  3. Is Ethernet shield for Nano usable in any way?
2 Posts 2 Posters 1.0k Views 2 Watching
  • N
    N
    NeoX
    Hi all!
    It's not really a technical problem but i wanted to ask you.
    I have a Deek-Robot W5100 Ethernet Shield for Nano. My question is, for what it is usable? :)
    I've created a very simple sketch with MySensors (W5100 Ethernet + MQTT + DHCP + MY DEBUG messages, quite typcial setup) + 2 relay messages.
    Debug build even won't fit into 30kB of flash :)
    Adding optimization, turning off My debug drops usage to 24kB (78% of flash).
    Room for application is so small, that i don't know for what this shield is used for :)
    By the way, do you know any small boards compatible (like nano) with ethernet, with more flash ?
    OldSurferDudeO 1 Reply Last reply
    • N NeoX
      Hi all!
      OldSurferDudeO
      OldSurferDudeO
      OldSurferDude
      @NeoX
      I use a Nano, Ethernet, LCD display, and GPS for an NTP server on my isolated network to provide the time for [suspect] cameras.
      #define VER 12.2
      bool debug = false;  // must be true to have debug statements go to serial
        NTP Time Server:
        Modified by Gregg Ferry
        using softwareserial instead of Serial1
        using GY-GPS6MV2
       This code is in the public domain.
       ver 12
         time server gets time from Arduino clock instead of from gps
      #define enableEthernet false
      #define enableGPS true
      #define enableDisplay true
      #define minimizeSerialTraffic true
      #if enableEthernet
      // ethernet
      #include <SPI.h>           // needed for Arduino versions later than 0018
      #include <Ethernet.h>
      #include <EthernetUdp.h>   // UDP library from: bjoern@cs.stanford.edu 12/30/2008
      // Time Server MAC address
      byte mac[] = {0xAA, 0xBB, 0xCC, 0xDD, 0xEE, 0xFF };
      // NTP Server public IP Address
      IPAddress ip(192, 168, 2, 130);
      // Time Server Port
      #define NTP_PORT 123
      unsigned int localPort = 123;
      static const int NTP_PACKET_SIZE = 48;
      // buffers for receiving and sending data
      byte packetBuffer[NTP_PACKET_SIZE];
      // An Ethernet UDP instance
      EthernetUDP Udp;
      int packetSize;
      // NTP since 1900/01/01
      //#include <PGMWrap.h>
      //const uint8_t daysInMonth [] PROGMEM = { 31,28,31,30,31,30,31,31,30,31,30,31 }; //const or compiler complains
      const uint8_t daysInMonth [] = { 31,28,31,30,31,30,31,31,30,31,30,31 }; //const or compiler complains
      const unsigned long seventyYears = 2208988800UL; // to convert unix time to epoch
      #if enableGPS
      // GPS
      #include <TinyGPS++.h>
      //GPS instance
      TinyGPSPlus tinyGPS;
      #include <NeoSWSerial.h>
      //#include <SoftwareSerial.h>
      #define rxPin 5
      #define txPin 4
      NeoSWSerial GPSSerial(rxPin, txPin); // CONNECT BT RX PIN TO ARDUINO txPin | CONNECT BT TX PIN TO ARDUINO rxPin
      char incharBefore=255;
      char inchar=255;
      #if enableDisplay
      // Display
      #include "SSD1306Ascii.h"
      #include "SSD1306AsciiAvrI2c.h"
      #define I2C_ADDRESS 0x3C
      SSD1306AsciiAvrI2c oled;
      bool TimeHasBeenSet = false;
      bool firstPass = true;
      //Time
      #include <Timezone.h>
      //#include "Time.h"
      TimeChangeRule myDST = {"PDT", Second, Sun, Mar, 2, -420};    // Daylight time = UTC - 7 hours
      TimeChangeRule mySTD = {"PST", First, Sun, Nov, 2, -480};     // Standard time = UTC - 8 hours
      Timezone myTZ(myDST, mySTD);
      TimeChangeRule *tcr;        // pointer to the time change rule, use to get TZ abbrev
      time_t local;
      String timeString = "hh:mm:ss";
      String dateString = "yyyy MMM dd";
      const String localDaysOfWeek[] = {"Sunday","Monday","Tuesday","Wednesday","Thursday","Friday","Saturday" };
      const String localMonthsOfYear[] = {"JAN","FEB","MAR","APR","MAY","JUN","JUL","AUG","SEP","OCT","NOV","DEC"};
      uint8_t localDayOfWeek;
      uint8_t previousHour = 0;
      uint8_t previousMinute = 0;
      uint8_t previousSecond = 0;
      unsigned long timestamp1970;
      //-----------------------------------------------------------------------------------printTimes
