt_username);
    wifiManager.addParameter(&custom_mqtt_password);
    wifiManager.addParameter(&custom_text5);
    wifiManager.addParameter(&custom_text6);
    wifiManager.addParameter(&custom_update_username);
    wifiManager.addParameter(&custom_update_password);
    wifiManager.addParameter(&custom_device_path);
    wifiManager.addParameter(&custom_text7);
    wifiManager.addParameter(&custom_text8);
    //reset settings - for testing
    //wifiManager.resetSettings();
    //set minimu quality of signal so it ignores AP’s under that quality
    //defaults to 8%
    //wifiManager.setMinimumSignalQuality();
    //sets timeout until configuration portal gets turned off
    //useful to make it all retry or go to sleep
    //in seconds
    wifiManager.setTimeout(120);
    //fetches ssid and pass and tries to connect
    //if it does not connect it starts an access point with the specified name
    //here “AutoConnectAP”
    //and goes into a blocking loop awaiting configuration
    if (!wifiManager.autoConnect(ssidAP.c_str()))
    delay(3000);
    //reset and try again, or maybe put it to deep sleep
    ESP.reset();
    delay(5000);
    //read updated parameters
    strcpy(host, custom_host.getValue());
    strcpy(mqtt_server, custom_mqtt_server.getValue());
    strcpy(mqtt_port, custom_mqtt_port.getValue());
    strcpy(mqtt_topic, custom_mqtt_topic.getValue());
    strcpy(mqtt_isAuthentication, custom_mqtt_isAuthentication.getValue());
    strcpy(mqtt_username, custom_mqtt_username.getValue());
    strcpy(mqtt_password, custom_mqtt_password.getValue());
    strcpy(update_username, custom_update_username.getValue());
    strcpy(update_password, custom_update_password.getValue());
    strcpy(update_path, custom_device_path.getValue());
    //save the custom parameters to FS
    if (shouldSaveConfig)
    JsonObject& json = jsonBuffer.createObject();
    json[“host”] = host;
    json[“mqtt_server”] = mqtt_server;
    json[“mqtt_port”] = mqtt_port;
    json[“mqtt_topic”] = mqtt_topic;
    json[“mqtt_isAuthentication”] = mqtt_isAuthentication;
    json[“mqtt_username”] = mqtt_username;
    json[“mqtt_password”] = mqtt_password;
    json[“update_username”] = update_username;
    json[“update_password”] = update_password;
    json[“update_path”] = update_path;
    File configFile = SPIFFS.open("/config.json", "w");
    if (!configFile)
    json.printTo(configFile);
    configFile.close();
    //end save
    delay(5000);
    if(digitalRead(0) == LOW || String(host).length() == 0 || String(mqtt_server).length() == 0 || String(mqtt_topic).length() == 0 || String(update_username).length() == 0 || String(update_password).length() == 0)
    ESP.reset();
    mqttDeviceID = host;
    client.begin(mqtt_server, atoi(mqtt_port), net);
    client.onMessage(messageReceived);
    connect();
    MDNS.begin(host);
    httpUpdater.setup(&httpServer, update_path, update_username, update_password);
    httpServer.on("/", {
    if(!httpServer.authenticate(update_username, update_password))
    return httpServer.requestAuthentication();
    httpServer.send(200, “text/plain”, "Hostname: " + String(host) + "\nMQTT Server: " + String(mqtt_server) + "\nMQTT Port: " + String(mqtt_port) + "\nMQTT Authentication: " + String(mqtt_isAuthentication) + "\nMQTT Out Topic: " + String(mqtt_topic) + “\nTo update firmware go to: http://”+ String(host) + “.local” + String(update_path) + “\nTo reset device settings restart the device and quickly move the jumper from RUN to PGM, wait 10 seconds and put the jumper back to RUN.”);
    httpServer.begin();
    MDNS.addService(“http”, “tcp”, 80);
    void connect()
    while (WiFi.status() != WL_CONNECTED)
    delay(1000);
    //If authentication true then connect with username and password
    if(String(mqtt_isAuthentication).equalsIgnoreCase(“TRUE”))
    while (!client.connect(mqttDeviceID, mqtt_username, mqtt_password))
    delay(1000);
    else
    while (!client.connect(mqttDeviceID))
    delay(1000);
    client.subscribe(mqtt_topic);
    client.loop();
    delay(10);
    if(!client.connected())
    //connect();
    client.disconnect();
    connect();
    httpServer.handleClient();
    //Sensor Detection
    if(digitalRead(sensorPin) == HIGH)
    if(lockLow)
    //makes sure we wait for a transition to LOW before any further output is made:
    lockLow = false;
    client.publish(String(mqtt_topic), “No Fire Detected”);
    delay(50);
    takeLowTime = true;
    if(digitalRead(sensorPin) == LOW)
    if(takeLowTime)
    lowIn = millis(); //save the time of the transition from high to LOW
    takeLowTime = false; //make sure this is only done at the start of a LOW phase
    //if the sensor is low for more than the given pause,
    //we assume that no more detection is going to happen
    if(!lockLow && millis() - lowIn > pause)
    //makes sure this block of code is only executed again after
    //a new detection sequence has been detected
    lockLow = true;
    client.publish(String(mqtt_topic), “FIRE DETECTED!”);
    delay(50);
    void messageReceived(String &topic, String &payload)
    //This sensor does not recieve anything from MQTT Server so this is blank
    voltage meter code :
    float correctionfactor = 26; // 77
    int analogInput = A0;
    float vout = 0;
    int vin = 0;
    float R1 = 30000
    float R2 = 7500; // 7.5 k
    int value = 0;
    Voltage();
    void Voltage()
    // read the value at analog input
    value = analogRead(analogInput);
    vout = (value * 5.0) / 1023.0; // see text
    vin = vout / (R2/(R1+R2));
    vin = vin - correctionfactor;
