  3. NRF24l01+ vs. NRF24l01+ pa + lna
22 Posts 11 Posters 19.9k Views 9 Watching
  • TakeroT
    TakeroT
    Takero
    wrote on last edited by Takero
    i have some trouble with the pa lna Module. Is something different between the normal Module and the pa lna? I use an Arduino Nano, with the "normal" it work perfect if I Connect the pa lna Module the serial connection will disconnect.
    I will use it as an Gateway.
    I try two different Nanos and nrf24l01+ lna pa
    • L
      L
      LastSamurai
      wrote on last edited by LastSamurai
      It uses much more power. The arduino can't handle that so you need an external power supply. It might also need shielding. There are many threads about that in this forum. Just search for them.
      TakeroT 1 Reply Last reply
      • L LastSamurai
        TakeroT
        TakeroT
        Takero
        @LastSamurai ok I will try it with an external Power source.
        • TakeroT
          TakeroT
          Takero
          Works like a charm! Thanks a lot!
          • L
            L
            LastSamurai
            Glad that I could help.
            • meju25M
              meju25M
              meju25
              I have a very similar problem.
              I have a sensor network with several nodes and one gateway, all using NRF24l01+. Everything works fine.
              Now I want to substitute the NRF24l01+ on the gateway with a NRF24l01 PA NLA to extend range.
              If I use the working gateway note and attach the PA NLA version I get ST=fail errors.
              Here the gateway log with the NRF24l01+ attached to the gateway:
              0_1464896067263_GatewayWithNRF24l01p.png image url)
              And here with the NRF24l01 PA NLA attached (no change in the Arduino Nano code - exactly same Nano used):
              For both log I did the same (operating a switch on a sensor node on and off).
              Any idea to solve the problem is highly appreciated.
              lg, Jürgen
              meju25M 1 Reply Last reply
              • meju25M meju25
                lg, Jürgen
                meju25M
                meju25M
                meju25
                By the way, I tried with 4 different pa lna modules from 2 different vendors, directly connected to the nano and also with external power source. Same result in any variant.
                AWIA 1 Reply Last reply
                • meju25M meju25
                  AWIA
                  AWIA
                  AWI
                  @meju25 try "the ugly fix" it is probably a shielding problem. You can also try to reduce the transmit power in your sketch (Config.h if you are on 1.5 version)
                  • V
                    V
                    vil1driver
                    wrote on last edited by vil1driver
                    hi..
                    maybe in myconfig.h put power at max
                    #define RF24_PA_LEVEL RF24_PA_MAX
                    all grounds connected ? external source and arduino source ?
                    • alexsh1A
                      alexsh1A
                      alexsh1
                      Interesting topic - I have nrf24l01+ PA/LNA connected to Uno (5v pin via LDO as 3.3v pin cannot handle high consumption) on my GW.
                      I must admit I tried normal transceiver and there is a huge difference. The amplified version must be properly fed (otherwise you'll get st=fail) and sometimes isolated (ugly fix). I did not have to do this ugly fix, but I have gone through a few modules to get the one working flawlessly
                      • meju25M
                        meju25M
                        meju25
                        Thank you all for your hints.
                        Unfortunately for me neighter worked (ugly fix, changing PA_LEVEL, decoupling with caps, using stable desktop power source).
                        It seems, that the Chinese modules are very sensitive.
                        I decided to give the amplified version a last try and ordered a little more expensive, non chinese (and hopefully better quality) module on Amazon.
                        If this also does not work, i will set up a repeater network with the nrf24l01+.
                        alexsh1A ChakkieC 2 Replies Last reply
                        • meju25M meju25
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @meju25 Just beware that Amazon selling the same chinese transceivers - I tried and returned a few.
                          • meju25M meju25
                            ChakkieC
                            ChakkieC
                            Chakkie
                            @meju25
                            Unfortunately I have the exact same problem with the amplified version. I have two of them and tried all the mentioned solutions (power, shielding etc) on both modules but none of them work. On the contrary the amplifier version works much worst then the normal version. So I have just given up on this module and put some of the normal NRF as repeater.
                            May be as one has mentioned, the Chinese module does not work properly. However the normal NRF module are all from China.
