  2. Announcements
  3. 💬 UV Sensor
💬 UV Sensor
24 Posts 9 Posters 8.5k Views 7 Watching
  • pndgt0P Offline
    pndgt0P Offline
    pndgt0
    Hi, I have problem in making Vera and Gateway add the UV Sensor (I used the example sketch). I have the following error after Gateway detect 1 Device: "System error: Device:496: Fail to load implementation file D_UvSensor1.xml ". I have reviewed the Luup files in Develop Apps and verified that the mentioned file does not exists only the same file name with JSON extension (don't know why it is not available neither in the Vera UI7 zip file for MySensors). I googled to find the XML file with no luck. Please, could anyone share the XML file with me or any help will be appreciated. Thanks Fernando
    • P Offline
      P Offline
      paqor
      This post is deleted!
      • P Offline
        P Offline
        paqor
        I'm getting low readings. The voltage at the sensor was OK. So it had to be the calculation. In my opinion the conversion of the 1023 values into a voltage is missing which can then be calculated further.
        uint16_t   uv = analogRead(UV_SENSOR_ANALOG_PIN);// Get UV value
            uv = (uv* (5 / 1023.0))*1000;
            if (uv>1170) {
                uv=1170;
        • P Offline
          P Offline
          paqor