      void printTimes(){
          Serial.print(F("GPS   "));
          Serial.print(tinyGPS.date.year());Serial.print(F("/"));
          Serial.print(tinyGPS.date.month());Serial.print(F("/"));
          Serial.print(tinyGPS.date.day());Serial.print(F(" "));
          Serial.print(tinyGPS.time.hour());Serial.print(F(":"));
          Serial.print(tinyGPS.time.minute());Serial.print(F(":"));
          Serial.println(tinyGPS.time.second());
          Serial.print(F("UTC   "));
          Serial.print(year());Serial.print(F("/"));
          Serial.print(month());Serial.print(F("/"));
          Serial.print(day());Serial.print(F(" "));
          Serial.print(hour());Serial.print(F(":"));
          Serial.print(minute());Serial.print(F(":"));
          Serial.println(second());
          Serial.print(F("local "));
          Serial.print(year(local));Serial.print(F("/"));
          Serial.print(month(local));Serial.print(F("/"));
          Serial.print(day(local));Serial.print(F(" "));
          Serial.print(hour(local));Serial.print(F(":"));
          Serial.print(minute(local));Serial.print(F(":"));
          Serial.println(second(local));
          Serial.print(dateString);Serial.print(F(" "));
          Serial.println(timeString);
      //-----------------------------------------------------------------------------------setTimeAndDateStrings
      void setTimeAndDateStrings(){
        local = myTZ.toLocal(now(), &tcr); // two days ago -172800
        char buf[32];
        sprintf(buf, "%.2d:%.2d:%.2d",hour(local), minute(local), second(local));
        timeString = String(buf);
      //  char m[4];    // temporary storage for month string (DateStrings.cpp uses shared buffer)
      //  strcpy(m, monthShortStr(month(local)));
      //  sprintf(buf, "%.2d %s %d",day(local), m, year(local));
      //  dateString = String(buf);
        sprintf(buf, "%.2d ",day(local));
        dateString += localMonthsOfYear[month(local)-1];
        sprintf(buf," %d",year(local));
        dateString += String(buf);
        localDayOfWeek = weekday(local)-1;
      #if enableGPS
      //-----------------------------------------------------------------------------------getgps
      static bool getgps()
      { // and update arduino time
        if (GPSSerial.available()==0) return false;
      //  while (GPSSerial.available()) {
          incharBefore = inchar;
          inchar = GPSSerial.read();
          tinyGPS.encode(inchar);
          if (!TimeHasBeenSet) Serial.print(inchar);
        if ((inchar != 10) || (incharBefore != 13)) return false; // make sure to full NMEA statement was received
          inchar = 0; incharBefore = 0; // NMEA statement received, reset terminators
        if(tinyGPS.time.isValid()){
         *   setTime(
            tinyGPS.time.hour(),
            tinyGPS.time.minute(),
            tinyGPS.time.second(),
            tinyGPS.date.day(),
            tinyGPS.date.month(),
            tinyGPS.date.year()
            int hh=tinyGPS.time.hour();
            int mm=tinyGPS.time.minute();
            int ss=tinyGPS.time.second();
            int DD=tinyGPS.date.day();
            int MM=tinyGPS.date.month();
            int YY=tinyGPS.date.year();
            setTime(hh,mm,ss,DD,MM,YY);
          local = myTZ.toLocal(now(), &tcr); //get the local time
          setTimeAndDateStrings();
          if (!TimeHasBeenSet) printTimes();
          TimeHasBeenSet = true;
          return true;
        else {
          return false;
      #if enableDisplay
      //-----------------------------------------------------------------------------------displayGPStimeSetTheTime
      void displayGPStimeSetTheTime(bool TimeSetByGPS){
        oled.setCursor(0,0);             // Start at top-left corner
        if (TimeSetByGPS) oled.print(F(" ")); else oled.print(F("!"));
      //-----------------------------------------------------------------------------------displayAwaitingGPS
      void displayAwaitingGPS() {
        oled.clear();
        oled.println(F("NTP Server"));
        oled.println(F(" Awating"));
        oled.println(F("  GPS Lock "));
        Serial.println(F(" Awating GPS Lock "));
      //-----------------------------------------------------------------------------------displayNewDay