                            Raspberry Pi 2
                            Domoticz
                            RFXCOM
                            ZWAVE Aeon stick
                            Coming soon Arduino mysensors GW
                            • alexsh1A
                              alexsh1A
                              alexsh1
                              I just tried the ugly fix by @Oitzu on my GW and now I can confirm that the reception 3 walls away is much more stable. Generally speakIng my scene controller has been working intermittently and it is super stable now. My advice is as follows:
                              1. read the feedback on Alixexpress and order nrf24l01+ + PA from a reputable name. Personally I had to go through several modules.
                              2. Feed it from Arduino 5V pin via AMS1117.
                                This makes sure the feed is 3.3V solid. You may need to use LC filter to get the ripple out if you have a bad clone or a noisy feed
                              3. make sure you solder a cap - 4.7uF or higher.
                              4. there are settings in MyConfig.h:
                              RF24_PA_LEVEL_GW
                              Which you may need to change.
                              1. Try to scan 2.4Ghz and change the channel accordingly
                              2. if nothing helps please re-do the steps above. Please note that some Arduino clones are terrible quality. This may have some contribution towards your issue.
                              • OitzuO
                                OitzuO
                                Oitzu
                                @alexsh1 is this now officially called "the ugly fix"? :/
                                I should reconsider my naming choices. :D
                                alexsh1A 1 Reply Last reply
                                • OitzuO Oitzu
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @Oitzu google "ugly fix nrf24l01+" :)
                                  • meju25M
                                    meju25M
                                    meju25
                                    wrote on last edited by meju25
                                    Today I received to packets with NRF24l01 pa nla modules.
                                    1 from China (http://www.aliexpress.com/item/Free-Shipping-Special-promotions-1100-meter-long-distance-NRF24L01-PA-LNA-wireless-modules-1100meters-with-antenna/1622133032.html)
                                    1 from Amazon (https://www.amazon.de/gp/product/B01CYDXAI4/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1)
                                    both are working perfectly (2 other stores from Aliexpress delivered modules with the st=FAIL issue earlier).
                                    The module from Amazon is rather expensive, but it is shielded (metal body on the pcb).
                                    So if you are looking for working modules, I can recommend the two modules above.
                                    • meju25M meju25
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      @meju25 €16 for a module???????? Wow
                                      On Amazon the same Chinese modules are sold - no need to pay 3-4 times more
                                      • Igor AntolićI
                                        Igor AntolićI
                                        Igor Antolić
                                        I cannot see any more activity on this topic, but I have the same situation.
                                        About year ago I bought ebay model with antenna and it worked perfectly and solved my range problem for gateway.
                                        Now I ordered again from ebay (2 different stores, similar price) but on same arduino , when I replace old NFR24 with new ones (I got 5 different NRF modules) it doesn't work properly.
                                        Also if I put NRF24 without antenna it works fine,
                                        None of that ugly fix worked for me (shielding with alu, external power supply....)
                                        Please note that old NRF24 work without any "ugly fixes", directly connected to Arduino Nano 3.3 (3uF capacitor only).
                                        Also note that NRF24s without antenna work even without capacitor.
                                        So my question is simple: can anyone differ good ebay NFR24 with antenna from a nonworking one. I spent not only money but also a lot of time (waiting items from ebay that dont work) without success.
                                        Now I only can cry that I didnt order more pieces of that "old" model I had.
                                        But I hope someone will be able to tell.
                                        Currently I got 5 nonworking and 1 working with antenna, and 10 working NRF24 without antena.
                                        sundberg84S AWIA 2 Replies Last reply
                                        • Igor AntolićI Igor Antolić
                                          @Igor-Antolić - sorry to say that i dont have any good answer - but since I have been around this forum for a long time I have seen this questions so many times - and the answer is thats its hard to know what you are buying. Search the forum, there is alof of pictures and discussions on this topic. This (https://forum.mysensors.org/topic/1664/which-are-the-best-nrf24l01-modules) might be the biggest so far.
                                          Someone mentioned we should report / keep some sort of register which seller delivers good/bad modules... but just as you I have had some good batches and some really bad.
