<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[WifiGateway crashes after 1 or 2 days]]></title><description><![CDATA[<p dir="auto">Any ideas how o solve that problem ?<br />
I built a WifiGateway, after 1 - 2 days,  it crashes, i can´t reach it through telnet<br />
But a ping is still working.</p>
<p dir="auto">As it tkaes that long, it´s not that easy to find the problem</p>
<p dir="auto">Is there any debug feature ?</p>
]]></description><link>https://forum.mysensors.org/topic/3050/wifigateway-crashes-after-1-or-2-days</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 01:37:27 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/3050.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 05 Feb 2016 20:09:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to WifiGateway crashes after 1 or 2 days on Sun, 14 Feb 2016 21:39:34 GMT]]></title><description><![CDATA[<p dir="auto">i investigated further:<br />
i have 2 gateways, both dev version, one from today, the other one about 2 weeks old</p>
<p dir="auto">I tried the relay sketch (newest dev version) - gave it an ID trough my ethernet gateway<br />
--&gt; directly after connecting the relay sensor both ESP gateway crash - no fault messages in serial monitor</p>
<p dir="auto">DId anybody try the wifi gateway together with a repeater ?</p>
]]></description><link>https://forum.mysensors.org/post/31658</link><guid isPermaLink="true">https://forum.mysensors.org/post/31658</guid><dc:creator><![CDATA[kr0815]]></dc:creator><pubDate>Sun, 14 Feb 2016 21:39:34 GMT</pubDate></item><item><title><![CDATA[Reply to WifiGateway crashes after 1 or 2 days on Sun, 14 Feb 2016 13:20:15 GMT]]></title><description><![CDATA[<p dir="auto">I still have the same problem, it worked now for about 5 days on the workbench, brought it to the final desination, crashes after some hours</p>
<p dir="auto">But i always could still ping the ESP</p>
<p dir="auto">What i wonder most about is, that sometimes when i replug the power it says radio init ok, but it doesn´t receive messages<br />
( i see on other gateway that messages are definetly sent)</p>
<p dir="auto">Is there any possibility to restart the gateway remotely ? Or only chance to replug power ?<br />
Could it be it´s a problem with the initialization of the radio ?</p>
<p dir="auto">Is it maybe because in my set-up, the gateway is only receiving, never sending anything ?</p>
<p dir="auto">The gateway lays avbout one meter away from a raspberry (no wifi) , but i can´t imagine that causes the problems ?</p>
<p dir="auto">Any help / ideas welcome.</p>
]]></description><link>https://forum.mysensors.org/post/31604</link><guid isPermaLink="true">https://forum.mysensors.org/post/31604</guid><dc:creator><![CDATA[kr0815]]></dc:creator><pubDate>Sun, 14 Feb 2016 13:20:15 GMT</pubDate></item><item><title><![CDATA[Reply to WifiGateway crashes after 1 or 2 days on Sun, 07 Feb 2016 20:12:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kr0815" aria-label="Profile: kr0815">@<bdi>kr0815</bdi></a> said:</p>
<blockquote>
<p dir="auto">the ESP side</p>
</blockquote>
<p dir="auto">I mean that when a connection is disconnected abruptly, the socket connection might also not be closed correctly on the ESP side.<br />
It can go wrong on either the server or the client side; I don't know.</p>
]]></description><link>https://forum.mysensors.org/post/30989</link><guid isPermaLink="true">https://forum.mysensors.org/post/30989</guid><dc:creator><![CDATA[Yveaux]]></dc:creator><pubDate>Sun, 07 Feb 2016 20:12:39 GMT</pubDate></item><item><title><![CDATA[Reply to WifiGateway crashes after 1 or 2 days on Sun, 07 Feb 2016 19:51:17 GMT]]></title><description><![CDATA[<p dir="auto">Sorry, this i don´t understand ? What do you mean wth by the ESP side ? Changes in the ESP Code needed ?<br />
