<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Will the Arduino mini 3.3v give enough stable power for nRF ?]]></title><description><![CDATA[<p dir="auto">Hello all,</p>
<p dir="auto">As mentioned in topic, I want to know if the 3.3v version will give enough and stable power for the nrf ?<br />
Also what is the totoal maximum power consumption which the mini can support if I want also to power up transistors or TRIACs ?</p>
<p dir="auto">Thank you.</p>
]]></description><link>https://forum.mysensors.org/topic/2254/will-the-arduino-mini-3-3v-give-enough-stable-power-for-nrf</link><generator>RSS for Node</generator><lastBuildDate>Tue, 18 Aug 2026 18:18:06 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/2254.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 25 Oct 2015 22:36:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Will the Arduino mini 3.3v give enough stable power for nRF ? on Mon, 26 Oct 2015 21:47:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rvendrame" aria-label="Profile: rvendrame">@<bdi>rvendrame</bdi></a> Does the mysensors library use high power modes on the nrf? As far as I remember these can use much more power.</p>
]]></description><link>https://forum.mysensors.org/post/23503</link><guid isPermaLink="true">https://forum.mysensors.org/post/23503</guid><dc:creator><![CDATA[LastSamurai]]></dc:creator><pubDate>Mon, 26 Oct 2015 21:47:01 GMT</pubDate></item><item><title><![CDATA[Reply to Will the Arduino mini 3.3v give enough stable power for nRF ? on Mon, 26 Oct 2015 14:34:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rvendrame" aria-label="Profile: rvendrame">@<bdi>rvendrame</bdi></a> Great. That's so clear.<br />
Thank you.</p>
]]></description><link>https://forum.mysensors.org/post/23481</link><guid isPermaLink="true">https://forum.mysensors.org/post/23481</guid><dc:creator><![CDATA[ahmedadelhosni]]></dc:creator><pubDate>Mon, 26 Oct 2015 14:34:20 GMT</pubDate></item><item><title><![CDATA[Reply to Will the Arduino mini 3.3v give enough stable power for nRF ? on Mon, 26 Oct 2015 11:46:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ahmedadelhosni" aria-label="Profile: ahmedadelhosni">@<bdi>ahmedadelhosni</bdi></a> ,  for a definitive answer you must check what kind of regulator your board has, as well as how much each component of your circuit will consume.</p>
<p dir="auto">The <a href="https://www.arduino.cc/en/uploads/Main/Arduino-Pro-Mini-schematic.pdf" rel="nofollow ugc">official pro-mini</a> uses an <a href="http://www.micrel.com/_PDF/mic5205.pdf" rel="nofollow ugc">MIC5205</a> voltage regulator that can deliver maximum of  150mA.</p>
<p dir="auto">Most clones uses a cheaper regulator (such as the 100mA <a href="http://www.ti.com/lit/ds/symlink/lp2981a-30.pdf" rel="nofollow ugc">LP2981</a> that I found in my pro-minis).</p>
<p dir="auto">The official nRF24l01 radio consumes about 15mA while transmitting/receiving.  You have to add on top of it the arduino itself, as well as any other components that you are powering up.</p>
<p dir="auto">And to be on safe side I would not use more than 60-70% of nominal regulator's output.</p>
<p dir="auto">Hope it helps...</p>
]]></description><link>https://forum.mysensors.org/post/23475</link><guid isPermaLink="true">https://forum.mysensors.org/post/23475</guid><dc:creator><![CDATA[rvendrame]]></dc:creator><pubDate>Mon, 26 Oct 2015 11:46:12 GMT</pubDate></item></channel></rss>
