  3. OpenHAB
  4. openhab controlling rc switch on raspberry pi
rc switchopenhab
6 Posts 3 Posters 4.4k Views 4 Watching
  • siodS
    siodS
    siod
    Hi guys,
    I would like to control a rc switch using my raspberry pi where openhab is also hosted. I already configured everything and it is working fine from shell e.g. as user pi I have to enter
    sudo /opt/rcswitch-pi/send 00001 5 1
    to turn the rc switch on. Now I tried to integrate this into openhab, without success. I added the following line to my home.items file:
    Switch Light_FF_Test 		"Test Funksteckdose"	(FF_Test, Lights)	{exec="OFF:sudo /opt/rcswitch-pi/send 00001 5 0, ON:sudo /opt/rcswitch-pi/send 00001 5 1"}
    I see openhab gets the command (log file) but it does not switch the rc switch. Any suggestions? Thank you!!
    still learning...
    • T
      TimO
      Is the user, that runs OH allowed to sudo?
      • siodS
        siodS
        siod
        For testing purposes I use the root user, I guess he should be able to sudo!? But I'm a total Linux noob...
        still learning...
        • J
          J
          Jan Gatzke
          Did you install the exec addon?
          siodS 1 Reply Last reply
          • T
            TimO
            If OH is running as root you don't need to sudo. Haven't tried to sudo as root yet. :-)
            If OH is running with a deamon user, which certainly makes sense for production, this user may not be allowed to sudo.
            • J Jan Gatzke
              siodS
              siodS
              siod
              Thank you Sir!
              was asking in a different forum as well, nobody had the idea to install this binding first and I didn´t know a binding is needed for execution of commands...
              Well then, problem solved :+1: :)
              still learning...