The more i think about it, the less i know...<br />
WHat causes the Wifi Gateway sometines after replugging power to say radio init ok, but not receiving messages ?</p>
]]></description><link>https://forum.mysensors.org/post/30982</link><guid isPermaLink="true">https://forum.mysensors.org/post/30982</guid><dc:creator><![CDATA[kr0815]]></dc:creator><pubDate>Sun, 07 Feb 2016 19:51:17 GMT</pubDate></item><item><title><![CDATA[Reply to WifiGateway crashes after 1 or 2 days on Sun, 07 Feb 2016 19:21:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kr0815" aria-label="Profile: kr0815">@<bdi>kr0815</bdi></a> Could also be caused by the ESP side, keep that in mind. Maybe search around for  'closed connections' w.r.t. ESP.</p>
]]></description><link>https://forum.mysensors.org/post/30970</link><guid isPermaLink="true">https://forum.mysensors.org/post/30970</guid><dc:creator><![CDATA[Yveaux]]></dc:creator><pubDate>Sun, 07 Feb 2016 19:21:19 GMT</pubDate></item><item><title><![CDATA[Reply to WifiGateway crashes after 1 or 2 days on Sun, 07 Feb 2016 19:18:51 GMT]]></title><description><![CDATA[<p dir="auto">Maybe you are right<br />
I set up two gateways, only one is connected to FHEM, now i swapped them in FHEM, the connected one crashed<br />
I´ll ask the FHEM guys for help, but as long as i´m playing with putty, is there any command to check / close connections ?<br />
Is it ok just to close putty, or should i send something to close the connection ?</p>
]]></description><link>https://forum.mysensors.org/post/30968</link><guid isPermaLink="true">https://forum.mysensors.org/post/30968</guid><dc:creator><![CDATA[kr0815]]></dc:creator><pubDate>Sun, 07 Feb 2016 19:18:51 GMT</pubDate></item><item><title><![CDATA[Reply to WifiGateway crashes after 1 or 2 days on Sun, 07 Feb 2016 19:11:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kr0815" aria-label="Profile: kr0815">@<bdi>kr0815</bdi></a> said:</p>
<blockquote>
<p dir="auto">my FHEM - installation and me playing around with one, max 2 instances of putty</p>
</blockquote>
<p dir="auto">It could still be that 5 or more connections are open simultaneously, when e.g. a connection is dropped and not nicely shut down before a new one is opened.</p>
]]></description><link>https://forum.mysensors.org/post/30965</link><guid isPermaLink="true">https://forum.mysensors.org/post/30965</guid><dc:creator><![CDATA[Yveaux]]></dc:creator><pubDate>Sun, 07 Feb 2016 19:11:09 GMT</pubDate></item><item><title><![CDATA[Reply to WifiGateway crashes after 1 or 2 days on Sun, 07 Feb 2016 19:07:39 GMT]]></title><description><![CDATA[<p dir="auto">Thanks a lot for your help, it´s really frustrating :-)</p>
<p dir="auto">unfortunately, there are notr more than 5 connections, only my FHEM - installation and me playing around with one, max 2 instances of putty</p>
<p dir="auto">but as i´m experimenting with it right now it looks like there is a problem with the radio</p>
<p dir="auto">I tried re-pluging power many times, sometimes i get in in a state where it says "radio init ok", but doesn´t receive messages</p>
<p dir="auto">I re-checked all the wires (only 10K Pull-Down at GPIO15 , the other lines to Radio are in Mega-Ohm Areas, so no wrong resistors on my ESP-Board)<br />
I tried to add small / large capacitors to the Vcc Line<br />
I swapped the NRF2401 - 3 different batches now, which even look different.<br />
I swapped the wall-wart to a regulated laboratory power supply<br />
