  3. Help with hacking a wireless outdoor weather station
24 Posts 7 Posters 18.2k Views 6 Watching
  • Boots33B Boots33
    @breimann Yes I built one from scratch, if you are already building MySensors nodes you will have no trouble with it. It is a great way to expand your connected devices. I have a cheap Chinese floating thermometer in our pool and it even picked that up.
    As to the 433mhz devices, of the cheap sets on ebay the fs1000 transmitters seem ok but i have found you may need to supply them 9v or more if you want to get decent range. The receivers that are bundled with them are not very good at all. You would be best to search on ebay for "arduino 433mhz superheterodyne" for a more reliable receiver.
    As you are in OZ you can also buy the Dorji units from Willtronics, I have had good results with them and the transmitter reaches full power at 5v so is easier to use with arduino.
    Dorji TXR
    Dorji RX
    They are a bit more expensive though
    The antenna is also very important, I usually just use a length of wire around 170 to 175mm seems to work best for me. You will find lots of info about antennas if you google it.
    korttomaK
    korttomaK
    korttoma
    I noticed this also when working on this project. I had rally bad range, like 4m or so changing to the RBX6 superheterdyne gave me the range I needed.
    • Tomas
    • Boots33B Boots33
      Dorji TXR
      Dorji RX
      breimannB
      breimannB
      breimann
      @Boots33 thanks for sharing this info. Really helpful.
      I have another question if you don't mind. What's the process once RFlink is connected and running in domoticz to program wireless power points like Cleve and Watts etc? Is there a learning process when you press the on/off buttons on your remote?
      Boots33B 1 Reply Last reply
      • breimannB breimann
        Boots33B
        Boots33B
        Boots33
        @breimann once RFlink is running and you have "Accept new Hardware Devices" turned on in Domoticz settings, it will start adding anything it recognises to the devices list.
        You can then give the device a name and add it to your used devices. if it is a power socket then as you said just press the remote and watch for it to turn up in the device list. If you live in a heavily populated area you will likely get lots of devices showing up .
        You will have to make sure you get the right device or you will be turning on and off the neighbours lights as well.
        For your weather station you will see the data also shown as separate devices like temp, pressure etc. Remember it will probably be listed as fine offset.
        breimannB 1 Reply Last reply
        • Boots33B Boots33
          breimannB
          breimannB
          breimann
          @Boots33 thanks that's really helpful info much appreciated. Now i need to decommission my Mega as my GW ready for RFlink and setup a new gateway.
