  3. Wind speed sensor node
21 Posts 5 Posters 12.5k Views 4 Watching
  • JohanRCJ
    JohanRCJ
    JohanRC
    wrote on last edited by JohanRC
    #21
    Yesterday I found some example code on the Domoticz forum.
    With some modifications I get numbers in wind :smiley:
    As below my current sketch that sends values, I will modify it untill it is what I like and will post it here.
    #define CHILD_ID_WIND 20
    #define LED_PIN 8
    #define ID_WIND 170
    #define WIND_SENSOR_ANALOG_PIN 1
    unsigned int val_wspeed;
    unsigned int val_wgust;
    unsigned int val_wdirection;
    unsigned int last_wspeed;
    unsigned int last_wgust;
    unsigned int last_wdirection;
    boolean metric = true;
    unsigned long currentTime;
    unsigned long SEND_FREQUENCY = 10000;
    unsigned long lastSend;
    MyMessage msgWSpeed(CHILD_ID_WIND, V_WIND);
    MyMessage msgWGust(CHILD_ID_WIND, V_GUST);
    MyMessage msgWDirection(CHILD_ID_WIND, V_DIRECTION);
    //Setup routine
      gw.begin();
      gw.sendSketchInfo("Windsensor", "0.1");
      gw.present(CHILD_ID_WIND, S_WIND);
      lastSend = 0;
      pinMode(LED_PIN, OUTPUT);
      digitalWrite(LED_PIN,1);
    //Main loop
      gw.process();
      currentTime = millis();
      unsigned int val_wspeed = (analogRead(WIND_SENSOR_ANALOG_PIN))/31.605;
        if(last_wspeed != val_wspeed)
           last_wspeed = val_wspeed;
           gw.send(msgWSpeed.set(val_wspeed, 1));
           Serial.print("WS: ");
           Serial.println(val_wspeed);
        unsigned int val_wgust = (analogRead(WIND_SENSOR_ANALOG_PIN))/31.605;
        if(last_wgust != val_wgust)
           last_wgust = val_wgust;
           gw.send(msgWGust.set(val_wgust, 1));
           Serial.print("WG: ");
           Serial.println(val_wgust);
        unsigned int val_wdirection = (analogRead(WIND_SENSOR_ANALOG_PIN))/2.842;
        if(last_wdirection != val_wdirection)
           last_wdirection = val_wdirection;
           gw.send(msgWDirection.set(val_wdirection, 1));
           Serial.print("WD: ");
           Serial.println(val_wdirection);
    RaspberryPi Domoticz - Serial gateway - 12 nodes and counting