--&gt; all the same result</p>
<p dir="auto">I have about 5 of these ESP-Boards running with ESP-Easy since weeks, so i can´t imagine it´s a fake ESP-Unit ?</p>
<p dir="auto">Any further ideas what to try ?</p>
]]></description><link>https://forum.mysensors.org/post/30962</link><guid isPermaLink="true">https://forum.mysensors.org/post/30962</guid><dc:creator><![CDATA[kr0815]]></dc:creator><pubDate>Sun, 07 Feb 2016 19:07:39 GMT</pubDate></item><item><title><![CDATA[Reply to WifiGateway crashes after 1 or 2 days on Sun, 07 Feb 2016 18:41:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kr0815" aria-label="Profile: kr0815">@<bdi>kr0815</bdi></a> said:</p>
<blockquote>
<p dir="auto">LmacRxBlk</p>
</blockquote>
<p dir="auto">Googled, <a href="https://github.com/esp8266/Arduino/issues/928" rel="nofollow ugc">this</a> came up.<br />
Here they say it's related to the maximum simultaneous socket connections to the ESP, which is set to 5 in hardware.<br />
Could it be that you open more than 5 sockets simultaneously?</p>
]]></description><link>https://forum.mysensors.org/post/30952</link><guid isPermaLink="true">https://forum.mysensors.org/post/30952</guid><dc:creator><![CDATA[Yveaux]]></dc:creator><pubDate>Sun, 07 Feb 2016 18:41:35 GMT</pubDate></item><item><title><![CDATA[Reply to WifiGateway crashes after 1 or 2 days on Sun, 07 Feb 2016 16:38:23 GMT]]></title><description><![CDATA[<p dir="auto">Hello Yveaux,</p>
<p dir="auto">i tried to debug with serial connected, but</p>
<p dir="auto">for hours only that:</p>
<pre><code>0;255;3;0;9;read: 102-102-0 s=1,c=1,t=0,pt=7,l=5,sg=0:19.0
0;255;3;0;9;read: 102-102-0 s=0,c=1,t=1,pt=7,l=5,sg=0:43.9
0;255;3;0;9;read: 102-102-0 s=255,c=3,t=0,pt=1,l=1,sg=0:95
0;255;3;0;9;read: 112-112-0 s=0,c=1,t=0,pt=7,l=5,sg=0:24.0
0;255;3;0;9;read: 112-112-0 s=1,c=1,t=0,pt=7,l=5,sg=0:23.9
</code></pre>
<p dir="auto">then not responsible, no fault message</p>
<p dir="auto">after waiting for a while i get</p>
<pre><code>LmacRxBlk:1
LmacRxBlk:1
LmacRxBlk:1
LmacRxBlk:1
LmacRxBlk:1
LmacRxBlk:1
LmacRxBlk:1
LmacRxBlk:1
</code></pre>
<p dir="auto">After a reboot:</p>
<pre><code>0;255;3;0;9;Starting gateway (RNNGE-, 2.0.0-beta)
0;255;3;0;9;Radio init successful.
....scandone
state: 0 -&gt; 2 (b0)
.state: 2 -&gt; 3 (0)
state: 3 -&gt; 5 (10)
add 0
aid 3
pm open phy_2,type:2 0 0
cnt
chg_B:-60
connected with Power-LAN, channel 6
dhcp client start...
...ip:192.168.178.84,mask:255.255.255.0,gw:192.168.178.1
.IP: 192.168.178.84
0;255;3;0;9;Init complete, id=0, parent=0, distance=0
0;255;3;0;9;read: 111-111-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
0;255;3;0;9;read: 111-111-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
</code></pre>
]]></description><link>https://forum.mysensors.org/post/30942</link><guid isPermaLink="true">https://forum.mysensors.org/post/30942</guid><dc:creator><![CDATA[kr0815]]></dc:creator><pubDate>Sun, 07 Feb 2016 16:38:23 GMT</pubDate></item><item><title><![CDATA[Reply to WifiGateway crashes after 1 or 2 days on Sat, 06 Feb 2016 07:43:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kr0815" aria-label="Profile: kr0815">@<bdi>kr0815</bdi></a> best debug option is to connect something to the serial port (before the crash) and watch the logs.<br />
I've seen similar behavior on a regular Ethernet getaway, so not sure if it's really WiFi gateway related.</p>
]]></description><link>https://forum.mysensors.org/post/30785</link><guid isPermaLink="true">https://forum.mysensors.org/post/30785</guid><dc:creator><![CDATA[Yveaux]]></dc:creator><pubDate>Sat, 06 Feb 2016 07:43:04 GMT</pubDate></item></channel></rss>