      void displayNewDay(){
        previousHour = hour(local);
        previousMinute= minute(local);
        previousSecond = second(local);
        oled.clear();
        oled.setCursor(12,0);             // center time string
        oled.print(timeString);
        uint8_t s = (10-localDaysOfWeek[localDayOfWeek].length())*6;
        oled.setCursor(s,3);
        oled.print(localDaysOfWeek[localDayOfWeek]);
        oled.setCursor(0,6);
        oled.print(dateString);
      //-----------------------------------------------------------------------------------displayTime
      void displayTime(){
        // digital clock display of the time
        if ((second(local)==0 && minute(local)==0 && hour(local)==0) || firstPass){ // new day
          firstPass = false;
          displayNewDay();
        else {
          if (hour(local) != previousHour){
          else {
            if (minute(local) != previousMinute){
              oled.setCursor(48,0);
              oled.print(timeString.substring(3));
            else {
              if (second(local) != previousSecond){
                oled.setCursor(84,0);
                oled.print(timeString.substring(6));
      // send to serial monitor
      #else
      void displayTime(){
      #if !minimizeSerialTraffic
        Serial.println();
        printTimes();
      //-----------------------------------------------------------------------------------setup
      #if enableEthernet
      void setupEthernet(){
        // start the Ethernet and UDP:
        Ethernet.begin(mac,ip);
        Udp.begin(localPort);
        Serial.print(Ethernet.localIP()); Serial.print(F(" "));Serial.println(NTP_PORT);
      #if enableGPS
      void setupGPS(){
        GPSSerial.begin(9600); // start GPS module UART
        // Disable everything but $GPRMC
        // Note the following sentences are for UBLOX NEO6MV2 GPS
        GPSSerial.write("$PUBX,40,GLL,0,0,0,0,0,0*5C\r\n");
        GPSSerial.write("$PUBX,40,VTG,0,0,0,0,0,0*5E\r\n");
        GPSSerial.write("$PUBX,40,GSV,0,0,0,0,0,0*59\r\n");
        GPSSerial.write("$PUBX,40,GGA,0,0,0,0,0,0*5A\r\n");
        GPSSerial.write("$PUBX,40,GSA,0,0,0,0,0,0*4E\r\n");
      #if enableDisplay
      void setupDisplay(){
        oled.begin(&Adafruit128x64, I2C_ADDRESS);
        oled.setFont(System5x7);
        oled.set2X();
        Serial.begin(115200);
        Serial.print("NTP Server with display version ");Serial.println(VER);
      #if enableDisplay
        setupDisplay();
        displayAwaitingGPS();
      #if enableEthernet
        setupEthernet();
      #if enableGPS
        setupGPS();
      //-----------------------------------------------------------------------------------loop
        while (Serial.available()){
          char inChar = Serial.read();
          if (inChar == 'd' || inChar == 'D') {
            debug = !debug;
            if (debug) Serial.println(F("debug is ON"));else Serial.println(F("debug is off"));
      #if enableGPS
        if (getgps()){
          if(TimeHasBeenSet) displayTime();
      #if enableEthernet
        // if there's data available, read a packet
        packetSize = Udp.parsePacket();
        if(packetSize) processNTP();
      #if enableEthernet
      //-----------------------------------------------------------------------------------numberOfSecondsSince1900Epoch
      unsigned long int numberOfSecondsSince1900Epoch(uint16_t y, uint8_t m, uint8_t d, uint8_t h, uint8_t mm, uint8_t s) {
        if (y >= 1970)
          y -= 1970;
        uint16_t daysLocal = d;
        for (uint8_t i = 1; i < m; ++i)  daysLocal += daysInMonth[i - 1];
      //  for (uint8_t i = 1; i < m; ++i)
      //    daysLocal += pgm_read_byte(daysInMonth + i - 1);
        if (m > 2 && y % 4 == 0)
          ++daysLocal;
        daysLocal += 365 * y + (y + 3) / 4 - 1;
        return daysLocal*24L*3600L + h*3600L + mm*60L + s + seventyYears;
      //-----------------------------------------------------------------------------------processNTP
      void processNTP() {
        Udp.read(packetBuffer,NTP_PACKET_SIZE);
        IPAddress Remote = Udp.remoteIP();
        int PortNum = Udp.remotePort();
      if (debug) {
        Serial.println();
        Serial.print("Received UDP packet size ");
