<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Which gateway to choose Serial, Ethernet or MQTT?]]></title><description><![CDATA[<p dir="auto">I'm currently running OpenHab on RPi2. I was looking at some other controller option just out of curiosity. Some of them support Serial and/or Ethernet gateway.</p>
<p dir="auto">I'm wondering for ex. I want to try out Domoticz. It supports Serial and Ethernet. So, which one should I choose? Does it matter? Serial is better choice over ethernet or vice-versa?</p>
<p dir="auto">would be great if you can shed some light on this. Thanks!</p>
]]></description><link>https://forum.mysensors.org/topic/1232/which-gateway-to-choose-serial-ethernet-or-mqtt</link><generator>RSS for Node</generator><lastBuildDate>Tue, 17 Mar 2026 03:33:42 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/1232.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 10 Apr 2015 06:40:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Which gateway to choose Serial, Ethernet or MQTT? on Tue, 14 Apr 2015 16:36:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/timo" aria-label="Profile: TimO">@<bdi>TimO</bdi></a> Thanks, I will try this.</p>
]]></description><link>https://forum.mysensors.org/post/12707</link><guid isPermaLink="true">https://forum.mysensors.org/post/12707</guid><dc:creator><![CDATA[kunall]]></dc:creator><pubDate>Tue, 14 Apr 2015 16:36:15 GMT</pubDate></item><item><title><![CDATA[Reply to Which gateway to choose Serial, Ethernet or MQTT? on Tue, 14 Apr 2015 13:13:53 GMT]]></title><description><![CDATA[<p dir="auto">Maybe this helps: <a href="http://forum.mysensors.org/topic/1194/tutorial-openhab-with-serial-gateway" rel="nofollow ugc">http://forum.mysensors.org/topic/1194/tutorial-openhab-with-serial-gateway</a></p>
<p dir="auto">:D</p>
]]></description><link>https://forum.mysensors.org/post/12691</link><guid isPermaLink="true">https://forum.mysensors.org/post/12691</guid><dc:creator><![CDATA[TimO]]></dc:creator><pubDate>Tue, 14 Apr 2015 13:13:53 GMT</pubDate></item><item><title><![CDATA[Reply to Which gateway to choose Serial, Ethernet or MQTT? on Tue, 14 Apr 2015 09:13:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kolaf" aria-label="Profile: kolaf">@<bdi>kolaf</bdi></a> If you could find, that would be very helpful. Thanks!</p>
]]></description><link>https://forum.mysensors.org/post/12686</link><guid isPermaLink="true">https://forum.mysensors.org/post/12686</guid><dc:creator><![CDATA[kunall]]></dc:creator><pubDate>Tue, 14 Apr 2015 09:13:51 GMT</pubDate></item><item><title><![CDATA[Reply to Which gateway to choose Serial, Ethernet or MQTT? on Mon, 13 Apr 2015 04:49:09 GMT]]></title><description><![CDATA[<p dir="auto">There should be a recent topic on this somewhere in the forum. I can look it up when I'm at the computer later.</p>
]]></description><link>https://forum.mysensors.org/post/12647</link><guid isPermaLink="true">https://forum.mysensors.org/post/12647</guid><dc:creator><![CDATA[kolaf]]></dc:creator><pubDate>Mon, 13 Apr 2015 04:49:09 GMT</pubDate></item><item><title><![CDATA[Reply to Which gateway to choose Serial, Ethernet or MQTT? on Sun, 12 Apr 2015 22:14:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rvendrame" aria-label="Profile: rvendrame">@<bdi>rvendrame</bdi></a> That is definitely a plus point. For me the question is, if serial gateway works with RPi + OpenHab?</p>
