<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[hlk-pm01 are to noisy for rfm69?]]></title><description><![CDATA[<p dir="auto">Hello . it's the 3rd node that i build with the combo arduino promini 3.3v + hlk-pm01 + rfm69 and all need wire ground to earth (on wallsocket)  to let rfm69 comunicate.<br />
otherwise will fail on every comunication even near Gateway...<br />
Personally i only think in noise.but everyone say that hlk-pm01 are low noise.<br />
I'm not using any cap after hlk-pm01 for snooth voltage but i already try it before without better result.<br />
rfm69 is powered by the pro mini integrated regulator.<br />
Any one had this problem?</p>
]]></description><link>https://forum.mysensors.org/topic/12178/hlk-pm01-are-to-noisy-for-rfm69</link><generator>RSS for Node</generator><lastBuildDate>Sat, 05 Sep 2026 08:23:22 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/12178.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 05 Aug 2023 21:16:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to hlk-pm01 are to noisy for rfm69? on Wed, 09 Aug 2023 16:28:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tmaster" aria-label="Profile: Tmaster">@<bdi>Tmaster</bdi></a> Never assume the original PCB was just a circuit of components, the PCB can incorporate RF shields and antenna radio ground planes...</p>
]]></description><link>https://forum.mysensors.org/post/113830</link><guid isPermaLink="true">https://forum.mysensors.org/post/113830</guid><dc:creator><![CDATA[zboblamont]]></dc:creator><pubDate>Wed, 09 Aug 2023 16:28:45 GMT</pubDate></item><item><title><![CDATA[Reply to hlk-pm01 are to noisy for rfm69? on Wed, 09 Aug 2023 15:56:21 GMT]]></title><description><![CDATA[<p dir="auto">Maybe you are right and it's the proximity to a switching tranformer like this hlk-pm01 .They are all on same protoboard aprox 50x60mm.  i could build a sheld on it but....now its working with the rfm69version W ok for a few days.<br />
The strange part is this combo was very used a few years now on  made pcbs the on forum wher they had the maker/developer contest and never seen a line of this problem...</p>
]]></description><link>https://forum.mysensors.org/post/113829</link><guid isPermaLink="true">https://forum.mysensors.org/post/113829</guid><dc:creator><![CDATA[Tmaster]]></dc:creator><pubDate>Wed, 09 Aug 2023 15:56:21 GMT</pubDate></item><item><title><![CDATA[Reply to hlk-pm01 are to noisy for rfm69? on Mon, 07 Aug 2023 14:02:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tmaster" aria-label="Profile: Tmaster">@<bdi>Tmaster</bdi></a> It would certainly imply the PSU or mains are causing noise to appear, but it could be on anywhere in the combination, but it's not necessarily at the rfm itself.<br />
I'd surmise your problem is related to proximity of the psu or mains power.<br />
eg - I have 3 un-shielded nodes with rfm69 variations running on 5v wall wart PSUs and battery backup and never had a single problem - The difference to your scenario is that the closest PSU and mains is 250mm away.<br />
One has been running on an old Nokia "charger" and USB breakout now for 6 years straight between power cuts (and christ almighty we do get them) yet it is still going strong.</p>
<p dir="auto">Perhaps reconsider your chosen method of supplying shore-power... ;)</p>
]]></description><link>https://forum.mysensors.org/post/113827</link><guid isPermaLink="true">https://forum.mysensors.org/post/113827</guid><dc:creator><![CDATA[zboblamont]]></dc:creator><pubDate>Mon, 07 Aug 2023 14:02:19 GMT</pubDate></item><item><title><![CDATA[Reply to hlk-pm01 are to noisy for rfm69? on Sun, 06 Aug 2023 16:17:42 GMT]]></title><description><![CDATA[<p dir="auto">i believe this problem has to be with rfm69CW and not the rfm69W  . i have boot versions 868mhz  and normally always the CW cause me this issues if is not batery powered even with 100uf +100nf caps filtering on transformer out, caps on the rfm60 power etc...    maybe they are fake or have any problem. .   i just ordered new rfm69W board and let me see if get better. right now i have like 10 nodes running outdoor on irrigation ,controlling relays and lights ,and metering temperatures. all with RFM69W ans HW ,this CW always give problems...</p>
]]></description><link>https://forum.mysensors.org/post/113826</link><guid isPermaLink="true">https://forum.mysensors.org/post/113826</guid><dc:creator><![CDATA[Tmaster]]></dc:creator><pubDate>Sun, 06 Aug 2023 16:17:42 GMT</pubDate></item></channel></rss>
