<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Unstable radio connection.]]></title><description><![CDATA[<p dir="auto">I've been trying to set the connection for a good while already but I keep facing multiple problems. I use 10uF caps instead of 4,7uF recommended. I also use nRF24L01+PA+LNa version. I assign a static node id to both the gateway (I have a sensor connected) and to the node.</p>
<p dir="auto">Here is the log</p>
<pre><code>72816 TSM:FAIL:RE-INIT
72818 TSM:INIT
72825 TSM:INIT:TSP OK
72827 TSM:INIT:STATID=7
72829 TSF:SID:OK,ID=7
72832 TSM:FPAR
72868 TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
74876 !TSM:FPAR:NO REPLY
74878 TSM:FPAR
74915 TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
76922 !TSM:FPAR:NO REPLY
76924 TSM:FPAR
76960 TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
78968 !TSM:FPAR:NO REPLY
78970 TSM:FPAR
79006 TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
81014 !TSM:FPAR:FAIL
81015 TSM:FAIL:CNT=5
81017 TSM:FAIL:PDT
91020 TSM:FAIL:RE-INIT
91022 TSM:INIT
91029 TSM:INIT:TSP OK
91031 TSM:INIT:STATID=7
91033 TSF:SID:OK,ID=7
91035 TSM:FPAR
91072 TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
93079 !TSM:FPAR:NO REPLY
93081 TSM:FPAR
93117 TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
95125 !TSM:FPAR:NO REPLY
95127 TSM:FPAR
95163 TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
97171 !TSM:FPAR:NO REPLY
97173 TSM:FPAR
97209 TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
99217 !TSM:FPAR:FAIL
99218 TSM:FAIL:CNT=6
99220 TSM:FAIL:PDT
109223 TSM:FAIL:RE-INIT
109225 TSM:INIT
109233 TSM:INIT:TSP OK
109235 TSM:INIT:STATID=7
109237 TSF:SID:OK,ID=7
109240 TSM:FPAR
109276 TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
109739 TSF:MSG:READ,0-0-7,s=255,c=3,t=8,pt=1,l=1,sg=0:0
109744 TSF:MSG:FPAR OK,ID=0,D=1
110668 TSF:MSG:READ,0-0-7,s=255,c=3,t=8,pt=1,l=1,sg=0:0
111284 TSM:FPAR:OK
111285 TSM:ID
111287 TSM:ID:OK
111288 TSM:UPL
111292 TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
111503 TSF:MSG:READ,0-0-7,s=255,c=3,t=8,pt=1,l=1,sg=0:0
111508 !TSF:MSG:FPAR INACTIVE
111520 TSF:MSG:READ,0-0-7,s=255,c=3,t=25,pt=1,l=1,sg=0:1
111525 TSF:MSG:PONG RECV,HP=1
111528 TSM:UPL:OK
111531 TSM:READY:ID=7,PAR=0,DIS=1
111535 TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
113544 TSF:MSG:SEND,7-7-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.1.0-beta
113552 TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
Send Sketch Info:
115598 !TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=11,pt=0,l=10,sg=0,ft=0,st=NACK:RADIOTEST
115642 !TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=12,pt=0,l=2,sg=0,ft=1,st=NACK:v1
RADIOTEST v1
Get Config: Metric
Presenting Nodes
________________
  S_TEMP
116691 !TSF:MSG:SEND,7-7-0-0,s=1,c=0,t=6,pt=0,l=16,sg=0,ft=2,st=NACK:House Temperarue
________________
116750 MCO:REG:REQ
116788 !TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=3,st=NACK:2
118830 !TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=4,st=NACK:2
120871 !TSF:MSG:SEND,7-7-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=5,st=NACK:2
120879 !TSM:READY:UPL FAIL,SNP
120882 TSM:FPAR
120918 TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=6,st=OK:
122880 !TSF:SND:TNR
122926 !TSM:FPAR:NO REPLY
122928 TSM:FPAR
122964 TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
126882 !TSM:FPAR:NO REPLY
126884 TSM:FPAR
126921 TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
128928 !TSM:FPAR:NO REPLY
128930 TSM:FPAR
128967 TSF:MSG:SEND,7-7-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
130974 !TSM:FPAR:FAIL
130976 TSM:FAIL:CNT=1
130978 TSM:FAIL:PDT
140981 TSM:FAIL:RE-INIT
</code></pre>
<p dir="auto">Some times I do have a connection but it usually doesn't last for a long time. Here is my gateway log:</p>
<pre><code>0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.0-beta
0;255;3;0;9;TSM:INIT
0;255;3;0;9;TSF:WUR:MS=0
0;255;3;0;9;TSM:INIT:TSP OK
0;255;3;0;9;TSM:INIT:GW MODE
0;255;0;0;18;2.1.0-beta
0;2;0;0;6;
0;2;0;0;6;
0;255;3;0;9;MCO:BGN:STP
Temperature is: 28.06
0;2;1;0;0;28.06
0;255;3;0;9;TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
0;255;3;0;9;TSF:MSG:BC
0;255;3;0;9;TSF:MSG:FPAR REQ,ID=7
0;255;3;0;9;TSF:PNG:SEND,TO=0
0;255;3;0;9;TSF:CKU:OK
0;255;3;0;9;TSF:MSG:GWL OK
0;255;3;0;9;!TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
0;2;0;0;6;
0;2;0;0;6;
Temperature is: 28.13
0;2;1;0;0;28.13
</code></pre>
<p dir="auto">Any help would be appreciated!</p>
]]></description><link>https://forum.mysensors.org/topic/5512/unstable-radio-connection</link><generator>RSS for Node</generator><lastBuildDate>Sat, 12 Sep 2026 14:08:40 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/5512.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 12 Dec 2016 13:15:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Unstable radio connection. on Wed, 21 Dec 2016 07:35:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/boots33" aria-label="Profile: Boots33">@<bdi>Boots33</bdi></a>  Thanks for advice! I will definitely get some extra non amplified nrf modules and think about having a separate power supply for my radio.</p>
