  3. PCBs for battery based sensor
5 Posts 2 Posters 3.5k Views 5 Watching
  • jumpingJ
    jumpingJ
    jumping
    I'm working on two projects, both of them with RFM and NRF option: what do you think? Are the PCBs correct?
    1. First PCB
    Raspberrry PI3 - Domoticz
    ESP8266 GW - MySensors 2.1.1
    jumpingJ 1 Reply Last reply
    • jumpingJ jumping
      1. First PCB
      jumpingJ
      jumpingJ
      jumping
      1. PCB with SMD resistors and capacitors with LIPO module, arduino module and radio module
      • ileneken3I
        ileneken3I
        ileneken3
        I know little about hardware design, but I will comment on the TP4056 :
        I originally planned on using a LIPO battery with a TP4056, but then read that the batteries can't withstand cold weather. (I wanted it for a mailbox). Could the board also support the newer, LifeP04 batteries? There is probably an interface board for those too, and they would be more efficient because you don't have to regulate the voltage (they operate at 3 V).
        • ileneken3I ileneken3
          jumpingJ
          jumpingJ
          jumping
          wrote on last edited by jumping
          @ileneken3
          my PCB use a cheap and easily available TP4056 charger, for LiFeP04 batteries you can use charger like this: https://www.tindie.com/products/xorbit/lifepo4weredusb/
          but I have good news, I found an interesting article http://nerdralph.blogspot.it/2016/01/a-36v-lifepo4-charger-for-under-50c.html maybe I can integrate a LiFePO4 charger on my PCB
          ileneken3I 1 Reply Last reply
          • jumpingJ jumping
            @ileneken3
            ileneken3I
            ileneken3I
            ileneken3
            @jumping
            Consider this:
            https://www.aliexpress.com/item/1PCS-TP5000-4-2V-3-6V-1A-Lithium-Battery-Charging-Board-Charger-Module/32756803176.html?ws_ab_test=searchweb0_0,searchweb201602_2_10065_10068_10084_10083_10080_10082_10081_10060_10061_10062_10056_10055_10037_10054_10033_10059_10032_10078_10079_10077_10073_10096_10070_10052_423_10050_424_10051,searchweb201603_2&btsid=e6d6960b-1c4d-48ce-b291-cde58e005c58
            It's not as cheap as a TP4056, but it allows you to choose between battery technologies.