]]></description><link>https://forum.mysensors.org/post/12645</link><guid isPermaLink="true">https://forum.mysensors.org/post/12645</guid><dc:creator><![CDATA[kunall]]></dc:creator><pubDate>Sun, 12 Apr 2015 22:14:38 GMT</pubDate></item><item><title><![CDATA[Reply to Which gateway to choose Serial, Ethernet or MQTT? on Sun, 12 Apr 2015 22:12:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kolaf" aria-label="Profile: kolaf">@<bdi>kolaf</bdi></a> Great, Thanks for the response. The serial gateway sound a good option to me. I'm using RPi2 with OpenHab. Would you happen to have any tutorial link where I can look learn the to connect serial gateway to RPi with Openhab? Do I still need MQTT with serial gateway?</p>
<p dir="auto">PS: I'm new to all this and do not hesitate to ask questions. Hope thats okay. :)</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.mysensors.org/post/12644</link><guid isPermaLink="true">https://forum.mysensors.org/post/12644</guid><dc:creator><![CDATA[kunall]]></dc:creator><pubDate>Sun, 12 Apr 2015 22:12:09 GMT</pubDate></item><item><title><![CDATA[Reply to Which gateway to choose Serial, Ethernet or MQTT? on Sun, 12 Apr 2015 22:04:49 GMT]]></title><description><![CDATA[<p dir="auto">I use my Serial gateway plugged on my Vera-Lite USB port, no issues when rebooting.  Serial port is always there as it should.</p>
]]></description><link>https://forum.mysensors.org/post/12643</link><guid isPermaLink="true">https://forum.mysensors.org/post/12643</guid><dc:creator><![CDATA[rvendrame]]></dc:creator><pubDate>Sun, 12 Apr 2015 22:04:49 GMT</pubDate></item><item><title><![CDATA[Reply to Which gateway to choose Serial, Ethernet or MQTT? on Sun, 12 Apr 2015 22:02:05 GMT]]></title><description><![CDATA[<p dir="auto">How could you deal with the need of 'restarting' the arduino (USB) after server reboots?<br />
I use Domoticz on OrangePI and when it reboots, the arduino is powered all the time, so it doesn't see serial arduino port after reboot.</p>
]]></description><link>https://forum.mysensors.org/post/12642</link><guid isPermaLink="true">https://forum.mysensors.org/post/12642</guid><dc:creator><![CDATA[andriej]]></dc:creator><pubDate>Sun, 12 Apr 2015 22:02:05 GMT</pubDate></item><item><title><![CDATA[Reply to Which gateway to choose Serial, Ethernet or MQTT? on Sat, 11 Apr 2015 18:15:51 GMT]]></title><description><![CDATA[<p dir="auto">... and the serial gateway usually is powered by the host USB computer/controller,  while the ethernet gateway requires its own power adapter.</p>
<p dir="auto">Just adding my two cents  ;-)</p>
]]></description><link>https://forum.mysensors.org/post/12612</link><guid isPermaLink="true">https://forum.mysensors.org/post/12612</guid><dc:creator><![CDATA[rvendrame]]></dc:creator><pubDate>Sat, 11 Apr 2015 18:15:51 GMT</pubDate></item><item><title><![CDATA[Reply to Which gateway to choose Serial, Ethernet or MQTT? on Fri, 10 Apr 2015 21:00:01 GMT]]></title><description><![CDATA[<p dir="auto">I guess it mostly depends on what you have available and where you want to place the Gateway. With the serial option you have to have the Gateway quite close to your computer, while with the ethernet option you can have them further apart.</p>
<p dir="auto">On the other hand, the ethernet option can be more expensive than the serial option since you need an ethernet adapter for the gateway.</p>
<p dir="auto">For my part I'm quite happy using the serial Gateway together with OpenHAB (earlier) and now testing it with Domoticz without any problems.</p>
]]></description><link>https://forum.mysensors.org/post/12589</link><guid isPermaLink="true">https://forum.mysensors.org/post/12589</guid><dc:creator><![CDATA[kolaf]]></dc:creator><pubDate>Fri, 10 Apr 2015 21:00:01 GMT</pubDate></item></channel></rss>
