  3. OpenHAB
  4. Trouble sending message to Relay from Openhab
5 Posts 3 Posters 3.8k Views 4 Watching
  • Ericb2745E
    Ericb2745E
    Ericb2745
    Simply put I am trying to send a message from Openhab to a MySensors sensor via a Serial Gateway.
    My environment is Openhab 1.7 running on RPi 3. I have a stock Serial Gateway running on Nano using RF24. I have two sensors DHT and micro switch sending data to the gateway and values are appearing in Openhab fine. For about week now I have been trying to turn the communication around. In Openhab I have configured an Switch Item called Relay. When it changes from Off to On I have a rule to send a command to the Arduino gateway item. However the message never shows up on the sensor. Any advice would be appreciated.
    Here is some of the code, config, and logs:
    Relay Sensor:
    #include <EEPROM.h>
    #include <MySigningNone.h>
    #include <MyTransportNRF24.h>
    #include <MyTransportRFM69.h>
    #include <MyHwATMega328.h>
    //MyTransportRFM69 radio;
    //MySigningNone signer;
    MyHwATMega328 hw;
    MySensor gw(radio, hw);
      //Wipe eprom
      for (int i = 0 ; i < EEPROM.length() ; i++) {
        EEPROM.write(i, 0);
      gw.begin(incomingMessage, 105, true);
      gw.sendSketchInfo("Relay", "1.0");
      // Fetch relay status
        gw.present(sensor, S_LIGHT);
        pinMode(pin, OUTPUT);
        digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
      gw.process();
      Serial.println("message received");
    arduino items
    String Arduino "Arduino" { serial="/dev/ttyUSB0@115200" }
    Contact Garage_Door             "Garage Door [MAP(en.map):%s]"          (gGarage, Windows)
    Number Temperature_Basement     "Temperature [%.1f F]"  <temperature>   (Temperature, gBasement)
    Number Humidity_Basement        "Humidity [%.1f %%]"    <temperature>   (gBasement)
    Switch Relay          "Relay"  (gBasement)
    test.rules
    import org.openhab.core.library.types.*
    rule "Send Relay Arduino Command"
    when
            Item Relay changed from OFF to ON
    then
            logInfo("FILE","Entering Rule: Send Relay Arduino Command")
            sendCommand(Arduino, "105;2;1;0;2;1\n")
    end
    openhab.log during registration
    2016-04-24 11:51:57.728 [INFO ] [org.openhab.model.script.FILE ] - nodeId: 105 childId: 255 msgType: 3 subType: 6 msg: 0
    2016-04-24 11:51:57.841 [INFO ] [org.openhab.model.script.FILE ] - Entering rule Arduino sends to Openhab
    2016-04-24 11:51:58.229 [INFO ] [org.openhab.model.script.FILE ] - Entering rule Arduino sends to Openhab
    2016-04-24 11:51:59.161 [INFO ] [org.openhab.model.script.FILE ] - nodeId: 0 childId: 0 msgType: 3 subType: 9 msg: read: 105-105-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
    2016-04-24 11:51:59.454 [INFO ] [org.openhab.model.script.FILE ] - nodeId: 0 childId: 0 msgType: 3 subType: 9 msg: send: 0-0-105-105 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0
    2016-04-24 11:52:00.462 [INFO ] [org.openhab.model.script.FILE ] - nodeId: 105 childId: 255 msgType: 3 subType: 12 msg: 1.0
    openhab.log after turning on switch
    2016-04-24 11:49:30 - Relay received command ON
    2016-04-24 11:49:31 - Arduino received command 105;2;1;0;2;1
    2016-04-24 11:49:31 - Arduino state updated to 0;0;3;0;9;send: 0-0-105-105 s=2,c=1,t=2,pt=0,l=1,sg=0,st=fail:1
    openhab events.log
    2016-04-24 11:49:31.056 [INFO ] [org.openhab.model.script.FILE ] - Entering Rule: Send Relay Arduino Command
    2016-04-24 11:49:31.522 [INFO ] [org.openhab.model.script.FILE ] - Entering rule Arduino sends to Openhab
    2016-04-24 11:49:31.943 [INFO ] [org.openhab.model.script.FILE ] - Entering rule Arduino sends to Openhab
    2016-04-24 11:49:32.651 [INFO ] [org.openhab.model.script.FILE ] - nodeId: 105 childId: 2 msgType: 1 subType: 2 msg: 1
    CJ CassarinoC 1 Reply Last reply
    • XanderX
      XanderX
      Xander
      Is there a Serial.begin in your Arduino Code?
      • Ericb2745E Ericb2745
        Relay Sensor:
        #include <EEPROM.h>
        MyHwATMega328 hw;
          //Wipe eprom
            EEPROM.write(i, 0);
          gw.process();
        arduino items
        test.rules
        when
        then
        end
        openhab events.log
        CJ CassarinoC
        CJ CassarinoC
        CJ Cassarino
        @Ericb2745
        I think you are missing in your arduino code the process for sending the relay information to OpenHAB. Try using this:
        send(msg.set(state?false:true), true); // Send new state and request ack back
        Also I can't see the entire item file but you may be missing or incorrectly settting your MQTT binding. This is mine for reference:
        Switch  OpenWindow 			"Extend Actuator"							<rollershutter> 	(gH)								{mqtt=">[mymosquitto:mysensors-in/5/0/1/0/2:command:ON:1],>[mymosquitto:mysensors-in/5/0/1/0/2:command:OFF:0]"}
        Ericb2745E 1 Reply Last reply
        • CJ CassarinoC CJ Cassarino
          @Ericb2745
          Ericb2745E
          Ericb2745E
          Ericb2745
          wrote on last edited by Ericb2745
          @CJ-Cassarino Thanks for the reply. I will try your send syntax in my Arduino rules. Also, the reason you don't see the mqtt tag is that I am using a Serial Gateway not a MQTT gateway.
            CJ CassarinoC
            CJ CassarinoC
            CJ Cassarino
            @Ericb2745
            Well, in that case, it seems you are missing the receiving part of the code. This is directly from the example for the actuator and it works for me... It goes at the end of the code after the void loop.
            // process incoming message
                if (message.sensor < noRelays) {          // check if message is valid for relays..... previous line  [[[ if (message.sensor <=noRelays){ ]]]
                  digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
                  saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
                  Serial.print(message.sensor);
                  Serial.print(message.getBool());
                  if(message.getBool() == 0)
                    Serial.println(" = OFF");
                  else(Serial.println(" = ON"));