        Serial.println(packetSize);
        Serial.print("From ");
        for (int i =0; i < 4; i++)
          Serial.print(Remote[i], DEC);
          if (i < 3)
            Serial.print(".");
        Serial.print(", port ");
        Serial.print(PortNum);
        byte LIVNMODE = packetBuffer[0];
        Serial.print("  LI, Vers, Mode :");
        Serial.print(packetBuffer[0],HEX);
        byte STRATUM = packetBuffer[1];
        Serial.print("  Stratum :");
        Serial.print(packetBuffer[1],HEX);
        byte POLLING = packetBuffer[2];
        Serial.print("  Polling :");
        Serial.print(packetBuffer[2],HEX);
        byte PRECISION = packetBuffer[3];
        Serial.print("  Precision :");
        Serial.println(packetBuffer[3],HEX);
        for (int z = 0; z < NTP_PACKET_SIZE; z++) {
          Serial.print(packetBuffer[z],HEX);
          if (((z+1) % 4) == 0) {
            Serial.println();
        Serial.println();
      } // end of debug statements
        packetBuffer[0] = 0b00100100;   // LI, Version, Mode
        packetBuffer[1] = 1 ;   // stratum
        packetBuffer[2] = 6 ;   // polling minimum
        packetBuffer[3] = 0xFA; // precision
        packetBuffer[7] = 0; // root delay
        packetBuffer[8] = 0;
        packetBuffer[9] = 8;
        packetBuffer[10] = 0;
        packetBuffer[11] = 0; // root dispersion
        packetBuffer[12] = 0;
        packetBuffer[13] = 0xC;
        packetBuffer[14] = 0;
          uint16_t y=year();
          uint8_t m=month();
          uint8_t d=day();
          uint8_t h=hour();
          uint8_t mm=minute();
          uint8_t s=second();
        if (y >= 1970) y -= 1970;
        if (m > 2 && y % 4 == 0) ++daysLocal;
        timestamp1970 = daysLocal*24L*3600L + h*3600L + mm*60L + s + seventyYears;
      //    uint16_t utcYY=year();
      //    uint8_t utcMM=month();
      //    uint8_t utcDD=day();
      //    uint8_t utchh=hour();
      //    uint8_t utcmm=minute();
      //    uint8_t utcss=second();
      //  timestamp1970 = numberOfSecondsSince1900Epoch(utcYY,utcMM,utcDD,utchh,utcmm,utcss);
      //  timestamp1970 = numberOfSecondsSince1900Epoch(2022,4,30,10,10,10);
      timestamp1970 = numberOfSecondsSince1900Epoch(year(),month(),day(),hour(),minute(),second());
          tinyGPS.date.year(),
          tinyGPS.date.day(),
        unsigned long tempval = timestamp1970;
        packetBuffer[12] = 71; //"G";
        packetBuffer[13] = 80; //"P";
        packetBuffer[14] = 83; //"S";
        packetBuffer[15] = 0; //"0";
        // reference timestamp1970
        packetBuffer[16] = (tempval >> 24) & 0XFF;
        packetBuffer[17] = (tempval >> 16) & 0xFF;
        packetBuffer[18] = (tempval >> 8) & 0xFF;
        packetBuffer[19] = (tempval) & 0xFF;
        packetBuffer[20] = 0;
        packetBuffer[21] = 0;
        packetBuffer[22] = 0;
        packetBuffer[23] = 0;
        //copy originate timestamp from incoming UDP transmit timestamp
        packetBuffer[24] = packetBuffer[40];
        packetBuffer[25] = packetBuffer[41];
        packetBuffer[26] = packetBuffer[42];
        packetBuffer[27] = packetBuffer[43];
        packetBuffer[28] = packetBuffer[44];
        packetBuffer[29] = packetBuffer[45];
        packetBuffer[30] = packetBuffer[46];
        packetBuffer[31] = packetBuffer[47];
        //receive timestamp
        packetBuffer[32] = (tempval >> 24) & 0XFF;
        packetBuffer[33] = (tempval >> 16) & 0xFF;
        packetBuffer[34] = (tempval >> 8) & 0xFF;
        packetBuffer[35] = (tempval) & 0xFF;
        packetBuffer[36] = 0;
        packetBuffer[37] = 0;
        packetBuffer[38] = 0;
        packetBuffer[39] = 0;
        //transmitt timestamp
        packetBuffer[40] = (tempval >> 24) & 0XFF;
        packetBuffer[41] = (tempval >> 16) & 0xFF;
        packetBuffer[42] = (tempval >> 8) & 0xFF;
        packetBuffer[43] = (tempval) & 0xFF;
        packetBuffer[44] = 0;
        packetBuffer[45] = 0;
        packetBuffer[46] = 0;
        packetBuffer[47] = 0;
        // Reply to the IP address and port that sent the NTP request
        Udp.beginPacket(Remote, PortNum);
        Udp.write(packetBuffer,NTP_PACKET_SIZE);
        Udp.endPacket();
      #else
      void processNTP() {}
