Requesting time from Openhab
Hey Guys,
I appreciate all the answers given to all the questions before mine in helping me figure out this stuff. I have a question about the requestTime() function and how we can handle it when being sent to Openhab. I have set up openhab with the MySensors binding as was talked about in another thread, and all looks good on that front. But, I am trying to get a response back to the node from the requestTime() and I can't figure out how to handle this request from the Openhab side of things. I can see the message come into the Openhab log ...02:13:23.415 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 101-101-0 s=255,c=3,t=1,pt=0,l=0,sg=0: 02:13:23.419 [DEBUG] [rs.internal.protocol.MySensorsReader] - 101;255;3;0;1;But how do I get Openhab to react to this message?
I have tried adding a dummy item with this id and setting up a rule to try to intercept but to no avail, the rule with...
received update or received command don't seem to fire, so I am at a loss.Any help would be much appreciated for this.
Thanks -
Hey Guys,
Thanks@brynt I suppose you're refering to the Openhab2 binding.
The answer for an request for time is not implemented yet. I need to look into this, shouldn't be that hard though.
Till I'm able to implement this you may implement a rule with the "expert mode" ;-)
https://github.com/tobof/openhab2-addons/wiki/Expert-mode-(rule-based)
Hi Tim,
Thanks for the response. I did try to add the MySensors Message binding from the UI but it seems to fail when adding as a new thing and just sits there as shown below.
When I first try to add the Mysensors message you get the following
10:34:13.403 [WARN ] [io.rest.core.thing.ThingTypeResource] - Cannot find channel type: mysensors:mySensorsMessage-channeland then once saving
10:35:54.128 [WARN ] [ore.thing.internal.ThingRegistryImpl] - Cannot create thing. No binding found that supports creating a thing of type mysensors:mysensorsMessage. 10:35:54.245 [INFO ] [smarthome.event.ThingAddedEvent ] - Thing 'mysensors:mysensorsMessage:8764e963' has been added.As I said I had tried to create a custom sensor thing with the child id 255 to intercept the message in a rule but did not seem to want to work either. Anyway not a big deal at least I can get everything else working fine.
Great work by the way :)
Thanks again for the response.
Hi Tim,
@brynt So, I was wrong: the answer to I_TIME was already implemented, but a bug was preventing it to work in combination with skipStartupCheck. I've fixed the bug and uploaded a current jar.
Please show me your configuration for the MySensorsMessage Thing. It should work.
A custom sensor with child id 255 expects a custom value, not an internal message, so it must not work. :-)