]]></description><link>https://forum.mysensors.org/post/55023</link><guid isPermaLink="true">https://forum.mysensors.org/post/55023</guid><dc:creator><![CDATA[Nikita]]></dc:creator><pubDate>Wed, 21 Dec 2016 07:35:11 GMT</pubDate></item><item><title><![CDATA[Reply to Unstable radio connection. on Mon, 19 Dec 2016 23:46:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nikita" aria-label="Profile: Nikita">@<bdi>Nikita</bdi></a> said:</p>
<blockquote>
<p dir="auto">I power my radio from the arduino unfortunately. Also I don't have other radio modules to test my project with.</p>
</blockquote>
<p dir="auto">It may be worth getting a few of the non amplified nrf modules and 3v regulators so you can do some testing.  The amplified versions should really have their own supply.  You could also try forcing the nrf to low power mode</p>
<pre><code>// Enable and select radio type attached
// Set LOW transmit power level as default
</code></pre>
<blockquote>
<p dir="auto">I covered my radios with foil to lower the interference. None of that really helped.</p>
</blockquote>
<p dir="auto">I found with the foil covering you have to be very thorough, if you leave even the smallest of gaps it will allow some rf noise to escape and cause trouble. The foil must also be earthed by allowing it to touch the aerial socket. it took me a few attempts to get it right.</p>
<p dir="auto">This is where having an extra nrf module comes in handy. you can build a simple node to be used as a range tester and then you can see if your range has improved. have a look at <a href="https://forum.mysensors.org/topic/4567/repeater-node-problems/17">this post </a>for my tester. I found it very useful in working out where to place repeater nodes as well.</p>
<blockquote>
<p dir="auto">There was one thing that actually worked. I have a sensor connected to the gateway that reads the temperature and sends it to itself. I use a serial-gateway to feed the data to the openhab installed on my pc. Once I disconnected this sensors from the gateway (so there is only one sensor total, on the node) everything worked fine :confused:</p>
</blockquote>
<p dir="auto">I can't be of much help there as I don't have any sensors on my gateway. Others do though without any problems so it should be ok. Perhaps the extra power draw of the sensors is enough to cause problems with the amplified nrf.</p>
]]></description><link>https://forum.mysensors.org/post/54921</link><guid isPermaLink="true">https://forum.mysensors.org/post/54921</guid><dc:creator><![CDATA[Boots33]]></dc:creator><pubDate>Mon, 19 Dec 2016 23:46:34 GMT</pubDate></item><item><title><![CDATA[Reply to Unstable radio connection. on Mon, 19 Dec 2016 18:05:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/boots33" aria-label="Profile: Boots33">@<bdi>Boots33</bdi></a> Thanks for such a detailed answer!</p>
<p dir="auto">I power my radio from the arduino unfortunately. Also I don't have other radio modules to test my project with. The distance between the node and the gateway is about 3m so it shouldn't be a problem. I covered my radios with foil to lower the interference. None of that really helped.</p>
<p dir="auto">There was one thing that actually worked. I have a sensor connected to the gateway that reads the temperature and sends it to itself. I use a serial-gateway to feed the data to the openhab installed on my pc. Once I disconnected this sensors from the gateway (so there is only one sensor total, on the node) everything worked fine :confused:  I assume there was an interference with gateway's own messages. I thought that it was possible to have sensors connected to gateway but when I do so the connection becomes unstable.<br />
P.S. I also installed 47uF capacitor to the gateway, just in case.</p>
]]></description><link>https://forum.mysensors.org/post/54899</link><guid isPermaLink="true">https://forum.mysensors.org/post/54899</guid><dc:creator><![CDATA[Nikita]]></dc:creator><pubDate>Mon, 19 Dec 2016 18:05:39 GMT</pubDate></item><item><title><![CDATA[Reply to Unstable radio connection. on Sat, 17 Dec 2016 20:49:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nikita" aria-label="Profile: Nikita">@<bdi>Nikita</bdi></a> Do you power the nRF24L01+PA+LNa from its own supply, they can draw too much for for the arduino 3v regulator and become unstable.<br />
Have you tried a standard nrf24l01+ to see if that improves reliability. is the distance too great between the nodes, can you try them close together. Being too close can also cause trouble as well.<br />
There have been several threads on range/reception issues, have a look at these and see if you can find some help. I know the <a href="http://blog.blackoise.de/2016/02/fixing-your-cheap-nrf24l01-palna-module/" rel="nofollow ugc">ugly fix</a> made a huge difference for my nRF24L01+PA+LNa nodes.</p>
<p dir="auto">Also you can see</p>
<p dir="auto"><a href="https://forum.mysensors.org/topic/1664/which-are-the-best-nrf24l01-modules">Which are the <em>best</em> NRF24L01+ modules?</a></p>
<p dir="auto"><a href="https://forum.mysensors.org/topic/3719/nrf24l01-vs-nrf24l01-pa-lna">NRF24l01+ vs. NRF24l01+ pa + lna</a></p>
<p dir="auto"><a href="https://forum.mysensors.org/topic/4631/nrf24l01-can-t-find-parent-on-gateway">NRF24L01 can't find parent on gateway</a></p>
]]></description><link>https://forum.mysensors.org/post/54782</link><guid isPermaLink="true">https://forum.mysensors.org/post/54782</guid><dc:creator><![CDATA[Boots33]]></dc:creator><pubDate>Sat, 17 Dec 2016 20:49:58 GMT</pubDate></item></channel></rss>
